_NvBufSurfTransformConfigParams Struct Reference
Holds configuration parameters for a transform/composite session.
Definition at line 175 of file sources/includes/nvbufsurftransform.h.
Data Fields
NvBufSurfTransform_Compute compute_mode
 Holds the mode of operation: VIC (Jetson) or GPU (iGPU + dGPU) If VIC is configured, gpu_id is ignored. More...
int32_t gpu_id
 Holds the GPU ID to be used for processing. More...
cudaStream_t cuda_stream
 User configure stream to be used. More...
void * reserved [STRUCTURE_PADDING]
 Reserved fields for future expansion. More...
Field Documentation
◆ compute_mode
NvBufSurfTransform_Compute _NvBufSurfTransformConfigParams::compute_mode
Definition at line 179 of file sources/includes/nvbufsurftransform.h.
◆ cuda_stream
cudaStream_t _NvBufSurfTransformConfigParams::cuda_stream
If NULL, the default stream is used. Ignored if VIC is used.
Definition at line 186 of file sources/includes/nvbufsurftransform.h.
◆ gpu_id
int32_t _NvBufSurfTransformConfigParams::gpu_id
Definition at line 182 of file sources/includes/nvbufsurftransform.h.
◆ reserved
void * _NvBufSurfTransformConfigParams::reserved
Definition at line 189 of file sources/includes/nvbufsurftransform.h.
