7.1 Release
Holds DeepSteam metadata.
Definition at line 90 of file gstnvdsmeta.h.
Data Fields
GstMeta meta
gpointer meta_data
 Holds a pointer to metadata. More...
gpointer user_data
 Holds a pointer to user-specific data . More...
gint meta_type
 Holds the type of metadata, one of values of enum GstNvDsMetaType. More...
NvDsMetaCopyFunc copyfunc
 A callback to be called when meta_data is to be copied or transformed from one buffer to other. More...
NvDsMetaReleaseFunc freefunc
 A callback to be called when meta_data is to be destroyed. More...
NvDsMetaCopyFunc gst_to_nvds_meta_transform_func
 A callback to be called when meta_data is transformed into NvDsUserMeta. More...
NvDsMetaReleaseFunc gst_to_nvds_meta_release_func
 A callback to be called when meta_data transformed into NvDsUserMeta is to be destroyed. More...
Field Documentation
◆ copyfunc
NvDsMetaCopyFunc _NvDsMeta::copyfunc
meta_data and user_data are passed as arguments.
Definition at line 106 of file gstnvdsmeta.h.
◆ freefunc
NvDsMetaReleaseFunc _NvDsMeta::freefunc
Definition at line 110 of file gstnvdsmeta.h.
◆ gst_to_nvds_meta_release_func
NvDsMetaReleaseFunc _NvDsMeta::gst_to_nvds_meta_release_func
This function must be provided by a GStreamer plugin that precedes Gst-nvstreammux in the DeepStream pipeline.
Definition at line 136 of file gstnvdsmeta.h.
◆ gst_to_nvds_meta_transform_func
NvDsMetaCopyFunc _NvDsMeta::gst_to_nvds_meta_transform_func
This function must be provided by a GStreamer plugin that precedes Gst-nvstreammux in the DeepStream pipeline. Gst-nvstreammux copies meta_data to user meta data at frame level inside NvDsFrameMeta. meta_data and user_data are passed as arguments.
To retrive the content of meta_data, iterate over NvDsFrameMetaList. Then search for meta_type of NvDsUserMeta which the user has attached. (See deepstream-gst-metadata-test source code for more details.)
Definition at line 128 of file gstnvdsmeta.h.
◆ meta
GstMeta _NvDsMeta::meta
Definition at line 91 of file gstnvdsmeta.h.
◆ meta_data
gpointer _NvDsMeta::meta_data
Must be cast to another structure based on meta_type.
Definition at line 95 of file gstnvdsmeta.h.
◆ meta_type
gint _NvDsMeta::meta_type
Definition at line 101 of file gstnvdsmeta.h.
◆ user_data
gpointer _NvDsMeta::user_data
Definition at line 98 of file gstnvdsmeta.h.
