20 #ifndef __NVDSINFER_CUDA_UTILS_H__
21 #define __NVDSINFER_CUDA_UTILS_H__
24 #include <condition_variable>
30 #include <cuda_runtime_api.h>
42 uint flag = cudaStreamDefault,
int gpuId = 0,
int priority = 0);
45 int devId()
const {
return m_GpuId; }
51 m_Stream = o.m_Stream;
65 explicit CudaEvent(uint flag = cudaEventDefault,
int gpuId = 0);
67 operator cudaEvent_t() {
return m_Event; }
68 int devId()
const {
return m_GpuId; }
69 cudaEvent_t&
ptr() {
return m_Event; }
80 cudaEvent_t m_Event =
nullptr;
120 void*
m_Buf =
nullptr;
129 class CudaDeviceMem :
public SysMem {
136 void _allocate(
size_t bytes);
142 class CudaHostMem :
public SysMem {
149 void _allocate(
size_t bytes);
155 class CpuMem :
public SysMem {
162 std::vector<uint8_t> m_Data;
168 class CudaTensorBuf :
public BaseBatchBuffer {
171 const std::string& name,
InferMemType mt,
int devId,
bool initCuEvent);
176 assert(size <= m_MaxBatchSize);
181 void*
getBufPtr(uint32_t batchIdx)
const final;
190 uint32_t m_MaxBatchSize = 0;
208 int batchSize,
InferMemType mt,
int devId,
225 InferDataType dt,
int batchSize,
const std::string& name =
226 int devId = 0,
bool initCuEvent =
false);
242 InferDataType dt,
int batchSize,
243 int devId = 0,
bool initCuEvent =
false);
InferDataType
Datatype of the tensor buffer.
std::unique_ptr< CudaTensorBuf > UniqCudaTensorBuf
void grow(size_t bytes) override
UniqCudaTensorBuf createTensorBuf(const InferDims &dims, InferDataType dt, int batchSize, const std::string &name, InferMemType mt, int devId, bool initCuEvent)
Create a tensor buffer of the specified memory type, dimensions on the given device.
CudaEvent(uint flag=cudaEventDefault, int gpuId=0)
virtual ~SysMem()=default
InferMemType type() const
Wrapper class for CUDA events.
virtual void setBatchSize(uint32_t size)
void setName(const std::string &name)
Wrapper class for CUDA streams.
Helper class for managing Cuda Streams.
std::unique_ptr< SysMem > UniqSysMem
virtual void grow(size_t bytes)=0
void move_copy(SysMem &&o)
~CudaTensorBuf() override
UniqCudaTensorBuf createGpuTensorBuf(const InferDims &dims, InferDataType dt, int batchSize, const std::string &name="", int devId=0, bool initCuEvent=false)
Create a CUDA device memory tensor buffer of specified dimensions on the given device.
UniqCudaTensorBuf createCpuTensorBuf(const InferDims &dims, InferDataType dt, int batchSize, const std::string &name="", int devId=0, bool initCuEvent=false)
Create a CUDA pinned memory tensor buffer of specified dimensions on the given device.
NvDsInferStatus syncAllCudaEvents(const SharedBatchArray &bufList)
Synchronize on all events associated with the batch buffer array.
void setBatchSize(uint32_t size) override
~CudaDeviceMem() override
Base class for managing memory allocation.
void * getBufPtr(uint32_t batchIdx) const final
Header file of batch buffer related class declarations.
InferMemType
The memory types of inference buffers.
#define SIMPLE_MOVE_COPY(Cls)
helper move function
CudaDeviceMem(size_t size, int gpuId=0)
CudaTensorBuf(const InferDims &dims, InferDataType dt, int batchSize, const std::string &name, InferMemType mt, int devId, bool initCuEvent)
CudaStream(uint flag=cudaStreamDefault, int gpuId=0, int priority=0)
InferBufferDescription & mutableBufDesc()
CudaHostMem(size_t size, int gpuId=0)
DISABLE_CLASS_COPY(SysMem)
SysMem(size_t s, int devId)
std::string name
Name of the buffer.
NvDsInferStatus
