sources/libs/nvdsinferserver/infer_base_backend.h
1 /*
2  * SPDX-FileCopyrightText: Copyright (c) 2019-2022 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
4  *
11  */
12
22 #ifndef __NVDSINFER_BASE_BACKEND_H__
23 #define __NVDSINFER_BASE_BACKEND_H__
24
25 #include <stdarg.h>
26 #include <condition_variable>
27 #include <memory>
28 #include <mutex>
29 #include <queue>
30
31 #include "infer_datatypes.h"
32 #include "infer_ibackend.h"
33 #include "infer_utils.h"
34
35 namespace nvdsinferserver {
36
40 class BaseBackend : public IBackend {
41 public:
45  ~BaseBackend() override = default;
49  InferTensorOrder getInputTensorOrder() const final { return m_InputOrder; }
50
54  void setUniqueId(uint32_t id) { m_UniqueId = id; }
55
59  int uniqueId() const { return m_UniqueId; }
60
64  void setFirstDimBatch(bool flag) { m_IsFirstDimBatch = flag; }
65
69  bool isFirstDimBatch() const final { return m_IsFirstDimBatch; }
70
75  uint32_t getLayerSize() const final {
76  assert(!m_AllLayers.empty());
77  return (int)m_AllLayers.size();
78  }
79
83  uint32_t getInputLayerSize() const final {
84  return m_InputSize;
85  }
86
91  const std::string& bindingName) const final;
92
96  LayersTuple getInputLayers() const final;
97
101  LayersTuple getOutputLayers() const final;
102
107  bool checkInputDims(const InputShapes& shapes) const;
108
113  const LayerDescriptionList& allLayers() const { return m_AllLayers; }
114
118  void setKeepInputs(bool enable) {
119  m_KeepInputs = enable;
120  }
121
125  int32_t maxBatchSize() const final { return m_MaxBatchSize; }
126
130  bool isNonBatching() const { return isNonBatch(maxBatchSize()); }
131
132 protected:
136  using LayerIdxMap = std::unordered_map<std::string, int>;
137
148  void resetLayers(LayerDescriptionList layers, int inputSize);
149
153  LayerDescription* mutableLayerInfo(const std::string& bindingName)
154  {
155  const LayerDescription* info = getLayerInfo(bindingName);
156  return const_cast<LayerDescription*>(info);
157  }
158
162  void setInputTensorOrder(InferTensorOrder order) { m_InputOrder = order; }
163
167  bool needKeepInputs() const {
168  return m_KeepInputs;
169  }
170
174  void setMaxBatchSize(uint32_t size) { m_MaxBatchSize = size; }
175
176 private:
180  LayerDescriptionList m_AllLayers;
184  LayerIdxMap m_LayerNameToIdx;
188  uint32_t m_InputSize = 0;
192  int32_t m_MaxBatchSize = 0;
196  bool m_IsFirstDimBatch = false;
197
205  uint32_t m_UniqueId = 0;
209  bool m_KeepInputs = false;
210 };
211
212 using UniqBackend = std::unique_ptr<BaseBackend>;
213
214 } // namespace nvdsinferserver
215 #endif
nvdsinferserver::BaseBackend::getOutputLayers
Get the LayersTuple for output layers.
nvdsinferserver
Definition: sources/gst-plugins/gst-nvinferserver/gstnvinferserver_impl.h:64
INFER_EXPORT_API::isNonBatch
bool isNonBatch(T b)
Checks if the input batch size is zero.
Definition: sources/libs/nvdsinferserver/infer_utils.h:101
nvdsinferserver::BaseBackend::setMaxBatchSize
Set the maximum batch size to be used for the backend.
Definition: sources/libs/nvdsinferserver/infer_base_backend.h:174
nvdsinferserver::BaseBackend::~BaseBackend
~BaseBackend() override=default
Destructor, default.
nvdsinferserver::BaseBackend::uniqueId
Get the unique ID of the object instance.
Definition: sources/libs/nvdsinferserver/infer_base_backend.h:59
nvdsinferserver::BaseBackend::resetLayers
Set the layer description list of the backend.
nvdsinferserver::IBackend::InputShapes
std::vector< InputShapeTuple > InputShapes
Definition: sources/libs/nvdsinferserver/infer_ibackend.h:84
Definition: sources/libs/nvdsinferserver/infer_ibackend.h:60
nvdsinferserver::InferTensorOrder
InferTensorOrder
The type of tensor order.
Definition: sources/includes/nvdsinferserver/infer_datatypes.h:41
nvdsinferserver::BaseBackend::mutableLayerInfo
LayerDescription * mutableLayerInfo(const std::string &bindingName)
Get the mutable layer description structure for the layer name.
Definition: sources/libs/nvdsinferserver/infer_base_backend.h:153
nvdsinferserver::LayerDescription
Stores the information of a layer in the inference model.
Definition: sources/libs/nvdsinferserver/infer_ibackend.h:34
nvdsinferserver::IBackend::LayersTuple
std::tuple< const LayerDescription *, int > LayersTuple
Tuple containing pointer to layer descriptions and the number of layers.
Definition: sources/libs/nvdsinferserver/infer_ibackend.h:77
nvdsinferserver::BaseBackend::LayerIdxMap
std::unordered_map< std::string, int > LayerIdxMap
Map of layer name to layer index.
Definition: sources/libs/nvdsinferserver/infer_base_backend.h:136
nvdsinferserver::BaseBackend::isFirstDimBatch
Returns boolean indicating if batched input is expected.
Definition: sources/libs/nvdsinferserver/infer_base_backend.h:69
nvdsinferserver::BaseBackend::getLayerInfo
const LayerDescription * getLayerInfo(const std::string &bindingName) const final
Retrieve the layer information from the layer name.
nvdsinferserver::BaseBackend::getLayerSize
Returns the total number of layers (input + output) for the model.
Definition: sources/libs/nvdsinferserver/infer_base_backend.h:75
nvdsinferserver::BaseBackend::setUniqueId
Set the unique ID for the object instance.
Definition: sources/libs/nvdsinferserver/infer_base_backend.h:54
nvdsinferserver::BaseBackend::isNonBatching
Checks if the batch size indicates batched processing or no.
Definition: sources/libs/nvdsinferserver/infer_base_backend.h:130
nvdsinferserver::UniqBackend
std::unique_ptr< BaseBackend > UniqBackend
Definition: sources/libs/nvdsinferserver/infer_base_backend.h:212
nvdsinferserver::BaseBackend::setFirstDimBatch
Set the flag indicating that it is a batch input.
Definition: sources/libs/nvdsinferserver/infer_base_backend.h:64
nvdsinferserver::LayerDescriptionList
std::vector< LayerDescription > LayerDescriptionList
Definition: sources/libs/nvdsinferserver/infer_ibackend.h:58
nvdsinferserver::BaseBackend::getInputLayers
Get the LayersTuple for input layers.
nvdsinferserver::BaseBackend::maxBatchSize
Returns the maximum batch size set for the backend.
Definition: sources/libs/nvdsinferserver/infer_base_backend.h:125
infer_ibackend.h
Inference processing backend interface header file.
nvdsinferserver::InferTensorOrder::kNone
@ kNone
infer_utils.h
nvdsinferserver::BaseBackend::needKeepInputs
Check if the keep input flag is set.
Definition: sources/libs/nvdsinferserver/infer_base_backend.h:167
Base class of inference backend processing.
Definition: sources/libs/nvdsinferserver/infer_base_backend.h:40
nvdsinferserver::BaseBackend::allLayers
const LayerDescriptionList & allLayers() const
Returns the list of all descriptions of all layers, input and output.
Definition: sources/libs/nvdsinferserver/infer_base_backend.h:113
nvdsinferserver::BaseBackend::checkInputDims
bool checkInputDims(const InputShapes &shapes) const
Check that the list of input shapes have fixed dimensions and corresponding layers are marked as inpu...
nvdsinferserver::BaseBackend::getInputTensorOrder
Returns the input tensor order.
Definition: sources/libs/nvdsinferserver/infer_base_backend.h:49
nvdsinferserver::BaseBackend::setInputTensorOrder
Set the tensor order for the input layers.
Definition: sources/libs/nvdsinferserver/infer_base_backend.h:162
nvdsinferserver::BaseBackend::setKeepInputs
Set the flag indicating whether to keep inputs buffers.
Definition: sources/libs/nvdsinferserver/infer_base_backend.h:118
nvdsinferserver::BaseBackend::getInputLayerSize
Returns the number of input layers for the model.
Definition: sources/libs/nvdsinferserver/infer_base_backend.h:83
