7.1 Release
nvdsinferserver::BatchSurfaceBuffer Class Reference
Definition at line 112 of file infer_surface_bufs.h.
Inheritance diagram for nvdsinferserver::BatchSurfaceBuffer:
Collaboration diagram for nvdsinferserver::BatchSurfaceBuffer:
Public Member Functions
 BatchSurfaceBuffer (int devId, uint32_t maxBatchSize, NvBufSurfaceMemType memType)
void * getBufPtr (uint32_t batchIdx) const override
size_t getBufOffset (uint32_t batchIdx) const override
 Get the offset from start of the memory allocation to the buffer pointer. More...
void append (const NvBufSurfaceParams &params, const NvBufSurfTransformRect &crop)
NvBufSurfaceParamsgetSurfaceParams (int batchIdx)
NvBufSurfTransformRect getCropArea (int batchIdx)
NvBufSurfacegetBufSurface ()
void getScaleRatio (uint32_t batchIdx, double &ratioX, double &ratioY)
void setScaleRatio (uint32_t batchIdx, double ratioX, double ratioY)
void getOffsets (uint32_t batchIdx, uint32_t &offsetLeft, uint32_t &offsetTop)
void setOffsets (uint32_t batchIdx, uint32_t offsetLeft, uint32_t offsetTop)
const InferBufferDescriptiongetBufDesc () const final
uint32_t getBatchSize () const final
uint64_t getTotalBytes () const override
void setBufDesc (const InferBufferDescription &desc)
InferBufferDescriptionmutableBufDesc ()
virtual void setBatchSize (uint32_t size)
const SharedCuEventcuEvent () const
void setCuEvent (SharedCuEvent e)
void setSyncObj (NvBufSurfTransformSyncObj_t SyncObj)
NvBufSurfTransformSyncObj_tgetSyncObj ()
void waitForSyncObj ()
void attach (SharedBatchBuf buf)
void detach ()
bool hasAttachedBufs () const
const std::vector< SharedBatchBuf > & attachedBufs () const
std::vector< SharedBatchBuf > & mutableAttachedBufs ()
bool hasAttachLoop () const
void setBufId (uint64_t id)
uint64_t bufId () const
◆ BatchSurfaceBuffer()
nvdsinferserver::BatchSurfaceBuffer::BatchSurfaceBuffer ( int  devId,
inline
Definition at line 114 of file infer_surface_bufs.h.
References nvdsinferserver::kNvSurface, and nvdsinferserver::kUint8.
Member Function Documentation
◆ append()
void nvdsinferserver::BatchSurfaceBuffer::append ( const NvBufSurfaceParams params,
const NvBufSurfTransformRect crop
inline
Definition at line 148 of file infer_surface_bufs.h.
◆ attach()
void nvdsinferserver::BaseBatchBuffer::attach ( SharedBatchBuf  buf)
inlineinherited
Definition at line 67 of file infer_batch_buffer.h.
◆ attachedBufs()
const std::vector<SharedBatchBuf>& nvdsinferserver::BaseBatchBuffer::attachedBufs ( ) const
inlineinherited
Definition at line 74 of file infer_batch_buffer.h.
◆ bufId()
uint64_t nvdsinferserver::BaseBatchBuffer::bufId ( ) const
inlineinherited
Definition at line 93 of file infer_batch_buffer.h.
◆ cuEvent()
const SharedCuEvent& nvdsinferserver::BaseBatchBuffer::cuEvent ( ) const
inlineinherited
Definition at line 52 of file infer_batch_buffer.h.
◆ detach()
void nvdsinferserver::BaseBatchBuffer::detach ( )
inlineinherited
Definition at line 72 of file infer_batch_buffer.h.
Referenced by nvdsinferserver::CudaTensorBuf::reuse().
◆ getBatchSize()
uint32_t nvdsinferserver::BaseBatchBuffer::getBatchSize ( ) const
inlinefinalvirtualinherited
◆ getBufDesc()
const InferBufferDescription& nvdsinferserver::BaseBatchBuffer::getBufDesc ( ) const
Implements nvdsinferserver::IBatchBuffer.
Definition at line 40 of file infer_batch_buffer.h.
◆ getBufOffset()
size_t nvdsinferserver::BatchSurfaceBuffer::getBufOffset ( uint32_t  batchIdx) const
inlineoverridevirtual
Needed for sharing CUDA memory with Triton server.
Reimplemented from nvdsinferserver::BaseBatchBuffer.
Definition at line 136 of file infer_surface_bufs.h.
◆ getBufPtr()
void* nvdsinferserver::BatchSurfaceBuffer::getBufPtr ( uint32_t  batchIdx) const
Definition at line 124 of file infer_surface_bufs.h.
◆ getBufSurface()
NvBufSurface* nvdsinferserver::BatchSurfaceBuffer::getBufSurface ( )
inline
Definition at line 167 of file infer_surface_bufs.h.
◆ getCropArea()
NvBufSurfTransformRect nvdsinferserver::BatchSurfaceBuffer::getCropArea ( int  batchIdx)
inline
Definition at line 163 of file infer_surface_bufs.h.
◆ getOffsets()
void nvdsinferserver::BatchSurfaceBuffer::getOffsets ( uint32_t  batchIdx,
uint32_t &  offsetLeft,
uint32_t &  offsetTop
inline
Definition at line 179 of file infer_surface_bufs.h.
◆ getScaleRatio()
void nvdsinferserver::BatchSurfaceBuffer::getScaleRatio ( uint32_t  batchIdx,
double &  ratioX,
double &  ratioY
inline
Definition at line 169 of file infer_surface_bufs.h.
◆ getSurfaceParams()
NvBufSurfaceParams& nvdsinferserver::BatchSurfaceBuffer::getSurfaceParams ( int  batchIdx)
inline
Definition at line 159 of file infer_surface_bufs.h.
◆ getSyncObj()
NvBufSurfTransformSyncObj_t& nvdsinferserver::BaseBatchBuffer::getSyncObj ( )
inlineinherited
Definition at line 55 of file infer_batch_buffer.h.
◆ getTotalBytes()
uint64_t nvdsinferserver::BaseBatchBuffer::getTotalBytes ( ) const
inlineoverridevirtualinherited
Reimplemented in nvdsinferserver::RefBatchBuffer.
Definition at line 42 of file infer_batch_buffer.h.
References nvdsinferserver::kNone.
◆ hasAttachedBufs()
bool nvdsinferserver::BaseBatchBuffer::hasAttachedBufs ( ) const
inlineinherited
Definition at line 73 of file infer_batch_buffer.h.
◆ hasAttachLoop()
bool nvdsinferserver::BaseBatchBuffer::hasAttachLoop ( ) const
inlineinherited
Definition at line 79 of file infer_batch_buffer.h.
◆ mutableAttachedBufs()
std::vector<SharedBatchBuf>& nvdsinferserver::BaseBatchBuffer::mutableAttachedBufs ( )
inlineinherited
Definition at line 78 of file infer_batch_buffer.h.
◆ mutableBufDesc()
InferBufferDescription& nvdsinferserver::BaseBatchBuffer::mutableBufDesc ( )
inlineinherited
Definition at line 50 of file infer_batch_buffer.h.
Referenced by nvdsinferserver::CudaTensorBuf::setName().
◆ setBatchSize()
virtual void nvdsinferserver::BaseBatchBuffer::setBatchSize ( uint32_t  size)
inlinevirtualinherited
◆ setBufDesc()
◆ setBufId()
void nvdsinferserver::BaseBatchBuffer::setBufId ( uint64_t  id)
inlineinherited
Definition at line 92 of file infer_batch_buffer.h.
◆ setCuEvent()
void nvdsinferserver::BaseBatchBuffer::setCuEvent ( SharedCuEvent  e)
inlineinherited
Definition at line 53 of file infer_batch_buffer.h.
◆ setOffsets()
void nvdsinferserver::BatchSurfaceBuffer::setOffsets ( uint32_t  batchIdx,
uint32_t  offsetTop
inline
Definition at line 185 of file infer_surface_bufs.h.
◆ setScaleRatio()
void nvdsinferserver::BatchSurfaceBuffer::setScaleRatio ( uint32_t  batchIdx,
double  ratioX,
double  ratioY
inline
Definition at line 174 of file infer_surface_bufs.h.
◆ setSyncObj()
void nvdsinferserver::BaseBatchBuffer::setSyncObj ( NvBufSurfTransformSyncObj_t  SyncObj)
inlineinherited
Definition at line 54 of file infer_batch_buffer.h.
◆ waitForSyncObj()
void nvdsinferserver::BaseBatchBuffer::waitForSyncObj ( )
inlineinherited
