| enum | NvDsUriSrcBinType {
SOURCE_TYPE_AUTO,
SOURCE_TYPE_URI,
SOURCE_TYPE_RTSP,
SOURCE_TYPE_AUTO,
SOURCE_TYPE_URI,
SOURCE_TYPE_RTSP,
SOURCE_TYPE_AUTO,
SOURCE_TYPE_URI,
SOURCE_TYPE_RTSP,
SOURCE_TYPE_AUTO,
SOURCE_TYPE_URI,
SOURCE_TYPE_RTSP
| enum | NvDsUriSrcBinDecSkipFrame {
DEC_SKIP_FRAMES_TYPE_NONE,
DEC_SKIP_FRAMES_TYPE_NONREF,
DEC_SKIP_FRAMES_TYPE_KEY_FRAME_ONLY,
| enum | NvDsUriSrcBinRtpProtocol {
RTP_PROTOCOL_UNKNOWN = 0,
RTP_PROTOCOL_UDP = 1,
RTP_PROTOCOL_UDP_MCAST = 2,
RTP_PROTOCOL_TCP = 4,
RTP_PROTOCOL_UDP_UDPMCAST_TCP = 7,
RTP_PROTOCOL_HTTP = 10,
RTP_PROTOCOL_TLS = 20,
| enum | NvDsUriSrcBinLeaky {
LEAKY_NONE,
LEAKY_UPSTREAM,
LEAKY_DOWNSTREAM,
LEAKY_NONE,
LEAKY_UPSTREAM,
LEAKY_DOWNSTREAM,
LEAKY_NONE,
LEAKY_UPSTREAM,
LEAKY_DOWNSTREAM,
LEAKY_NONE,
LEAKY_UPSTREAM,
LEAKY_DOWNSTREAM
| enum | NvDsUriSrcBinBufferMode {
BUFFER_MODE_UNKNOWN = 0,
BUFFER_MODE_SLAVE = 1,
BUFFER_MODE_BUFFER = 2,
BUFFER_MODE_AUTO = 3,
BUFFER_MODE_SYNCED = 4,
| enum | NvDsUriSrcBinSRType {
SMART_REC_DISABLE,
SMART_REC_CLOUD,
SMART_REC_MULTI,
SMART_REC_DISABLE,
SMART_REC_CLOUD,
SMART_REC_MULTI,
SMART_REC_DISABLE,
SMART_REC_CLOUD,
SMART_REC_MULTI,
SMART_REC_DISABLE,
SMART_REC_CLOUD,
SMART_REC_MULTI
| enum | NvDsUriSrcBinSRMode {
SMART_REC_AUDIO_VIDEO,
SMART_REC_VIDEO_ONLY,
SMART_REC_AUDIO_ONLY,
| enum | NvDsUriSrcBinSRCont {
SMART_REC_MP4,
SMART_REC_MKV,
SMART_REC_MP4,
SMART_REC_MKV,
SMART_REC_MP4,
SMART_REC_MKV,
SMART_REC_MP4,
SMART_REC_MKV
◆ GstDsNvUriSrcConfig
◆ NvDsRtspAttemptsInfo
◆ NvDsSensorInfo
◆ NvDsUriSrcBinBufferMode
| Enumerator |
| BUFFER_MODE_UNKNOWN | |
| BUFFER_MODE_SLAVE | |
| BUFFER_MODE_BUFFER | |
| BUFFER_MODE_AUTO | |
| BUFFER_MODE_SYNCED | |
Definition at line 54 of file sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
◆ NvDsUriSrcBinDecSkipFrame
| Enumerator |
| DEC_SKIP_FRAMES_TYPE_NONE | |
| DEC_SKIP_FRAMES_TYPE_NONREF | |
| DEC_SKIP_FRAMES_TYPE_KEY_FRAME_ONLY | |
Definition at line 29 of file sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
◆ NvDsUriSrcBinLeaky
◆ NvDsUriSrcBinRtpProtocol
| Enumerator |
| RTP_PROTOCOL_UNKNOWN | |
| RTP_PROTOCOL_UDP | |
| RTP_PROTOCOL_UDP_MCAST | |
| RTP_PROTOCOL_TCP | |
| RTP_PROTOCOL_UDP_UDPMCAST_TCP | |
| RTP_PROTOCOL_HTTP | |
| RTP_PROTOCOL_TLS | |
Definition at line 36 of file sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
◆ NvDsUriSrcBinSRCont
◆ NvDsUriSrcBinSRMode
| Enumerator |
| SMART_REC_AUDIO_VIDEO | |
| SMART_REC_VIDEO_ONLY | |
| SMART_REC_AUDIO_ONLY | |
Definition at line 70 of file sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
◆ NvDsUriSrcBinSRType
| Enumerator |
| SMART_REC_DISABLE | |
| SMART_REC_CLOUD | |
| SMART_REC_MULTI | |
| SMART_REC_CLOUD | |
| SMART_REC_MULTI | |
| SMART_REC_CLOUD | |
| SMART_REC_MULTI | |
| SMART_REC_CLOUD | |
| SMART_REC_MULTI | |
Definition at line 63 of file sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
◆ NvDsUriSrcBinType
| Enumerator |
| SOURCE_TYPE_AUTO | |
| SOURCE_TYPE_URI | |
| SOURCE_TYPE_RTSP | |
| SOURCE_TYPE_URI | |
| SOURCE_TYPE_URI | |
| SOURCE_TYPE_URI | |
Definition at line 22 of file sources/libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
