GstNvDsPreProcessGroup Struct Reference
Collaboration diagram for GstNvDsPreProcessGroup:
Data Fields
std::vector< gint > src_ids
 vector of src_ids More...
std::vector< gint > operate_on_class_ids
 vector of operate_on_class_ids for sgie More...
guint num_units
 total rois/full-frames in a group More...
std::string custom_transform_function_name
 custom transformation function name More...
std::function< NvDsPreProcessStatus(NvBufSurface *, NvBufSurface *, CustomTransformParams &)> custom_transform
 wrapper to custom transformation function More...
NvBufSurfTransformSyncObj_t sync_obj = NULL
 sync object for async transformation More...
std::unordered_map< gint, GstNvDsPreProcessFrameframemeta_map
 Map src_id - Preprocess Frame meta. More...
gboolean process_on_roi = 0
 boolean indicating if processing on rois/full-frames inside the group More...
gboolean process_on_all_objects = 0
 boolean indicating if secondary classification is done on all detections/roi inside the group More...
gboolean draw_roi = 0
 boolean indicating that the roi is to be drawn or not More...
NvOSD_ColorParams roi_color
 color of roi More...
guint min_input_object_width
 Input object size-based filtering parameters for object processing mode. More...
guint min_input_object_height
guint max_input_object_width
guint max_input_object_height
guint replicated_src_id
 src-id whose rois is used by all the src within the preprocess-group (when src-ids[0]=-1) More...
guint interval = 0
 Group interval for frame/roi processing. More...
guint interval_counter = 0
Field Documentation
◆ custom_transform
std::function< NvDsPreProcessStatus(NvBufSurface *, NvBufSurface *, CustomTransformParams &)> GstNvDsPreProcessGroup::custom_transform
Definition at line 82 of file sources/gst-plugins/gst-nvdspreprocess/gstnvdspreprocess.h.
◆ custom_transform_function_name
std::string GstNvDsPreProcessGroup::custom_transform_function_name
Definition at line 78 of file sources/gst-plugins/gst-nvdspreprocess/gstnvdspreprocess.h.
◆ draw_roi
gboolean GstNvDsPreProcessGroup::draw_roi = 0
Definition at line 97 of file sources/gst-plugins/gst-nvdspreprocess/gstnvdspreprocess.h.
◆ framemeta_map
std::unordered_map< gint, GstNvDsPreProcessFrame > GstNvDsPreProcessGroup::framemeta_map
Definition at line 88 of file sources/gst-plugins/gst-nvdspreprocess/gstnvdspreprocess.h.
◆ interval
guint GstNvDsPreProcessGroup::interval = 0
Definition at line 112 of file sources/gst-plugins/gst-nvdspreprocess/gstnvdspreprocess.h.
◆ interval_counter
guint GstNvDsPreProcessGroup::interval_counter = 0
◆ max_input_object_height
guint GstNvDsPreProcessGroup::max_input_object_height
◆ max_input_object_width
guint GstNvDsPreProcessGroup::max_input_object_width
◆ min_input_object_height
guint GstNvDsPreProcessGroup::min_input_object_height
◆ min_input_object_width
guint GstNvDsPreProcessGroup::min_input_object_width
Definition at line 103 of file sources/gst-plugins/gst-nvdspreprocess/gstnvdspreprocess.h.
◆ num_units
guint GstNvDsPreProcessGroup::num_units
Definition at line 75 of file sources/gst-plugins/gst-nvdspreprocess/gstnvdspreprocess.h.
◆ operate_on_class_ids
std::vector< gint > GstNvDsPreProcessGroup::operate_on_class_ids
Definition at line 72 of file sources/gst-plugins/gst-nvdspreprocess/gstnvdspreprocess.h.
◆ process_on_all_objects
gboolean GstNvDsPreProcessGroup::process_on_all_objects = 0
Definition at line 94 of file sources/gst-plugins/gst-nvdspreprocess/gstnvdspreprocess.h.
◆ process_on_roi
gboolean GstNvDsPreProcessGroup::process_on_roi = 0
Definition at line 91 of file sources/gst-plugins/gst-nvdspreprocess/gstnvdspreprocess.h.
◆ replicated_src_id
guint GstNvDsPreProcessGroup::replicated_src_id
Definition at line 109 of file sources/gst-plugins/gst-nvdspreprocess/gstnvdspreprocess.h.
◆ roi_color
NvOSD_ColorParams GstNvDsPreProcessGroup::roi_color
color of roi
Definition at line 100 of file sources/gst-plugins/gst-nvdspreprocess/gstnvdspreprocess.h.
◆ src_ids
std::vector< gint > GstNvDsPreProcessGroup::src_ids
vector of src_ids
Definition at line 69 of file sources/gst-plugins/gst-nvdspreprocess/gstnvdspreprocess.h.
◆ sync_obj
NvBufSurfTransformSyncObj_t GstNvDsPreProcessGroup::sync_obj = NULL
Definition at line 85 of file sources/gst-plugins/gst-nvdspreprocess/gstnvdspreprocess.h.
