8.0 Release
sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h
1 /*
2  * SPDX-FileCopyrightText: Copyright (c) 2022-2026 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
4  *
11  */
12
13 #ifndef _GST_NVDSCOMMON_CONFIG_H_
14 #define _GST_NVDSCOMMON_CONFIG_H_
15
16 #ifdef __cplusplus
17 extern "C" {
18 #endif
19
20 #include <gst/gst.h>
21
22 typedef enum
23 {
28
29 typedef enum
30 {
35
36 typedef enum
37 {
46
47 typedef enum
48 {
53
54 typedef enum
55 {
62
63 typedef enum
64 {
69
70 typedef enum
71 {
76
77 typedef enum
78 {
82
83 typedef struct _NvDsSensorInfo
84 {
85  guint source_id;
86  gchar const* uri;
87  gchar const* sensor_id;
88  gchar const* sensor_name;
90
91 typedef struct _NvDsRtspAttemptsInfo
92 {
93  gboolean attempt_exceeded;
94  guint source_id;
96
97 typedef struct _GstDsNvUriSrcConfig
98 {
100  gboolean loop;
101  gchar *uri;
102  gchar *sei_uuid;
103  gint latency;
105  gchar *smart_rec_dir_path;
106  gchar *smart_rec_file_prefix;
110  guint smart_rec_cache_size;
111  guint gpu_id;
112  gint source_id;
115  guint num_extra_surfaces;
117  guint cuda_memory_type;
118  guint drop_frame_interval;
119  gboolean low_latency_mode;
120  gboolean extract_sei_type5_data;
124  guint max_size_buffers;
127  gint num_rtsp_reconnects;
128  guint udp_buffer_size;
129  gchar *sensorId;
130  gboolean disable_passthrough;
131  gchar *sensorName;
132  gboolean disable_audio;
133  gboolean drop_on_latency;
134  gboolean ipc_buffer_timestamp_copy;
135  gchar *ipc_socket_path;
137  guint64 ipc_connection_interval;
138  gboolean sensorIdToPadIdMapping;
139  gboolean enable_error_propagation;
140  gchar* proto_lib;
141  gchar* conn_str;
142  gchar* topic;
144  guint64 creation_time_ns;
146
147 typedef struct
148 {
149  // Struct members to store config / properties for the element
150
151  //mandatory configs when using legacy nvstreammux
152  gint pipeline_width;
153  gint pipeline_height;
154  gint batched_push_timeout;
155
156  //not mandatory; auto configured
157  gint batch_size;
158
159  //not mandatory; defaults will be used
160  gint buffer_pool_size;
161  gint compute_hw;
162  gint num_surfaces_per_frame;
163  gint interpolation_method;
164  guint gpu_id;
165  guint nvbuf_memory_type;
166  gboolean live_source;
167  gboolean enable_padding;
168  gboolean attach_sys_ts_as_ntp;
169  gchar* config_file_path;
170  gboolean sync_inputs;
171  guint64 max_latency;
172  gboolean frame_num_reset_on_eos;
173  gboolean frame_num_reset_on_stream_reset;
174
175  guint64 frame_duration;
176  guint maxBatchSize;
177  gboolean async_process;
178  gboolean no_pipeline_eos;
179  gboolean extract_sei_type5_data;
180  gboolean sort_batch;
181  gboolean buffer_cache;
182  gint buffer_cache_timeout;
183  gboolean extract_sei_sim_time;
184  gboolean align_first_buffer;
185  guint sync_inputs_ntp;
186  gboolean drop_backward_sei;
188
189 #ifdef __cplusplus
190 }
191 #endif
192
193 #endif
SMART_REC_AUDIO_ONLY
@ SMART_REC_AUDIO_ONLY
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:74
_GstDsNvUriSrcConfig::smart_rec_container
NvDsUriSrcBinSRCont smart_rec_container
Definition: sources/includes/gst-nvdscommonconfig.h:107
SMART_REC_MULTI
@ SMART_REC_MULTI
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:67
_GstDsNvUriSrcConfig::proto_lib
gchar * proto_lib
Definition: sources/includes/gst-nvdscommonconfig.h:140
NvDsUriSrcBinRtpProtocol
Definition: sources/includes/gst-nvdscommonconfig.h:36
_GstDsNvUriSrcConfig::extract_sei_type5_data
Definition: sources/includes/gst-nvdscommonconfig.h:120
Definition: sources/includes/gst-nvdscommonconfig.h:97
_GstDsNvUriSrcConfig::disable_audio
Definition: sources/includes/gst-nvdscommonconfig.h:132
_NvDsRtspAttemptsInfo::source_id
guint source_id
Definition: sources/includes/gst-nvdscommonconfig.h:94
NvDsUriSrcBinDecSkipFrame
Definition: sources/includes/gst-nvdscommonconfig.h:29
SMART_REC_CLOUD
@ SMART_REC_CLOUD
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:66
GstDsNvUriSrcConfig
struct _GstDsNvUriSrcConfig GstDsNvUriSrcConfig
_NvDsSensorInfo::source_id
guint source_id
Definition: sources/includes/gst-nvdscommonconfig.h:85
LEAKY_UPSTREAM
@ LEAKY_UPSTREAM
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:50
_GstDsNvUriSrcConfig::src_type
NvDsUriSrcBinType src_type
Definition: sources/includes/gst-nvdscommonconfig.h:99
BUFFER_MODE_BUFFER
@ BUFFER_MODE_BUFFER
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:58
_GstDsNvUriSrcConfig::enable_error_propagation
Definition: sources/includes/gst-nvdscommonconfig.h:139
_GstDsNvUriSrcConfig::smart_record
NvDsUriSrcBinSRType smart_record
Definition: sources/includes/gst-nvdscommonconfig.h:104
_GstDsNvUriSrcConfig::udp_buffer_size
Definition: sources/includes/gst-nvdscommonconfig.h:128
NvDsUriSrcBinType
NvDsUriSrcBinType
Definition: sources/includes/gst-nvdscommonconfig.h:22
BUFFER_MODE_SYNCED
@ BUFFER_MODE_SYNCED
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:60
LEAKY_NONE
@ LEAKY_NONE
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:49
_GstDsNvUriSrcConfig::simulate_fps_interval_ms
guint simulate_fps_interval_ms
Definition: sources/includes/gst-nvdscommonconfig.h:143
_GstDsNvUriSrcConfig::creation_time_ns
Stream creation time in nanoseconds since epoch (from ISO 8601 timestamp)
Definition: sources/includes/gst-nvdscommonconfig.h:144
_GstDsNvUriSrcConfig::leaky
NvDsUriSrcBinLeaky leaky
Definition: sources/includes/gst-nvdscommonconfig.h:123
NvDsUriSrcBinSRCont
NvDsUriSrcBinSRCont
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:77
NvDsUriSrcBinSRType
NvDsUriSrcBinSRType
Definition: sources/includes/gst-nvdscommonconfig.h:63
_GstDsNvUriSrcConfig::uri
gchar * uri
Definition: sources/includes/gst-nvdscommonconfig.h:101
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:36
RTP_PROTOCOL_UNKNOWN
@ RTP_PROTOCOL_UNKNOWN
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:38
_GstDsNvUriSrcConfig::ipc_connection_interval
Definition: sources/includes/gst-nvdscommonconfig.h:137
NvDsSensorInfo
struct _NvDsSensorInfo NvDsSensorInfo
NvDsUriSrcBinSRMode
NvDsUriSrcBinSRMode
Definition: sources/includes/gst-nvdscommonconfig.h:70
SOURCE_TYPE_AUTO
@ SOURCE_TYPE_AUTO
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:24
_GstDsNvUriSrcConfig::drop_on_latency
Definition: sources/includes/gst-nvdscommonconfig.h:133
_GstDsNvUriSrcConfig::buffer_mode
NvDsUriSrcBinBufferMode buffer_mode
Definition: sources/includes/gst-nvdscommonconfig.h:114
_GstDsNvUriSrcConfig::disable_passthrough
Definition: sources/includes/gst-nvdscommonconfig.h:130
_GstDsNvUriSrcConfig::ipc_socket_path
gchar * ipc_socket_path
Definition: sources/includes/gst-nvdscommonconfig.h:135
_GstDsNvUriSrcConfig::sensorId
gchar * sensorId
unique Sensor ID string
Definition: sources/includes/gst-nvdscommonconfig.h:129
_GstDsNvUriSrcConfig::max_size_buffers
Definition: sources/includes/gst-nvdscommonconfig.h:124
SOURCE_TYPE_RTSP
@ SOURCE_TYPE_RTSP
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:26
Definition: sources/includes/gst-nvdscommonconfig.h:91
_GstDsNvUriSrcConfig::smart_rec_file_prefix
gchar * smart_rec_file_prefix
Definition: sources/includes/gst-nvdscommonconfig.h:106
_NvDsSensorInfo::sensor_name
gchar const * sensor_name
Definition: sources/includes/gst-nvdscommonconfig.h:88
DEC_SKIP_FRAMES_TYPE_NONE
@ DEC_SKIP_FRAMES_TYPE_NONE
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:31
NvDsUriSrcBinSRType
NvDsUriSrcBinSRType
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:63
RTP_PROTOCOL_TLS
@ RTP_PROTOCOL_TLS
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:44
RTP_PROTOCOL_UDP
@ RTP_PROTOCOL_UDP
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:39
_GstDsNvUriSrcConfig::rtsp_reconnect_interval_sec_org
gint rtsp_reconnect_interval_sec_org
Definition: sources/includes/gst-nvdscommonconfig.h:121
_NvDsSensorInfo::sensor_id
gchar const * sensor_id
Definition: sources/includes/gst-nvdscommonconfig.h:87
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:29
NvDsUriSrcBinSRCont
NvDsUriSrcBinSRCont
Definition: sources/includes/gst-nvdscommonconfig.h:77
NvDsUriSrcBinLeaky
NvDsUriSrcBinLeaky
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:47
RTP_PROTOCOL_UDP_UDPMCAST_TCP
@ RTP_PROTOCOL_UDP_UDPMCAST_TCP
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:42
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:54
_GstDsNvUriSrcConfig::topic
gchar * topic
Definition: sources/includes/gst-nvdscommonconfig.h:142
_GstDsNvUriSrcConfig::drop_frame_interval
Definition: sources/includes/gst-nvdscommonconfig.h:118
_GstDsNvUriSrcConfig::sensorName
gchar * sensorName
Sensor Name string; could be NULL.
Definition: sources/includes/gst-nvdscommonconfig.h:131
_GstDsNvUriSrcConfig::gpu_id
guint gpu_id
Definition: sources/includes/gst-nvdscommonconfig.h:111
SMART_REC_MKV
@ SMART_REC_MKV
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:80
DEC_SKIP_FRAMES_TYPE_NONREF
@ DEC_SKIP_FRAMES_TYPE_NONREF
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:32
SMART_REC_MP4
@ SMART_REC_MP4
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:79
NvDsUriSrcBinSRMode
NvDsUriSrcBinSRMode
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:70
_GstDsNvUriSrcConfig::smart_rec_def_duration
guint smart_rec_def_duration
Definition: sources/includes/gst-nvdscommonconfig.h:109
_GstDsNvUriSrcConfig::smart_rec_cache_size
Definition: sources/includes/gst-nvdscommonconfig.h:110
BUFFER_MODE_SLAVE
@ BUFFER_MODE_SLAVE
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:57
_GstDsNvUriSrcConfig::low_latency_mode
Definition: sources/includes/gst-nvdscommonconfig.h:119
_GstDsNvUriSrcConfig::num_rtsp_reconnects
Definition: sources/includes/gst-nvdscommonconfig.h:127
SMART_REC_DISABLE
@ SMART_REC_DISABLE
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:65
NvDsUriSrcBinType
NvDsUriSrcBinType
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:22
DEC_SKIP_FRAMES_TYPE_KEY_FRAME_ONLY
@ DEC_SKIP_FRAMES_TYPE_KEY_FRAME_ONLY
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:33
Definition: sources/includes/gst-nvdscommonconfig.h:54
BUFFER_MODE_UNKNOWN
@ BUFFER_MODE_UNKNOWN
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:56
_GstDsNvUriSrcConfig::smart_rec_dir_path
gchar * smart_rec_dir_path
Definition: sources/includes/gst-nvdscommonconfig.h:105
SMART_REC_AUDIO_VIDEO
@ SMART_REC_AUDIO_VIDEO
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:72
_NvDsSensorInfo
Definition: sources/includes/gst-nvdscommonconfig.h:83
SMART_REC_VIDEO_ONLY
@ SMART_REC_VIDEO_ONLY
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:73
_GstDsNvUriSrcConfig::cuda_memory_type
Definition: sources/includes/gst-nvdscommonconfig.h:117
RTP_PROTOCOL_TCP
@ RTP_PROTOCOL_TCP
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:41
_GstDsNvUriSrcConfig::smart_rec_mode
NvDsUriSrcBinSRMode smart_rec_mode
Definition: sources/includes/gst-nvdscommonconfig.h:108
SOURCE_TYPE_URI
@ SOURCE_TYPE_URI
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:25
RTP_PROTOCOL_UDP_MCAST
@ RTP_PROTOCOL_UDP_MCAST
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:40
_GstDsNvUriSrcConfig::latency
gint latency
Definition: sources/includes/gst-nvdscommonconfig.h:103
_GstDsNvUriSrcConfig::loop
gboolean loop
Definition: sources/includes/gst-nvdscommonconfig.h:100
_GstDsNvUriSrcConfig::rtp_protocol
NvDsUriSrcBinRtpProtocol rtp_protocol
Definition: sources/includes/gst-nvdscommonconfig.h:113
_GstDsNvUriSrcConfig::num_extra_surfaces
Definition: sources/includes/gst-nvdscommonconfig.h:115
_GstDsNvUriSrcConfig::sei_uuid
gchar * sei_uuid
Definition: sources/includes/gst-nvdscommonconfig.h:102
_GstDsNvUriSrcConfig::source_id
gint source_id
Definition: sources/includes/gst-nvdscommonconfig.h:112
GstDsNvStreammuxConfig
Definition: sources/includes/gst-nvdscommonconfig.h:147
_GstDsNvUriSrcConfig::skip_frames_type
NvDsUriSrcBinDecSkipFrame skip_frames_type
Definition: sources/includes/gst-nvdscommonconfig.h:116
Definition: sources/includes/gst-nvdscommonconfig.h:122
NvDsUriSrcBinLeaky
NvDsUriSrcBinLeaky
Definition: sources/includes/gst-nvdscommonconfig.h:47
_GstDsNvUriSrcConfig::ipc_connection_attempts
gint ipc_connection_attempts
Definition: sources/includes/gst-nvdscommonconfig.h:136
BUFFER_MODE_AUTO
@ BUFFER_MODE_AUTO
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:59
_GstDsNvUriSrcConfig::sensorIdToPadIdMapping
Definition: sources/includes/gst-nvdscommonconfig.h:138
_GstDsNvUriSrcConfig::conn_str
gchar * conn_str
Definition: sources/includes/gst-nvdscommonconfig.h:141
_NvDsSensorInfo::uri
gchar const * uri
Definition: sources/includes/gst-nvdscommonconfig.h:86
_GstDsNvUriSrcConfig::ipc_buffer_timestamp_copy
Definition: sources/includes/gst-nvdscommonconfig.h:134
LEAKY_DOWNSTREAM
@ LEAKY_DOWNSTREAM
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:51
_GstDsNvUriSrcConfig::rtsp_reconnect_attempts
gint rtsp_reconnect_attempts
Definition: sources/includes/gst-nvdscommonconfig.h:126
struct _NvDsRtspAttemptsInfo NvDsRtspAttemptsInfo
_NvDsRtspAttemptsInfo::attempt_exceeded
Definition: sources/includes/gst-nvdscommonconfig.h:93
RTP_PROTOCOL_HTTP
@ RTP_PROTOCOL_HTTP
Definition: sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h:43
_GstDsNvUriSrcConfig::init_rtsp_reconnect_interval_sec
gint init_rtsp_reconnect_interval_sec
Definition: sources/includes/gst-nvdscommonconfig.h:125
