sources/gst-plugins/gst-nvinferserver/gstnvinferserver_meta_utils.h File Reference
nvinferserver metadata utilities header file.
This file contains the declarations of the metadata utility functions that add the inference output to the metadata of the input batch.
Definition in file sources/gst-plugins/gst-nvinferserver/gstnvinferserver_meta_utils.h.
Namespaces
 gstnvinferserver
Functions
void gstnvinferserver::attachDetectionMetadata (NvDsFrameMeta *frameMeta, NvDsObjectMeta *parentObj, const NvDsInferDetectionOutput &detection_output, float scaleX, float scaleY, uint32_t offsetLeft, uint32_t offsetTop, uint32_t roiLeft, uint32_t roiTop, uint32_t roiWidth, uint32_t roiHeight, uint32_t imageWidth, uint32_t imageHeight, uint32_t uniqueId, const ic::PluginControl &config)
 Attach detection metadata for the objects in a frame. More...
void gstnvinferserver::attachClassificationMetadata (NvDsObjectMeta *objMeta, NvDsFrameMeta *frameMeta, NvDsRoiMeta *roiMeta, const InferClassificationOutput &objInfo, uint32_t uniqueId, const std::string &classifierType, uint32_t imageWidth, uint32_t imageHeight)
 Attach the classification output as NvDsClassifierMeta. More...
void gstnvinferserver::mergeClassificationOutput (InferClassificationOutput &cache, const InferClassificationOutput &newRes)
 Merge the object history with the new classification result. More...
void gstnvinferserver::attachSegmentationMetadata (NvDsObjectMeta *objMeta, NvDsFrameMeta *frameMeta, NvDsRoiMeta *roiMeta, const NvDsInferSegmentationOutput &segmentation_output, dsis::SharedIBatchBuffer &buf)
 Attach the segmentation output as user metadata. More...
void gstnvinferserver::attachTensorOutputMeta (NvDsObjectMeta *objMeta, NvDsFrameMeta *frameMeta, NvDsRoiMeta *roiMeta, uint32_t uniqueId, const std::vector< dsis::SharedIBatchBuffer > &tensors, uint32_t batchIdx, const NvDsInferNetworkInfo &inputInfo, bool maintainAspectRatio, bool symmetricPadding)
 Attaches the raw tensor output to the GstBuffer as metadata. More...
void gstnvinferserver::attachFullTensorOutputMeta (NvDsBatchMeta *batchMeta, uint32_t uniqueId, const std::vector< dsis::SharedIBatchBuffer > &tensors, const NvDsInferNetworkInfo &inputInfo)
 Attach the full inference output tensors to the batch metadata. More...
