sources/libs/nvdsinferserver/infer_surface_bufs.h File Reference
Data Structures
class  nvdsinferserver::ImageAlignBuffer
class  nvdsinferserver::SurfaceBuffer
class  nvdsinferserver::BatchSurfaceBuffer
Namespaces
 nvdsinferserver
Typedefs
using nvdsinferserver::UniqSurfaceBuf = std::unique_ptr< SurfaceBuffer >
using nvdsinferserver::SharedBatchSurface = std::shared_ptr< BatchSurfaceBuffer >
Functions
SharedBufPool< UniqSurfaceBuf > nvdsinferserver::createSurfaceBufPool (int width, int height, InferMediaFormat color, int batchSize, int gpuId, int poolSize)
