7.1 Release
infer_icontext.h
1 /*
2  * SPDX-FileCopyrightText: Copyright (c) 2018-2022 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
4  *
11  */
12
23 #ifndef __NVDSINFERSERVER_ICONTEXT_H__
24 #define __NVDSINFERSERVER_ICONTEXT_H__
25
26 #ifdef __cplusplus
27
28 #include <stdarg.h>
29 #include <condition_variable>
30 #include <functional>
31 #include <list>
32 #include <memory>
33 #include <mutex>
34 #include <queue>
35
36 #include <infer_datatypes.h>
37
38 namespace nvdsinferserver {
39
43 using InferOutputCb = std::function<void(NvDsInferStatus, SharedIBatchArray)>;
44
48 using InferLoggingFunc =
49  std::function<void(NvDsInferLogLevel, const char* msg)>;
50
54 class IInferContext {
55 public:
56  virtual ~IInferContext() = default;
57
66  virtual NvDsInferStatus initialize(
67  const std::string& prototxt, InferLoggingFunc logFunc) = 0;
68
77  virtual NvDsInferStatus run(
78  SharedIBatchArray input, InferOutputCb outputCb) = 0;
79
85  virtual NvDsInferStatus deinit() = 0;
86
92  virtual void getNetworkInputInfo(NvDsInferNetworkInfo &networkInfo) = 0;
93 };
94
99 class ITritonServerInstance;
100
101 } // namespace nvdsinferserver
102
103 extern "C" {
104
113 INFER_EXPORT_API nvdsinferserver::IInferContext* createInferTrtISContext(
114  const char* configStr, uint32_t configStrLen);
115
121 INFER_EXPORT_API nvdsinferserver::IInferContext*
122 createInferTritonSimpleContext();
123
132 INFER_EXPORT_API nvdsinferserver::IInferContext*
133 createInferTritonGrpcContext(const char* configStr, uint32_t configStrLen);
134
144 INFER_EXPORT_API NvDsInferStatus NvDsTritonServerInit(
145  nvdsinferserver::ITritonServerInstance** instance, const char* configStr,
146  uint32_t configStrLen);
147
156 NvDsTritonServerDeinit(nvdsinferserver::ITritonServerInstance* instance);
157
169  void* buf, size_t bufBytes,
170  const nvdsinferserver::InferBufferDescription& desc, uint32_t batchSize,
171  std::function<void(void* data)> freeFunc);
172
179 NvDsInferServerCreateBatchArray();
180
194 NvDsInferServerCreateStrBuf(
195  const std::vector<std::string>& strings,
196  const nvdsinferserver::InferDims& dims, uint32_t batchSize,
197  const std::string& name, bool isInput);
198 }
199
200 #endif
201
202 #endif
nvdsinferserver
Definition: infer_custom_process.h:24
nvdsinferserver::SharedIBatchBuffer
std::shared_ptr< IBatchBuffer > SharedIBatchBuffer
Definition: infer_datatypes.h:204
infer_datatypes.h
Header file for the data types used in the inference processing.
NvDsInferLogLevel
NvDsInferLogLevel
Enum for the log levels of NvDsInferContext.
Definition: nvdsinfer.h:251
Definition: nvdsinfer.h:112
nvdsinferserver::SharedIBatchArray
std::shared_ptr< IBatchArray > SharedIBatchArray
Definition: infer_datatypes.h:205
INFER_EXPORT_API
Definition: infer_utils.h:33
Holds the information about the dimensions of a neural network layer.
Definition: infer_datatypes.h:146
NvDsInferStatus
NvDsInferStatus
Definition: nvdsinfer.h:220
Holds the information about a inference buffer.
Definition: infer_datatypes.h:168
