nvdsinferserver::SysMem Class Referenceabstract
Base class for managing memory allocation.
Definition at line 87 of file sources/libs/nvdsinferserver/infer_cuda_utils.h.
Inheritance diagram for nvdsinferserver::SysMem:
Public Member Functions
virtual ~SysMem ()=default
size_t bytes () const
template<typename T >
T * ptr () const
void * ptr () const
int devId () const
InferMemType type () const
void reuse ()
virtual void grow (size_t bytes)=0
T * ptr () const
void * ptr () const
int devId () const
void reuse ()
Protected Member Functions
 SysMem (size_t s, int devId)
void move_copy (SysMem &&o)
 DISABLE_CLASS_COPY (SysMem)
Protected Attributes
void * m_Buf = nullptr
size_t m_Size = 0
int m_DevId = 0
InferMemType m_Type = InferMemType::kNone
◆ ~SysMem() [1/2]
virtual nvdsinferserver::SysMem::~SysMem ( )
virtualdefault
◆ SysMem() [1/2]
nvdsinferserver::SysMem::SysMem ( size_t  s,
int  devId
inlineprotected
◆ ~SysMem() [2/2]
virtualdefault
◆ SysMem() [2/2]
int  devId
inlineprotected
Member Function Documentation
◆ bytes() [1/2]
size_t nvdsinferserver::SysMem::bytes ( ) const
inline
Definition at line 90 of file sources/libs/nvdsinferserver/infer_cuda_utils.h.
References m_Size.
◆ bytes() [2/2]
inline
Definition at line 90 of file 9.0/sources/libs/nvdsinferserver/infer_cuda_utils.h.
References m_Size.
◆ devId() [1/2]
int nvdsinferserver::SysMem::devId ( ) const
inline
Definition at line 98 of file sources/libs/nvdsinferserver/infer_cuda_utils.h.
References m_DevId.
◆ devId() [2/2]
inline
Definition at line 98 of file 9.0/sources/libs/nvdsinferserver/infer_cuda_utils.h.
References m_DevId.
◆ DISABLE_CLASS_COPY() [1/2]
nvdsinferserver::SysMem::DISABLE_CLASS_COPY ( SysMem  )
protected
◆ DISABLE_CLASS_COPY() [2/2]
protected
◆ grow() [1/2]
◆ grow() [2/2]
◆ move_copy() [1/2]
void nvdsinferserver::SysMem::move_copy ( SysMem &&  o)
inlineprotected
◆ move_copy() [2/2]
inlineprotected
◆ ptr() [1/4]
T* nvdsinferserver::SysMem::ptr ( ) const
inline
Definition at line 93 of file 9.0/sources/libs/nvdsinferserver/infer_cuda_utils.h.
References m_Buf.
◆ ptr() [2/4]
inline
Definition at line 93 of file sources/libs/nvdsinferserver/infer_cuda_utils.h.
References m_Buf.
◆ ptr() [3/4]
void* nvdsinferserver::SysMem::ptr ( ) const
inline
Definition at line 97 of file 9.0/sources/libs/nvdsinferserver/infer_cuda_utils.h.
References m_Buf.
◆ ptr() [4/4]
inline
Definition at line 97 of file sources/libs/nvdsinferserver/infer_cuda_utils.h.
References m_Buf.
◆ reuse() [1/2]
void nvdsinferserver::SysMem::reuse ( )
inline
◆ reuse() [2/2]
inline
◆ type() [1/2]
InferMemType nvdsinferserver::SysMem::type ( ) const
inline
Definition at line 99 of file 9.0/sources/libs/nvdsinferserver/infer_cuda_utils.h.
References m_Type.
◆ type() [2/2]
inline
Definition at line 99 of file sources/libs/nvdsinferserver/infer_cuda_utils.h.
References m_Type.
Field Documentation
◆ m_Buf
void * nvdsinferserver::SysMem::m_Buf = nullptr
protected
Definition at line 120 of file sources/libs/nvdsinferserver/infer_cuda_utils.h.
Referenced by move_copy(), and ptr().
◆ m_DevId
int nvdsinferserver::SysMem::m_DevId = 0
protected
Definition at line 122 of file sources/libs/nvdsinferserver/infer_cuda_utils.h.
Referenced by devId(), and move_copy().
◆ m_Size
size_t nvdsinferserver::SysMem::m_Size = 0
protected
Definition at line 121 of file sources/libs/nvdsinferserver/infer_cuda_utils.h.
Referenced by bytes(), and move_copy().
◆ m_Type
InferMemType nvdsinferserver::SysMem::m_Type = InferMemType::kNone
protected
Definition at line 123 of file sources/libs/nvdsinferserver/infer_cuda_utils.h.
Referenced by move_copy(), and type().
