nvdsinferserver::BaseBackend Class Referenceabstract
Base class of inference backend processing.
Definition at line 40 of file sources/libs/nvdsinferserver/infer_base_backend.h.
Inheritance diagram for nvdsinferserver::BaseBackend:
Collaboration diagram for nvdsinferserver::BaseBackend:
Public Types
enum  {
  kLTpLayerDesc,
  kTpLayerNum
enum  {
  kInShapeName,
  kInShapeDims
enum  {
  kLTpLayerDesc,
  kTpLayerNum
enum  {
  kInShapeName,
  kInShapeDims
using InferenceDone = std::function< void(NvDsInferStatus, SharedBatchArray)>
 Function wrapper for post inference processing. More...
using InputsConsumed = std::function< void(SharedBatchArray)>
 Function wrapper called after the input buffer is consumed. More...
using LayersTuple = std::tuple< const LayerDescription *, int >
 Tuple containing pointer to layer descriptions and the number of layers. More...
using InputShapeTuple = std::tuple< std::string, InferBatchDims >
 Tuple of layer name and dimensions including batch size. More...
using InputShapes = std::vector< InputShapeTuple >
Public Member Functions
 ~BaseBackend () override=default
 Destructor, default. More...
InferTensorOrder getInputTensorOrder () const final
 Returns the input tensor order. More...
void setUniqueId (uint32_t id)
 Set the unique ID for the object instance. More...
int uniqueId () const
 Get the unique ID of the object instance. More...
void setFirstDimBatch (bool flag)
 Set the flag indicating that it is a batch input. More...
bool isFirstDimBatch () const final
 Returns boolean indicating if batched input is expected. More...
uint32_t getLayerSize () const final
 Returns the total number of layers (input + output) for the model. More...
uint32_t getInputLayerSize () const final
 Returns the number of input layers for the model. More...
const LayerDescriptiongetLayerInfo (const std::string &bindingName) const final
 Retrieve the layer information from the layer name. More...
LayersTuple getInputLayers () const final
 Get the LayersTuple for input layers. More...
LayersTuple getOutputLayers () const final
 Get the LayersTuple for output layers. More...
bool checkInputDims (const InputShapes &shapes) const
 Check that the list of input shapes have fixed dimensions and corresponding layers are marked as input layers. More...
const LayerDescriptionListallLayers () const
 Returns the list of all descriptions of all layers, input and output. More...
void setKeepInputs (bool enable)
 Set the flag indicating whether to keep inputs buffers. More...
int32_t maxBatchSize () const final
 Returns the maximum batch size set for the backend. More...
bool isNonBatching () const
 Checks if the batch size indicates batched processing or no. More...
virtual NvDsInferStatus initialize ()=0
 Initialize the backend for processing. More...
virtual NvDsInferStatus specifyInputDims (const InputShapes &shapes)=0
 Specify the input layers for the backend. More...
virtual NvDsInferStatus enqueue (SharedBatchArray inputs, SharedCuStream stream, InputsConsumed bufConsumed, InferenceDone inferenceDone)=0
 Enqueue an array of input batches for inference. More...
Protected Types
using LayerIdxMap = std::unordered_map< std::string, int >
 Map of layer name to layer index. More...
Protected Member Functions
void resetLayers (LayerDescriptionList layers, int inputSize)
 Set the layer description list of the backend. More...
LayerDescriptionmutableLayerInfo (const std::string &bindingName)
 Get the mutable layer description structure for the layer name. More...
void setInputTensorOrder (InferTensorOrder order)
 Set the tensor order for the input layers. More...
bool needKeepInputs () const
 Check if the keep input flag is set. More...
void setMaxBatchSize (uint32_t size)
 Set the maximum batch size to be used for the backend. More...
Member Typedef Documentation
◆ InferenceDone [1/2]
Definition at line 66 of file sources/libs/nvdsinferserver/infer_ibackend.h.
◆ InferenceDone [2/2]
Definition at line 66 of file 9.0/sources/libs/nvdsinferserver/infer_ibackend.h.
◆ InputsConsumed [1/2]
using nvdsinferserver::IBackend::InputsConsumed = std::function<void(SharedBatchArray)>
inherited
Definition at line 70 of file sources/libs/nvdsinferserver/infer_ibackend.h.
◆ InputsConsumed [2/2]
inherited
Definition at line 70 of file 9.0/sources/libs/nvdsinferserver/infer_ibackend.h.
◆ InputShapes [1/2]
◆ InputShapes [2/2]
◆ InputShapeTuple [1/2]
using nvdsinferserver::IBackend::InputShapeTuple = std::tuple<std::string, InferBatchDims>
inherited
Definition at line 83 of file sources/libs/nvdsinferserver/infer_ibackend.h.
◆ InputShapeTuple [2/2]
inherited
Definition at line 83 of file 9.0/sources/libs/nvdsinferserver/infer_ibackend.h.
◆ LayerIdxMap [1/2]
using nvdsinferserver::BaseBackend::LayerIdxMap = std::unordered_map<std::string, int>
protected
Definition at line 136 of file 9.0/sources/libs/nvdsinferserver/infer_base_backend.h.
◆ LayerIdxMap [2/2]
protected
Definition at line 136 of file sources/libs/nvdsinferserver/infer_base_backend.h.
◆ LayersTuple [1/2]
using nvdsinferserver::IBackend::LayersTuple = std::tuple<const LayerDescription*, int>
inherited
Definition at line 77 of file 9.0/sources/libs/nvdsinferserver/infer_ibackend.h.
◆ LayersTuple [2/2]
inherited
Definition at line 77 of file sources/libs/nvdsinferserver/infer_ibackend.h.
Member Enumeration Documentation
◆ anonymous enum
anonymous enum
inherited
Enumerator
kLTpLayerDesc
kTpLayerNum
Definition at line 72 of file sources/libs/nvdsinferserver/infer_ibackend.h.
◆ anonymous enum
anonymous enum
inherited
Enumerator
kInShapeName
kInShapeDims
Definition at line 79 of file sources/libs/nvdsinferserver/infer_ibackend.h.
◆ anonymous enum
anonymous enum
inherited
Enumerator
kLTpLayerDesc
kTpLayerNum
Definition at line 72 of file 9.0/sources/libs/nvdsinferserver/infer_ibackend.h.
◆ anonymous enum
anonymous enum
inherited
Enumerator
kInShapeName
kInShapeDims
Definition at line 79 of file 9.0/sources/libs/nvdsinferserver/infer_ibackend.h.
◆ ~BaseBackend() [1/2]
nvdsinferserver::BaseBackend::~BaseBackend ( )
overridedefault
◆ ~BaseBackend() [2/2]
overridedefault
Member Function Documentation
◆ allLayers() [1/2]
const LayerDescriptionList& nvdsinferserver::BaseBackend::allLayers ( ) const
inline
Definition at line 113 of file sources/libs/nvdsinferserver/infer_base_backend.h.
◆ allLayers() [2/2]
inline
Definition at line 113 of file 9.0/sources/libs/nvdsinferserver/infer_base_backend.h.
◆ checkInputDims() [1/2]
bool nvdsinferserver::BaseBackend::checkInputDims ( const InputShapes shapes) const
◆ checkInputDims() [2/2]
◆ enqueue() [1/2]
virtual NvDsInferStatus nvdsinferserver::IBackend::enqueue ( SharedBatchArray  inputs,
pure virtualinherited
This function adds a input to the inference processing queue of the backend. The post inference function and function to be called after consuming input buffer is provided.
Parameters
[in]inputsList of input batch buffers
[in]streamThe CUDA stream to be used in inference processing.
[in]bufConsumedFunction to be called once input buffer is consumed.
[in]inferenceDoneFunction to be called after inference.
Returns
Execution status code.
Implemented in nvdsinferserver::TrtISBackend, nvdsinferserver::TrtISBackend, nvdsinferserver::TritonGrpcBackend, nvdsinferserver::TritonGrpcBackend, nvdsinferserver::TritonSimpleRuntime, and nvdsinferserver::TritonSimpleRuntime.
◆ enqueue() [2/2]
Parameters
Returns
◆ getInputLayers() [1/2]
LayersTuple nvdsinferserver::BaseBackend::getInputLayers ( ) const
finalvirtual
Implements nvdsinferserver::IBackend.
◆ getInputLayers() [2/2]
finalvirtual
◆ getInputLayerSize() [1/2]
uint32_t nvdsinferserver::BaseBackend::getInputLayerSize ( ) const
inlinefinalvirtual
Definition at line 83 of file sources/libs/nvdsinferserver/infer_base_backend.h.
◆ getInputLayerSize() [2/2]
inlinefinalvirtual
Definition at line 83 of file 9.0/sources/libs/nvdsinferserver/infer_base_backend.h.
◆ getInputTensorOrder() [1/2]
InferTensorOrder nvdsinferserver::BaseBackend::getInputTensorOrder ( ) const
inlinefinalvirtual
Definition at line 49 of file 9.0/sources/libs/nvdsinferserver/infer_base_backend.h.
◆ getInputTensorOrder() [2/2]
inlinefinalvirtual
Definition at line 49 of file sources/libs/nvdsinferserver/infer_base_backend.h.
◆ getLayerInfo() [1/2]
const LayerDescription* nvdsinferserver::BaseBackend::getLayerInfo ( const std::string &  bindingName) const
finalvirtual
Referenced by mutableLayerInfo().
◆ getLayerInfo() [2/2]
finalvirtual
◆ getLayerSize() [1/2]
uint32_t nvdsinferserver::BaseBackend::getLayerSize ( ) const
inlinefinalvirtual
Definition at line 75 of file 9.0/sources/libs/nvdsinferserver/infer_base_backend.h.
◆ getLayerSize() [2/2]
inlinefinalvirtual
Definition at line 75 of file sources/libs/nvdsinferserver/infer_base_backend.h.
◆ getOutputLayers() [1/2]
LayersTuple nvdsinferserver::BaseBackend::getOutputLayers ( ) const
finalvirtual
◆ getOutputLayers() [2/2]
finalvirtual
◆ initialize() [1/2]
virtual NvDsInferStatus nvdsinferserver::IBackend::initialize ( )
◆ initialize() [2/2]
◆ isFirstDimBatch() [1/2]
bool nvdsinferserver::BaseBackend::isFirstDimBatch ( ) const
inlinefinalvirtual
Definition at line 69 of file sources/libs/nvdsinferserver/infer_base_backend.h.
◆ isFirstDimBatch() [2/2]
inlinefinalvirtual
Definition at line 69 of file 9.0/sources/libs/nvdsinferserver/infer_base_backend.h.
◆ isNonBatching() [1/2]
bool nvdsinferserver::BaseBackend::isNonBatching ( ) const
inline
Definition at line 130 of file 9.0/sources/libs/nvdsinferserver/infer_base_backend.h.
References INFER_EXPORT_API::isNonBatch(), and maxBatchSize().
◆ isNonBatching() [2/2]
inline
Definition at line 130 of file sources/libs/nvdsinferserver/infer_base_backend.h.
◆ maxBatchSize() [1/2]
int32_t nvdsinferserver::BaseBackend::maxBatchSize ( ) const
inlinefinalvirtual
Definition at line 125 of file 9.0/sources/libs/nvdsinferserver/infer_base_backend.h.
◆ maxBatchSize() [2/2]
inlinefinalvirtual
Definition at line 125 of file sources/libs/nvdsinferserver/infer_base_backend.h.
Referenced by isNonBatching().
◆ mutableLayerInfo() [1/2]
LayerDescription* nvdsinferserver::BaseBackend::mutableLayerInfo ( const std::string &  bindingName)
inlineprotected
Definition at line 153 of file sources/libs/nvdsinferserver/infer_base_backend.h.
References getLayerInfo().
◆ mutableLayerInfo() [2/2]
inlineprotected
Definition at line 153 of file 9.0/sources/libs/nvdsinferserver/infer_base_backend.h.
◆ needKeepInputs() [1/2]
bool nvdsinferserver::BaseBackend::needKeepInputs ( ) const
inlineprotected
Definition at line 167 of file sources/libs/nvdsinferserver/infer_base_backend.h.
◆ needKeepInputs() [2/2]
inlineprotected
Definition at line 167 of file 9.0/sources/libs/nvdsinferserver/infer_base_backend.h.
◆ resetLayers() [1/2]
void nvdsinferserver::BaseBackend::resetLayers ( LayerDescriptionList  layers,
int  inputSize
protected
This function sets the layer description for the backend and updates the number of input layers, layer name to index map.
Parameters
[in]layersThe list of descriptions for all layers, input followed by output layers.
[in]inputSizeThe number of input layers in the list.
◆ resetLayers() [2/2]
int  inputSize
protected
Parameters
◆ setFirstDimBatch() [1/2]
void nvdsinferserver::BaseBackend::setFirstDimBatch ( bool  flag)
inline
Definition at line 64 of file sources/libs/nvdsinferserver/infer_base_backend.h.
◆ setFirstDimBatch() [2/2]
inline
Definition at line 64 of file 9.0/sources/libs/nvdsinferserver/infer_base_backend.h.
◆ setInputTensorOrder() [1/2]
void nvdsinferserver::BaseBackend::setInputTensorOrder ( InferTensorOrder  order)
inlineprotected
Definition at line 162 of file sources/libs/nvdsinferserver/infer_base_backend.h.
◆ setInputTensorOrder() [2/2]
inlineprotected
Definition at line 162 of file 9.0/sources/libs/nvdsinferserver/infer_base_backend.h.
◆ setKeepInputs() [1/2]
void nvdsinferserver::BaseBackend::setKeepInputs ( bool  enable)
inline
Definition at line 118 of file 9.0/sources/libs/nvdsinferserver/infer_base_backend.h.
◆ setKeepInputs() [2/2]
inline
Definition at line 118 of file sources/libs/nvdsinferserver/infer_base_backend.h.
◆ setMaxBatchSize() [1/2]
void nvdsinferserver::BaseBackend::setMaxBatchSize ( uint32_t  size)
inlineprotected
Definition at line 174 of file 9.0/sources/libs/nvdsinferserver/infer_base_backend.h.
◆ setMaxBatchSize() [2/2]
inlineprotected
Definition at line 174 of file sources/libs/nvdsinferserver/infer_base_backend.h.
◆ setUniqueId() [1/2]
void nvdsinferserver::BaseBackend::setUniqueId ( uint32_t  id)
inline
Definition at line 54 of file sources/libs/nvdsinferserver/infer_base_backend.h.
◆ setUniqueId() [2/2]
inline
Definition at line 54 of file 9.0/sources/libs/nvdsinferserver/infer_base_backend.h.
◆ specifyInputDims() [1/2]
virtual NvDsInferStatus nvdsinferserver::IBackend::specifyInputDims ( const InputShapes shapes)
Parameters
shapesList of name and shapes of the input layers.
Returns
Status code of the type NvDsInferStatus.
Implemented in nvdsinferserver::TrtISBackend, nvdsinferserver::TrtISBackend, nvdsinferserver::TritonSimpleRuntime, and nvdsinferserver::TritonSimpleRuntime.
◆ specifyInputDims() [2/2]
Parameters
Returns
◆ uniqueId() [1/2]
int nvdsinferserver::BaseBackend::uniqueId ( ) const
inline
Definition at line 59 of file 9.0/sources/libs/nvdsinferserver/infer_base_backend.h.
◆ uniqueId() [2/2]
inline
Definition at line 59 of file sources/libs/nvdsinferserver/infer_base_backend.h.
