sources/includes/nvmsgbroker_internal.h File Reference
Data Structures
struct  NvMsgBrokerThread_t
struct  proto_adapter
struct  NvMsgBrokerHandle
struct  NvMsgBrokerSendCB_info
Macros
#define DEFAULT_RETRY_INTERVAL   2
#define DEFAULT_MAX_RETRY_LIMIT   360
#define DEFAULT_WORK_INTERVAL   10000
Typedefs
typedef struct proto_adapter AdapterLib
Enumerations
enum  NvMsgBrokerReturnVal {
  SUCCESS,
  FAIL,
  ERROR,
  SUCCESS,
  FAIL,
  ERROR
Functions
void * do_work_func (void *)
void adapter_connect_cb (NvDsMsgApiHandle *adapter_h_ptr, NvDsMsgApiEventType ds_evt)
void adapter_send_cb (void *user_ptr, NvDsMsgApiErrorType completion_flag)
void adapter_subscribe_cb (NvDsMsgApiErrorType flag, void *msg, int msglen, char *topic, void *user_ptr)
void handle_error (void *handle, pthread_mutex_t *lock, AdapterLib *lib, const char *log, const char *error)
bool fetch_adapter_api (void *so_handle, AdapterLib *LIB)
NvMsgBrokerReturnVal reconnect (NvMsgBrokerHandle *h_ptr)
void __attribute__ ((constructor)) nvmsgbroker_init(void)
void __attribute__ ((destructor)) nvmsgbroker_deinit(void)
Variables
const char * nvmsgbrokerConfig = "/opt/nvidia/deepstream/deepstream/sources/libs/nvmsgbroker/cfg_nvmsgbroker.txt"
bool auto_reconnect
unsigned retry_interval
unsigned max_retry_limit
unsigned work_interval
map< pair< string, AdapterLib * >, NvMsgBrokerHandle * > conn_string_handle_map
unordered_set< NvMsgBrokerHandle * > conn_Handle_list
unordered_map< NvDsMsgApiHandle, NvMsgBrokerHandle * > adapter_msgbroker_map
unordered_map< void *, AdapterLib * > so_handle_map
pthread_mutex_t h_ptr_lock
◆ DEFAULT_MAX_RETRY_LIMIT
Definition at line 28 of file sources/includes/nvmsgbroker_internal.h.
◆ DEFAULT_RETRY_INTERVAL
Definition at line 27 of file sources/includes/nvmsgbroker_internal.h.
◆ DEFAULT_WORK_INTERVAL
Definition at line 29 of file sources/includes/nvmsgbroker_internal.h.
Typedef Documentation
◆ AdapterLib
◆ NvMsgBrokerReturnVal
Enumerator
SUCCESS
FAIL
ERROR
SUCCESS
FAIL
ERROR
Definition at line 39 of file sources/includes/nvmsgbroker_internal.h.
Function Documentation
◆ __attribute__() [1/2]
void __attribute__ ( (constructor)  )
◆ __attribute__() [2/2]
void __attribute__ ( (destructor)  )
◆ adapter_connect_cb()
void adapter_connect_cb ( NvDsMsgApiHandle adapter_h_ptr,
◆ adapter_send_cb()
void adapter_send_cb ( void *  user_ptr,
◆ adapter_subscribe_cb()
void adapter_subscribe_cb ( NvDsMsgApiErrorType  flag,
void *  msg,
int  msglen,
char *  topic,
void *  user_ptr
◆ do_work_func()
void* do_work_func ( void *  )
◆ fetch_adapter_api()
bool fetch_adapter_api ( void *  so_handle,
AdapterLib LIB
◆ handle_error()
void handle_error ( void *  handle,
pthread_mutex_t *  lock,
AdapterLib lib,
const char *  log,
const char *  error
◆ reconnect()
NvMsgBrokerReturnVal reconnect ( NvMsgBrokerHandle h_ptr)
Variable Documentation
◆ adapter_msgbroker_map
unordered_map<NvDsMsgApiHandle, NvMsgBrokerHandle *> adapter_msgbroker_map
Definition at line 101 of file sources/includes/nvmsgbroker_internal.h.
◆ auto_reconnect
bool auto_reconnect
Definition at line 34 of file sources/includes/nvmsgbroker_internal.h.
◆ conn_Handle_list
unordered_set<NvMsgBrokerHandle *> conn_Handle_list
Definition at line 100 of file sources/includes/nvmsgbroker_internal.h.
◆ conn_string_handle_map
map<pair<string, AdapterLib *>, NvMsgBrokerHandle *> conn_string_handle_map
Definition at line 99 of file sources/includes/nvmsgbroker_internal.h.
◆ h_ptr_lock
Definition at line 105 of file sources/includes/nvmsgbroker_internal.h.
◆ max_retry_limit
Definition at line 36 of file sources/includes/nvmsgbroker_internal.h.
◆ nvmsgbrokerConfig
const char* nvmsgbrokerConfig = "/opt/nvidia/deepstream/deepstream/sources/libs/nvmsgbroker/cfg_nvmsgbroker.txt"
Definition at line 32 of file sources/includes/nvmsgbroker_internal.h.
◆ retry_interval
Definition at line 35 of file sources/includes/nvmsgbroker_internal.h.
◆ so_handle_map
unordered_map<void *, AdapterLib *> so_handle_map
Definition at line 102 of file sources/includes/nvmsgbroker_internal.h.
◆ work_interval
Definition at line 37 of file sources/includes/nvmsgbroker_internal.h.
