Allocates and manages CUDA device memory.
Definition at line 129 of file sources/libs/nvdsinferserver/infer_cuda_utils.h.
Public Member Functions | |
| CudaDeviceMem (size_t size, int gpuId=0) | |
| ~CudaDeviceMem () override | |
| void | grow (size_t bytes) override |
| size_t | bytes () const |
| template<typename T > | |
| T * | ptr () const |
| void * | ptr () const |
| int | devId () const |
| InferMemType | type () const |
| void | reuse () |
| void | reuse () |
Protected Member Functions | |
| void | move_copy (SysMem &&o) |
| DISABLE_CLASS_COPY (SysMem) | |
Protected Attributes | |
| void * | m_Buf = nullptr |
| size_t | m_Size = 0 |
| int | m_DevId = 0 |
| InferMemType | m_Type = InferMemType::kNone |
| nvdsinferserver::CudaDeviceMem::CudaDeviceMem | ( | size_t | size, |
| int | gpuId = 0 |
override |
| int | gpuId = 0 |
override |
inlineinherited |
Definition at line 90 of file sources/libs/nvdsinferserver/infer_cuda_utils.h.
References nvdsinferserver::SysMem::m_Size.
inlineinherited |
Definition at line 90 of file 9.0/sources/libs/nvdsinferserver/infer_cuda_utils.h.
inlineinherited |
Definition at line 98 of file sources/libs/nvdsinferserver/infer_cuda_utils.h.
References nvdsinferserver::SysMem::m_DevId.
inlineinherited |
Definition at line 98 of file 9.0/sources/libs/nvdsinferserver/infer_cuda_utils.h.
protectedinherited |
overridevirtual |
Implements nvdsinferserver::SysMem.
overridevirtual |
inlineprotectedinherited |
Definition at line 107 of file 9.0/sources/libs/nvdsinferserver/infer_cuda_utils.h.
References nvdsinferserver::kNone, nvdsinferserver::SysMem::m_Buf, nvdsinferserver::SysMem::m_DevId, nvdsinferserver::SysMem::m_Size, and nvdsinferserver::SysMem::m_Type.
Definition at line 107 of file sources/libs/nvdsinferserver/infer_cuda_utils.h.
inlineinherited |
Definition at line 93 of file 9.0/sources/libs/nvdsinferserver/infer_cuda_utils.h.
References nvdsinferserver::SysMem::m_Buf.
inlineinherited |
Definition at line 93 of file sources/libs/nvdsinferserver/infer_cuda_utils.h.
inlineinherited |
Definition at line 97 of file 9.0/sources/libs/nvdsinferserver/infer_cuda_utils.h.
inlineinherited |
Definition at line 97 of file sources/libs/nvdsinferserver/infer_cuda_utils.h.
inlineinherited |
Definition at line 100 of file 9.0/sources/libs/nvdsinferserver/infer_cuda_utils.h.
inlineinherited |
Definition at line 100 of file sources/libs/nvdsinferserver/infer_cuda_utils.h.
inlineinherited |
Definition at line 99 of file 9.0/sources/libs/nvdsinferserver/infer_cuda_utils.h.
References nvdsinferserver::SysMem::m_Type.
inlineinherited |
Definition at line 99 of file sources/libs/nvdsinferserver/infer_cuda_utils.h.
Definition at line 120 of file sources/libs/nvdsinferserver/infer_cuda_utils.h.
Referenced by nvdsinferserver::SysMem::move_copy(), and nvdsinferserver::SysMem::ptr().
Definition at line 122 of file sources/libs/nvdsinferserver/infer_cuda_utils.h.
Referenced by nvdsinferserver::SysMem::devId(), and nvdsinferserver::SysMem::move_copy().
Definition at line 121 of file sources/libs/nvdsinferserver/infer_cuda_utils.h.
Referenced by nvdsinferserver::SysMem::bytes(), and nvdsinferserver::SysMem::move_copy().
Definition at line 123 of file sources/libs/nvdsinferserver/infer_cuda_utils.h.
Referenced by nvdsinferserver::SysMem::move_copy(), and nvdsinferserver::SysMem::type().
