NvMsgBrokerHandle Struct Reference
Definition at line 72 of file sources/includes/nvmsgbroker_internal.h.
Collaboration diagram for NvMsgBrokerHandle:
Data Fields
int ref_count
string broker_proto_so
string broker_conn_str
string broker_cfg_path
string broker_signature
NvDsMsgApiHandle adapter_h_ptr
AdapterLibadapter_lib
nvds_msgapi_subscribe_request_cb_t subscribe_cb
unordered_set< nv_msgbroker_connect_cb_tconnect_cb_set
unordered_set< nv_msgbroker_send_cb_tsend_cb_set
unordered_map< string, set< pair< nv_msgbroker_subscribe_cb_t, void * > > > subscribe_topic_map
NvMsgBrokerThread_t do_work_thread
pthread_mutex_t subscribe_lock
int pending_send_cnt
bool disconnect
bool reconnecting
Field Documentation
◆ adapter_h_ptr
NvDsMsgApiHandle NvMsgBrokerHandle::adapter_h_ptr
Definition at line 78 of file sources/includes/nvmsgbroker_internal.h.
◆ adapter_lib
AdapterLib * NvMsgBrokerHandle::adapter_lib
Definition at line 79 of file sources/includes/nvmsgbroker_internal.h.
◆ broker_cfg_path
string NvMsgBrokerHandle::broker_cfg_path
Definition at line 76 of file sources/includes/nvmsgbroker_internal.h.
◆ broker_conn_str
string NvMsgBrokerHandle::broker_conn_str
Definition at line 75 of file sources/includes/nvmsgbroker_internal.h.
◆ broker_proto_so
string NvMsgBrokerHandle::broker_proto_so
Definition at line 74 of file sources/includes/nvmsgbroker_internal.h.
◆ broker_signature
string NvMsgBrokerHandle::broker_signature
Definition at line 77 of file sources/includes/nvmsgbroker_internal.h.
◆ connect_cb_set
unordered_set< nv_msgbroker_connect_cb_t > NvMsgBrokerHandle::connect_cb_set
Definition at line 81 of file sources/includes/nvmsgbroker_internal.h.
◆ disconnect
bool NvMsgBrokerHandle::disconnect
Definition at line 87 of file sources/includes/nvmsgbroker_internal.h.
◆ do_work_thread
NvMsgBrokerThread_t NvMsgBrokerHandle::do_work_thread
Definition at line 84 of file sources/includes/nvmsgbroker_internal.h.
◆ pending_send_cnt
int NvMsgBrokerHandle::pending_send_cnt
Definition at line 86 of file sources/includes/nvmsgbroker_internal.h.
◆ reconnecting
bool NvMsgBrokerHandle::reconnecting
Definition at line 88 of file sources/includes/nvmsgbroker_internal.h.
◆ ref_count
int NvMsgBrokerHandle::ref_count
Definition at line 73 of file sources/includes/nvmsgbroker_internal.h.
◆ send_cb_set
unordered_set< nv_msgbroker_send_cb_t > NvMsgBrokerHandle::send_cb_set
Definition at line 82 of file sources/includes/nvmsgbroker_internal.h.
◆ subscribe_cb
nvds_msgapi_subscribe_request_cb_t NvMsgBrokerHandle::subscribe_cb
Definition at line 80 of file sources/includes/nvmsgbroker_internal.h.
◆ subscribe_lock
pthread_mutex_t NvMsgBrokerHandle::subscribe_lock
Definition at line 85 of file sources/includes/nvmsgbroker_internal.h.
◆ subscribe_topic_map
unordered_map< string, set< pair< nv_msgbroker_subscribe_cb_t, void * > > > NvMsgBrokerHandle::subscribe_topic_map
Definition at line 83 of file sources/includes/nvmsgbroker_internal.h.
