7.1 Release
nvdsinferserver::IBackend Class Referenceabstract
Definition at line 60 of file infer_ibackend.h.
Inheritance diagram for nvdsinferserver::IBackend:
Public Types
enum  {
  kLTpLayerDesc,
  kTpLayerNum
enum  {
  kInShapeName,
  kInShapeDims
using InferenceDone = std::function< void(NvDsInferStatus, SharedBatchArray)>
 Function wrapper for post inference processing. More...
using InputsConsumed = std::function< void(SharedBatchArray)>
 Function wrapper called after the input buffer is consumed. More...
using LayersTuple = std::tuple< const LayerDescription *, int >
 Tuple containing pointer to layer descriptions and the number of layers. More...
using InputShapeTuple = std::tuple< std::string, InferBatchDims >
 Tuple of layer name and dimensions including batch size. More...
using InputShapes = std::vector< InputShapeTuple >
Public Member Functions
 IBackend ()=default
 Constructor, default. More...
virtual ~IBackend ()=default
 Destructor, default. More...
virtual NvDsInferStatus initialize ()=0
 Initialize the backend for processing. More...
virtual NvDsInferStatus specifyInputDims (const InputShapes &shapes)=0
 Specify the input layers for the backend. More...
virtual bool isFirstDimBatch () const =0
 Check if the flag for first dimension being batch is set. More...
virtual InferTensorOrder getInputTensorOrder () const =0
 Get the tensor order set for the input. More...
virtual int32_t maxBatchSize () const =0
 Get the configured maximum batch size for this backend. More...
virtual uint32_t getLayerSize () const =0
 Get the number of layers (input and output) for the model. More...
virtual uint32_t getInputLayerSize () const =0
 Get the number of input layers. More...
virtual const LayerDescriptiongetLayerInfo (const std::string &bindingName) const =0
 Get the layer description from the layer name. More...
virtual LayersTuple getInputLayers () const =0
 Get the LayersTuple for input layers. More...
virtual LayersTuple getOutputLayers () const =0
 Get the LayersTuple for output layers. More...
virtual NvDsInferStatus enqueue (SharedBatchArray inputs, SharedCuStream stream, InputsConsumed bufConsumed, InferenceDone inferenceDone)=0
 Enqueue an array of input batches for inference. More...
Member Typedef Documentation
◆ InferenceDone
Definition at line 66 of file infer_ibackend.h.
◆ InputsConsumed
Definition at line 70 of file infer_ibackend.h.
◆ InputShapes
Definition at line 84 of file infer_ibackend.h.
◆ InputShapeTuple
Definition at line 83 of file infer_ibackend.h.
◆ LayersTuple
Definition at line 77 of file infer_ibackend.h.
Member Enumeration Documentation
◆ anonymous enum
anonymous enum
Enumerator
kLTpLayerDesc
kTpLayerNum
Definition at line 72 of file infer_ibackend.h.
◆ anonymous enum
anonymous enum
Enumerator
kInShapeName
kInShapeDims
Definition at line 79 of file infer_ibackend.h.
◆ IBackend()
nvdsinferserver::IBackend::IBackend ( )
default
◆ ~IBackend()
virtual nvdsinferserver::IBackend::~IBackend ( )
virtualdefault
Member Function Documentation
◆ enqueue()
virtual NvDsInferStatus nvdsinferserver::IBackend::enqueue ( SharedBatchArray  inputs,
pure virtual
This function adds a input to the inference processing queue of the backend. The post inference function and function to be called after consuming input buffer is provided.
Parameters
[in]inputsList of input batch buffers
[in]streamThe CUDA stream to be used in inference processing.
[in]bufConsumedFunction to be called once input buffer is consumed.
[in]inferenceDoneFunction to be called after inference.
Returns
Execution status code.
Implemented in nvdsinferserver::TrtISBackend, nvdsinferserver::TritonGrpcBackend, and nvdsinferserver::TritonSimpleRuntime.
◆ getInputLayers()
virtual LayersTuple nvdsinferserver::IBackend::getInputLayers ( ) const
pure virtual
Implemented in nvdsinferserver::BaseBackend.
◆ getInputLayerSize()
virtual uint32_t nvdsinferserver::IBackend::getInputLayerSize ( ) const
pure virtual
◆ getInputTensorOrder()
virtual InferTensorOrder nvdsinferserver::IBackend::getInputTensorOrder ( ) const
pure virtual
◆ getLayerInfo()
virtual const LayerDescription* nvdsinferserver::IBackend::getLayerInfo ( const std::string &  bindingName) const
pure virtual
◆ getLayerSize()
virtual uint32_t nvdsinferserver::IBackend::getLayerSize ( ) const
pure virtual
◆ getOutputLayers()
virtual LayersTuple nvdsinferserver::IBackend::getOutputLayers ( ) const
pure virtual
◆ initialize()
virtual NvDsInferStatus nvdsinferserver::IBackend::initialize ( )
pure virtual
Returns
Status code of the type NvDsInferStatus.
◆ isFirstDimBatch()
virtual bool nvdsinferserver::IBackend::isFirstDimBatch ( ) const
pure virtual
◆ maxBatchSize()
virtual int32_t nvdsinferserver::IBackend::maxBatchSize ( ) const
pure virtual
◆ specifyInputDims()
virtual NvDsInferStatus nvdsinferserver::IBackend::specifyInputDims ( const InputShapes shapes)
pure virtual
Parameters
shapesList of name and shapes of the input layers.
Returns
Implemented in nvdsinferserver::TrtISBackend, and nvdsinferserver::TritonSimpleRuntime.
