8.0 Release
nvdsinferserver::SurfaceBuffer Class Reference
Inheritance diagram for nvdsinferserver::SurfaceBuffer:
Collaboration diagram for nvdsinferserver::SurfaceBuffer:
Public Member Functions
 ~SurfaceBuffer () override
void * getBufPtr (uint32_t batchIdx) const override
size_t getBufOffset (uint32_t batchIdx) const override
 Get the offset from start of the memory allocation to the buffer pointer. More...
uint32_t getReservedSize ()
NvBufSurfacegetBufSurface ()
InferMediaFormat getColorFormat () const override
const BatchSurfaceInfogetSurfaceAlignInfo () const override
void reuse ()
void reuse ()
const InferBufferDescriptiongetBufDesc () const final
uint32_t getBatchSize () const final
uint64_t getTotalBytes () const override
void setBufDesc (const InferBufferDescription &desc)
InferBufferDescriptionmutableBufDesc ()
virtual void setBatchSize (uint32_t size)
const SharedCuEventcuEvent () const
void setCuEvent (SharedCuEvent e)
void setSyncObj (NvBufSurfTransformSyncObj_t SyncObj)
NvBufSurfTransformSyncObj_tgetSyncObj ()
void waitForSyncObj ()
void attach (SharedBatchBuf buf)
void detach ()
void detach ()
bool hasAttachedBufs () const
const std::vector< SharedBatchBuf > & attachedBufs () const
std::vector< SharedBatchBuf > & mutableAttachedBufs ()
bool hasAttachLoop () const
void setBufId (uint64_t id)
uint64_t bufId () const
Protected Member Functions
 SurfaceBuffer (int batchSize)
bool init (int width, int height, InferMediaFormat format, int gpuId)
Friends
UniqSurfaceBuf createNvBufSurface (int width, int height, InferMediaFormat format, int batchSize, int gpuId)
◆ SurfaceBuffer() [1/2]
nvdsinferserver::SurfaceBuffer::SurfaceBuffer ( int  batchSize)
explicitprotected
◆ ~SurfaceBuffer() [1/2]
nvdsinferserver::SurfaceBuffer::~SurfaceBuffer ( )
override
◆ SurfaceBuffer() [2/2]
explicitprotected
◆ ~SurfaceBuffer() [2/2]
override
Member Function Documentation
◆ attach() [1/2]
void nvdsinferserver::BaseBatchBuffer::attach ( SharedBatchBuf  buf)
inlineinherited
◆ attach() [2/2]
inlineinherited
◆ attachedBufs() [1/2]
const std::vector<SharedBatchBuf>& nvdsinferserver::BaseBatchBuffer::attachedBufs ( ) const
inlineinherited
◆ attachedBufs() [2/2]
inlineinherited
◆ bufId() [1/2]
uint64_t nvdsinferserver::BaseBatchBuffer::bufId ( ) const
inlineinherited
◆ bufId() [2/2]
inlineinherited
◆ cuEvent() [1/2]
const SharedCuEvent& nvdsinferserver::BaseBatchBuffer::cuEvent ( ) const
inlineinherited
◆ cuEvent() [2/2]
inlineinherited
◆ detach() [1/2]
void nvdsinferserver::BaseBatchBuffer::detach ( )
inlineinherited
◆ detach() [2/2]
inlineinherited
◆ getBatchSize() [1/2]
uint32_t nvdsinferserver::BaseBatchBuffer::getBatchSize ( ) const
inlinefinalvirtualinherited
◆ getBatchSize() [2/2]
◆ getBufDesc() [1/2]
const InferBufferDescription& nvdsinferserver::BaseBatchBuffer::getBufDesc ( ) const
◆ getBufDesc() [2/2]
◆ getBufOffset() [1/2]
size_t nvdsinferserver::SurfaceBuffer::getBufOffset ( uint32_t  batchIdx) const
inlineoverridevirtual
Needed for sharing CUDA memory with Triton server.
Reimplemented from nvdsinferserver::BaseBatchBuffer.
Definition at line 73 of file sources/libs/nvdsinferserver/infer_surface_bufs.h.
References nvdsinferserver::BaseBatchBuffer::getBatchSize(), and NvBufSurface::isContiguous.
◆ getBufOffset() [2/2]
Definition at line 73 of file 9.0/sources/libs/nvdsinferserver/infer_surface_bufs.h.
◆ getBufPtr() [1/2]
void* nvdsinferserver::SurfaceBuffer::getBufPtr ( uint32_t  batchIdx) const
◆ getBufPtr() [2/2]
◆ getBufSurface() [1/2]
NvBufSurface* nvdsinferserver::SurfaceBuffer::getBufSurface ( )
inline
◆ getBufSurface() [2/2]
inline
◆ getColorFormat() [1/2]
InferMediaFormat nvdsinferserver::SurfaceBuffer::getColorFormat ( ) const
◆ getColorFormat() [2/2]
◆ getReservedSize() [1/2]
uint32_t nvdsinferserver::SurfaceBuffer::getReservedSize ( )
inline
◆ getReservedSize() [2/2]
inline
◆ getSurfaceAlignInfo() [1/2]
const BatchSurfaceInfo& nvdsinferserver::SurfaceBuffer::getSurfaceAlignInfo ( ) const
overridevirtual
◆ getSurfaceAlignInfo() [2/2]
overridevirtual
◆ getSyncObj() [1/2]
NvBufSurfTransformSyncObj_t& nvdsinferserver::BaseBatchBuffer::getSyncObj ( )
inlineinherited
◆ getSyncObj() [2/2]
inlineinherited
◆ getTotalBytes() [1/2]
uint64_t nvdsinferserver::BaseBatchBuffer::getTotalBytes ( ) const
inlineoverridevirtualinherited
◆ getTotalBytes() [2/2]
◆ hasAttachedBufs() [1/2]
bool nvdsinferserver::BaseBatchBuffer::hasAttachedBufs ( ) const
inlineinherited
◆ hasAttachedBufs() [2/2]
inlineinherited
◆ hasAttachLoop() [1/2]
bool nvdsinferserver::BaseBatchBuffer::hasAttachLoop ( ) const
inlineinherited
◆ hasAttachLoop() [2/2]
inlineinherited
◆ init() [1/2]
bool nvdsinferserver::SurfaceBuffer::init ( int  width,
int  height,
int  gpuId
protected
◆ init() [2/2]
int  height,
int  gpuId
protected
◆ mutableAttachedBufs() [1/2]
std::vector<SharedBatchBuf>& nvdsinferserver::BaseBatchBuffer::mutableAttachedBufs ( )
inlineinherited
◆ mutableAttachedBufs() [2/2]
inlineinherited
◆ mutableBufDesc() [1/2]
InferBufferDescription& nvdsinferserver::BaseBatchBuffer::mutableBufDesc ( )
inlineinherited
◆ mutableBufDesc() [2/2]
inlineinherited
◆ reuse() [1/2]
void nvdsinferserver::SurfaceBuffer::reuse ( )
inline
◆ reuse() [2/2]
inline
◆ setBatchSize() [1/2]
virtual void nvdsinferserver::BaseBatchBuffer::setBatchSize ( uint32_t  size)
inlinevirtualinherited
◆ setBatchSize() [2/2]
◆ setBufDesc() [1/2]
void nvdsinferserver::BaseBatchBuffer::setBufDesc ( const InferBufferDescription desc)
inlineinherited
◆ setBufDesc() [2/2]
◆ setBufId() [1/2]
void nvdsinferserver::BaseBatchBuffer::setBufId ( uint64_t  id)
inlineinherited
◆ setBufId() [2/2]
inlineinherited
◆ setCuEvent() [1/2]
void nvdsinferserver::BaseBatchBuffer::setCuEvent ( SharedCuEvent  e)
inlineinherited
◆ setCuEvent() [2/2]
inlineinherited
◆ setSyncObj() [1/2]
void nvdsinferserver::BaseBatchBuffer::setSyncObj ( NvBufSurfTransformSyncObj_t  SyncObj)
inlineinherited
◆ setSyncObj() [2/2]
inlineinherited
◆ waitForSyncObj() [1/2]
void nvdsinferserver::BaseBatchBuffer::waitForSyncObj ( )
inlineinherited
◆ waitForSyncObj() [2/2]
inlineinherited
Friends And Related Function Documentation
◆ createNvBufSurface [1/2]
UniqSurfaceBuf createNvBufSurface ( int  width,
int  height,
int  batchSize,
int  gpuId
friend
◆ createNvBufSurface [2/2]
int  height,
int  batchSize,
int  gpuId
friend
