7.1 Release
nvdsinferserver::ImageAlignBuffer Class Referenceabstract
Definition at line 46 of file infer_surface_bufs.h.
Inheritance diagram for nvdsinferserver::ImageAlignBuffer:
Collaboration diagram for nvdsinferserver::ImageAlignBuffer:
Public Member Functions
 ImageAlignBuffer (int batchSize)
virtual InferMediaFormat getColorFormat () const =0
virtual const BatchSurfaceInfogetSurfaceAlignInfo () const =0
const InferBufferDescriptiongetBufDesc () const final
uint32_t getBatchSize () const final
uint64_t getTotalBytes () const override
void setBufDesc (const InferBufferDescription &desc)
InferBufferDescriptionmutableBufDesc ()
virtual void setBatchSize (uint32_t size)
const SharedCuEventcuEvent () const
void setCuEvent (SharedCuEvent e)
void setSyncObj (NvBufSurfTransformSyncObj_t SyncObj)
NvBufSurfTransformSyncObj_tgetSyncObj ()
void waitForSyncObj ()
void attach (SharedBatchBuf buf)
void detach ()
bool hasAttachedBufs () const
const std::vector< SharedBatchBuf > & attachedBufs () const
std::vector< SharedBatchBuf > & mutableAttachedBufs ()
bool hasAttachLoop () const
void setBufId (uint64_t id)
uint64_t bufId () const
size_t getBufOffset (uint32_t batchIdx) const override
 Get the offset from start of the memory allocation to the buffer pointer. More...
virtual void * getBufPtr (uint32_t batchIdx) const =0
◆ ImageAlignBuffer()
nvdsinferserver::ImageAlignBuffer::ImageAlignBuffer ( int  batchSize)
inline
Definition at line 48 of file infer_surface_bufs.h.
Member Function Documentation
◆ attach()
void nvdsinferserver::BaseBatchBuffer::attach ( SharedBatchBuf  buf)
inlineinherited
Definition at line 67 of file infer_batch_buffer.h.
◆ attachedBufs()
const std::vector<SharedBatchBuf>& nvdsinferserver::BaseBatchBuffer::attachedBufs ( ) const
inlineinherited
Definition at line 74 of file infer_batch_buffer.h.
◆ bufId()
uint64_t nvdsinferserver::BaseBatchBuffer::bufId ( ) const
inlineinherited
Definition at line 93 of file infer_batch_buffer.h.
◆ cuEvent()
const SharedCuEvent& nvdsinferserver::BaseBatchBuffer::cuEvent ( ) const
inlineinherited
Definition at line 52 of file infer_batch_buffer.h.
◆ detach()
void nvdsinferserver::BaseBatchBuffer::detach ( )
inlineinherited
Definition at line 72 of file infer_batch_buffer.h.
Referenced by nvdsinferserver::CudaTensorBuf::reuse().
◆ getBatchSize()
uint32_t nvdsinferserver::BaseBatchBuffer::getBatchSize ( ) const
inlinefinalvirtualinherited
◆ getBufDesc()
const InferBufferDescription& nvdsinferserver::BaseBatchBuffer::getBufDesc ( ) const
Implements nvdsinferserver::IBatchBuffer.
Definition at line 40 of file infer_batch_buffer.h.
◆ getBufOffset()
size_t nvdsinferserver::BaseBatchBuffer::getBufOffset ( uint32_t  batchIdx) const
inlineoverridevirtualinherited
Needed for sharing CUDA memory with Triton server.
Reimplemented in nvdsinferserver::RefBatchBuffer, nvdsinferserver::BatchSurfaceBuffer, and nvdsinferserver::SurfaceBuffer.
Definition at line 100 of file infer_batch_buffer.h.
◆ getBufPtr()
◆ getColorFormat()
virtual InferMediaFormat nvdsinferserver::ImageAlignBuffer::getColorFormat ( ) const
pure virtual
◆ getSurfaceAlignInfo()
virtual const BatchSurfaceInfo& nvdsinferserver::ImageAlignBuffer::getSurfaceAlignInfo ( ) const
pure virtual
◆ getSyncObj()
NvBufSurfTransformSyncObj_t& nvdsinferserver::BaseBatchBuffer::getSyncObj ( )
inlineinherited
Definition at line 55 of file infer_batch_buffer.h.
◆ getTotalBytes()
uint64_t nvdsinferserver::BaseBatchBuffer::getTotalBytes ( ) const
Reimplemented in nvdsinferserver::RefBatchBuffer.
Definition at line 42 of file infer_batch_buffer.h.
References nvdsinferserver::kNone.
◆ hasAttachedBufs()
bool nvdsinferserver::BaseBatchBuffer::hasAttachedBufs ( ) const
inlineinherited
Definition at line 73 of file infer_batch_buffer.h.
◆ hasAttachLoop()
bool nvdsinferserver::BaseBatchBuffer::hasAttachLoop ( ) const
inlineinherited
Definition at line 79 of file infer_batch_buffer.h.
◆ mutableAttachedBufs()
std::vector<SharedBatchBuf>& nvdsinferserver::BaseBatchBuffer::mutableAttachedBufs ( )
inlineinherited
Definition at line 78 of file infer_batch_buffer.h.
◆ mutableBufDesc()
InferBufferDescription& nvdsinferserver::BaseBatchBuffer::mutableBufDesc ( )
inlineinherited
Definition at line 50 of file infer_batch_buffer.h.
Referenced by nvdsinferserver::CudaTensorBuf::setName().
◆ setBatchSize()
virtual void nvdsinferserver::BaseBatchBuffer::setBatchSize ( uint32_t  size)
inlinevirtualinherited
◆ setBufDesc()
◆ setBufId()
void nvdsinferserver::BaseBatchBuffer::setBufId ( uint64_t  id)
inlineinherited
Definition at line 92 of file infer_batch_buffer.h.
◆ setCuEvent()
void nvdsinferserver::BaseBatchBuffer::setCuEvent ( SharedCuEvent  e)
inlineinherited
Definition at line 53 of file infer_batch_buffer.h.
◆ setSyncObj()
void nvdsinferserver::BaseBatchBuffer::setSyncObj ( NvBufSurfTransformSyncObj_t  SyncObj)
inlineinherited
Definition at line 54 of file infer_batch_buffer.h.
◆ waitForSyncObj()
void nvdsinferserver::BaseBatchBuffer::waitForSyncObj ( )
inlineinherited
