7.1 Release
DeepStream Metadata Extension
Defines an API for managing GStreamer DeepStream metadata.
DeepStream Metadata is attached to a buffer with gst_buffer_add_nvds_meta(). Its metadata type is set to NVDS_BATCH_GST_META.
Multiple groups of metadata may be attached by different elements. gst_buffer_get_nvds_meta() gets the last added NvDsMeta.
The NvDsMeta::meta_data structure member must be cast to a meaningful structure pointer based on the meta_type. For example, for meta_type = NVDS_BATCH_GST_META, meta_data must be cast as (NvDsBatchMeta *).
Data Structures
struct  _NvDsMeta
 Holds DeepSteam metadata. More...
Macros
#define NVDS_META_API_TYPE   (nvds_meta_api_get_type())
#define NVDS_META_INFO   (nvds_meta_get_info())
#define NVDS_META_STRING   "nvdsmeta"
Typedefs
typedef struct _NvDsMeta NvDsMeta
Enumerations
enum  GstNvDsMetaType {
  NVDS_GST_INVALID_META =-1,
  NVDS_BATCH_GST_META = NVDS_GST_CUSTOM_META + 1,
  NVDS_DECODER_GST_META,
  NVDS_DEWARPER_GST_META,
  NVDS_BUFFER_GST_AS_FRAME_USER_META,
  NVDS_RESERVED_GST_META = NVDS_GST_CUSTOM_META + 4096,
  NVDS_GST_META_FORCE32 = 0x7FFFFFFF
 Defines the type of metadata. More...
Functions
GType nvds_meta_api_get_type (void)
const GstMetaInfo * nvds_meta_get_info (void)
NvDsMetagst_buffer_add_nvds_meta (GstBuffer *buffer, gpointer meta_data, gpointer user_data, NvDsMetaCopyFunc copy_func, NvDsMetaReleaseFunc release_func)
 Adds GstMeta of type NvDsMeta to the GstBuffer and sets the meta_data member of NvDsMeta. More...
NvDsMetagst_buffer_get_nvds_meta (GstBuffer *buffer)
 Gets the NvDsMeta last added to a GstBuffer. More...
NvDsBatchMetagst_buffer_get_nvds_batch_meta (GstBuffer *buffer)
 Gets the NvDsBatchMeta added to a GstBuffer. More...
void nvds_copy_gst_meta_to_frame_meta (GstBuffer *src_gst_buffer, NvDsBatchMeta *batch_meta, NvDsFrameMeta *frame_meta)
 Copies all GstMeta objects on src_gst_buffer to the batched buffer's NvDsBatchMeta The GstMeta objects are copied into the user_meta_list within NvDsFrameMeta. More...
void nvds_copy_gst_meta_to_audio_frame_meta (GstBuffer *src_gst_buffer, NvDsBatchMeta *batch_meta, NvDsAudioFrameMeta *frame_meta)
 Copies all GstMeta objects on src_gst_buffer to the batched buffer's NvDsBatchMeta The GstMeta objects are copied into the user_meta_list within NvDsAudioFrameMeta. More...
◆ NVDS_META_API_TYPE
Definition at line 56 of file gstnvdsmeta.h.
◆ NVDS_META_INFO
Definition at line 60 of file gstnvdsmeta.h.
◆ NVDS_META_STRING
Definition at line 62 of file gstnvdsmeta.h.
Typedef Documentation
◆ NvDsMeta
◆ GstNvDsMetaType
NVIDIA-defined GstNvDsMetaType values are in the range from NVDS_BATCH_GST_META to NVDS_START_USER_META.
Enumerator
NVDS_BATCH_GST_META
Definition at line 68 of file gstnvdsmeta.h.
Function Documentation
◆ gst_buffer_add_nvds_meta()
NvDsMeta* gst_buffer_add_nvds_meta ( GstBuffer buffer,
gpointer  meta_data,
gpointer  user_data,
Parameters
[in]bufferA pointer to a GstBuffer to which the function adds metadata.
[in]meta_dataA pointer at which the function sets the meta_data member of NvDsMeta.
[in]user_dataA pointer to the user-specific data.
[in]copy_funcThe callback to be called when NvDsMeta is to be copied. The function is called with meta_data and user_data as parameters.
[in]release_funcThe callback to be called when NvDsMeta is to be destroyed. The function is called with meta_data and user_data as parameters.
Returns
A pointer to the attached NvDsMeta structure if successful, or NULL otherwise.
◆ gst_buffer_get_nvds_batch_meta()
NvDsBatchMeta* gst_buffer_get_nvds_batch_meta ( GstBuffer buffer)
Parameters
[in]bufferA pointer to the GstBuffer.
Returns
A pointer to the NvDsBatchMeta structure, or NULL if no NvDsMeta was attached.
◆ gst_buffer_get_nvds_meta()
NvDsMeta* gst_buffer_get_nvds_meta ( GstBuffer buffer)
Parameters
Returns
A pointer to the last added NvDsMeta structure, or NULL if no NvDsMeta was attached.
◆ nvds_copy_gst_meta_to_audio_frame_meta()
void nvds_copy_gst_meta_to_audio_frame_meta ( GstBuffer src_gst_buffer,
NvDsBatchMeta batch_meta,
NvDsAudioFrameMeta frame_meta
Note: the list of plain GstMeta from @src_gst_buffer are copied into @frame_meta as a single frame_meta->user_meta with NvDsUserMeta->base_meta.meta_type == NVDS_USER_FRAME_META_GST_META. The list of N X NvDsMeta from @src_gst_buffer are copied into @frame_meta as N X frame_meta->user_meta with each NvDsUserMeta->base_meta.meta_type == NvDsMeta->meta_type.
Parameters
[in]src_gst_bufferA pointer to the GstBuffer. GstMeta objects in this GstBuffer will be copied.
[in]batch_metaA pointer to the NvDsBatchMeta obtained from nvstreammux plugin. (Note: Works only for nvstreammux2 (Beta))
[in]frame_metaA pointer to the NvDsAudioFrameMeta NvDsAudioFrameMeta (metadata) for the batched input frame to which GstMeta objects will be copied as frame NvDsUserMeta.
◆ nvds_copy_gst_meta_to_frame_meta()
void nvds_copy_gst_meta_to_frame_meta ( GstBuffer src_gst_buffer,
NvDsFrameMeta frame_meta
Parameters
[in]frame_metaA pointer to the NvDsFrameMeta NvDsFrameMeta (metadata) for the batched input frame to which GstMeta objects will be copied as frame NvDsUserMeta.
◆ nvds_meta_api_get_type()
GType nvds_meta_api_get_type ( void  )
◆ nvds_meta_get_info()
const GstMetaInfo* nvds_meta_get_info ( void  )
