7.1 Release
libs/gstnvdscustomhelper/gst-nvmultiurisrcbincreator.h
1 /*
2  * SPDX-FileCopyrightText: Copyright (c) 2022-2024 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
4  *
11  */
12
13 #ifndef _GST_NVMULTIURISRCBIN_CREATOR_H_
14 #define _GST_NVMULTIURISRCBIN_CREATOR_H_
15 #include <gst/gst.h>
16 #include "gst-nvdscommonconfig.h"
17
18
23
24 #ifdef __cplusplus
25 extern "C"
26 {
27 #endif
28
29
31
32  typedef enum
33  {
37
46  guint sourceId);
47
57  guint sourceId, NvDsServerDecInfo * dec_info);
58
68  guint sourceId, NvDsServerConvInfo * conv_info);
69
78  NvDsServerMuxInfo * mux_info);
79
88  NvDsServerAppInstanceInfo * appinstance_info);
100  binName, NvDsMultiUriMode mode, GstDsNvStreammuxConfig * muxConfig);
101
111  gboolean
113  apiHandle, GstDsNvUriSrcConfig * sourceConfig);
114
127  gboolean
129  (NvDst_Handle_NvMultiUriSrcCreator apiHandle, guint sourceId);
130
145  gboolean
147  (NvDst_Handle_NvMultiUriSrcCreator apiHandle, guint sourceId);
148
161  GstElement
163  apiHandle);
164
175  GstPad
178
183  gboolean
186
194  apiHandle);
195
210  (NvDst_Handle_NvMultiUriSrcCreator apiHandle, gchar const *uri,
211  gchar const *sensorId);
212
213
219  sourceConfig);
220
226  config);
227
238  (NvDst_Handle_NvMultiUriSrcCreator apiHandle, gchar const *sensorId);
239
252  gboolean
254  (NvDst_Handle_NvMultiUriSrcCreator apiHandle, guint * count,
255  GstDsNvUriSrcConfig *** configs);
256
265  gboolean
267  (NvDst_Handle_NvMultiUriSrcCreator apiHandle, GList ** sensor_info_list);
268
280  (NvDst_Handle_NvMultiUriSrcCreator apiHandle, guint count,
281  GstDsNvUriSrcConfig ** configs);
282
283 #ifdef __cplusplus
284 }
285 #endif
286
287 #endif
gst_nvmultiurisrcbincreator_get_source_config_by_sensorid
GstDsNvUriSrcConfig * gst_nvmultiurisrcbincreator_get_source_config_by_sensorid(NvDst_Handle_NvMultiUriSrcCreator apiHandle, gchar const *sensorId)
API to procure the source config for a particular sensor.
_GstDsNvUriSrcConfig
Definition: libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:76
gst_nvmultiurisrcbincreator_src_config_dup
GstDsNvUriSrcConfig * gst_nvmultiurisrcbincreator_src_config_dup(GstDsNvUriSrcConfig *sourceConfig)
API to create duplicate of GstDsNvUriSrcConfig.
GstDsNvUriSrcConfig * gst_nvmultiurisrcbincreator_get_source_config(NvDst_Handle_NvMultiUriSrcCreator apiHandle, gchar const *uri, gchar const *sensorId)
gst_nvmultiurisrcbincreator_get_active_sources_list
gboolean gst_nvmultiurisrcbincreator_get_active_sources_list(NvDst_Handle_NvMultiUriSrcCreator apiHandle, guint *count, GstDsNvUriSrcConfig ***configs)
API to procure the list of sources.
NVDS_MULTIURISRCBIN_MODE_VIDEO
@ NVDS_MULTIURISRCBIN_MODE_VIDEO
Definition: libs/gstnvdscustomhelper/gst-nvmultiurisrcbincreator.h:34
gst_nvmultiurisrcbincreator_get_bin
GstElement * gst_nvmultiurisrcbincreator_get_bin(NvDst_Handle_NvMultiUriSrcCreator apiHandle)
Get the nvmultiurisrcbin GstBin User may: a) add this Bin/Element into their pipeline and b) link the...
gst_nvmultiurisrcbincreator_src_config_list_free
void gst_nvmultiurisrcbincreator_src_config_list_free(NvDst_Handle_NvMultiUriSrcCreator apiHandle, guint count, GstDsNvUriSrcConfig **configs)
API to destroy the memory allocation for list of sources procured with API: gst_nvmultiurisrcbincreat...
gst_nvmultiurisrcbincreator_add_source
gboolean gst_nvmultiurisrcbincreator_add_source(NvDst_Handle_NvMultiUriSrcCreator apiHandle, GstDsNvUriSrcConfig *sourceConfig)
API to add a source/stream into the nvmultiurisrcbin instance A new instance of nvurisrcbin will be c...
gst_nvmultiurisrcbincreator_remove_source_without_forced_state_change
gboolean gst_nvmultiurisrcbincreator_remove_source_without_forced_state_change(NvDst_Handle_NvMultiUriSrcCreator apiHandle, guint sourceId)
API to remove a source/stream from the nvmultiurisrcbin instance The corresponding nvurisrcbin will b...
NvDsServerMuxInfo
Definition: includes/nvds_rest_server.h:240
gst_nvmultiurisrcbincreator_src_config_free
void gst_nvmultiurisrcbincreator_src_config_free(GstDsNvUriSrcConfig *config)
API to free GstDsNvUriSrcConfig object obtained with API: gst_nvmultiurisrcbincreator_src_config_dup.
void * NvDst_Handle_NvMultiUriSrcCreator
Definition: includes/gst-nvmultiurisrcbincreator.h:30
NvDsMultiUriMode
NvDsMultiUriMode
Definition: libs/gstnvdscustomhelper/gst-nvmultiurisrcbincreator.h:32
set_nvuribin_dec_prop
gboolean set_nvuribin_dec_prop(NvDst_Handle_NvMultiUriSrcCreator apiHandle, guint sourceId, NvDsServerDecInfo *dec_info)
API to set property value on nvv4l2decoder of nvmultiurisrcbin instance.
gst_nvmultiurisrcbincreator_deinit
void gst_nvmultiurisrcbincreator_deinit(NvDst_Handle_NvMultiUriSrcCreator apiHandle)
Deinit the nvmultiurisrcbin creator API Note: If this bin was added to a parent pipeline instance,...
NvDsMultiUriMode
NvDsMultiUriMode
Definition: includes/gst-nvmultiurisrcbincreator.h:32
NvDsServerDecInfo
Definition: includes/nvds_rest_server.h:196
gst_nvmultiurisrcbincreator_get_source_info_list
gboolean gst_nvmultiurisrcbincreator_get_source_info_list(NvDst_Handle_NvMultiUriSrcCreator apiHandle, GList **sensor_info_list)
API to procure the list of active sources.
Definition: libs/gstnvdscustomhelper/gst-nvmultiurisrcbincreator.h:30
gst_nvmultiurisrcbincreator_sync_children_states
gboolean gst_nvmultiurisrcbincreator_sync_children_states(NvDst_Handle_NvMultiUriSrcCreator apiHandle)
set_nvuribin_conv_prop
gboolean set_nvuribin_conv_prop(NvDst_Handle_NvMultiUriSrcCreator apiHandle, guint sourceId, NvDsServerConvInfo *conv_info)
API to set property value on nvvideoconvert of nvmultiurisrcbin instance.
gboolean gst_nvmultiurisrcbincreator_remove_source(NvDst_Handle_NvMultiUriSrcCreator apiHandle, guint sourceId)
gst_nvmultiurisrcbincreator_init
NvDst_Handle_NvMultiUriSrcCreator gst_nvmultiurisrcbincreator_init(gchar *binName, NvDsMultiUriMode mode, GstDsNvStreammuxConfig *muxConfig)
Initialize the API for nvmultiurisrcbin creation Note: nvmultiurisrcbin is a collection of DeepStream...
NVDS_MULTIURISRCBIN_MODE_AUDIO
@ NVDS_MULTIURISRCBIN_MODE_AUDIO
Definition: libs/gstnvdscustomhelper/gst-nvmultiurisrcbincreator.h:35
set_nvuribin_mux_prop
gboolean set_nvuribin_mux_prop(NvDst_Handle_NvMultiUriSrcCreator apiHandle, NvDsServerMuxInfo *mux_info)
API to set property value on nvstreammux of nvmultiurisrcbin instance.
find_source
gboolean find_source(NvDst_Handle_NvMultiUriSrcCreator apiHandle, guint sourceId)
API to check if sourceId related source exist.
Definition: libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:114
Definition: includes/nvds_rest_server.h:322
NvDsServerAppInstanceInfo::uri
std::string uri
Definition: includes/nvds_rest_server.h:329
s_force_eos_handle
gboolean s_force_eos_handle(NvDst_Handle_NvMultiUriSrcCreator apiHandle, NvDsServerAppInstanceInfo *appinstance_info)
API to set EOS related properties on nvstreammux of nvmultiurisrcbin instance.
NvDsServerConvInfo
Definition: includes/nvds_rest_server.h:225
gst_nvmultiurisrcbincreator_get_source_pad
GstPad * gst_nvmultiurisrcbincreator_get_source_pad(NvDst_Handle_NvMultiUriSrcCreator apiHandle)
API to procure the source pad ("src") of this nvmultiurisrcbin instance Note: User may link the bin's...
