nvdsinferserver::CudaTensorBuf Class Reference
A batch buffer with CUDA memory allocation.
Definition at line 168 of file sources/libs/nvdsinferserver/infer_cuda_utils.h.
Inheritance diagram for nvdsinferserver::CudaTensorBuf:
Collaboration diagram for nvdsinferserver::CudaTensorBuf:
Public Member Functions
 CudaTensorBuf (const InferDims &dims, InferDataType dt, int batchSize, const std::string &name, InferMemType mt, int devId, bool initCuEvent)
 ~CudaTensorBuf () override
void setBatchSize (uint32_t size) override
void setName (const std::string &name)
void * getBufPtr (uint32_t batchIdx) const final
void reuse ()
void reuse ()
const InferBufferDescriptiongetBufDesc () const final
uint32_t getBatchSize () const final
uint64_t getTotalBytes () const override
void setBufDesc (const InferBufferDescription &desc)
InferBufferDescriptionmutableBufDesc ()
const SharedCuEventcuEvent () const
void setCuEvent (SharedCuEvent e)
void setSyncObj (NvBufSurfTransformSyncObj_t SyncObj)
NvBufSurfTransformSyncObj_tgetSyncObj ()
void waitForSyncObj ()
void attach (SharedBatchBuf buf)
void detach ()
void detach ()
bool hasAttachedBufs () const
const std::vector< SharedBatchBuf > & attachedBufs () const
std::vector< SharedBatchBuf > & mutableAttachedBufs ()
bool hasAttachLoop () const
void setBufId (uint64_t id)
uint64_t bufId () const
size_t getBufOffset (uint32_t batchIdx) const override
 Get the offset from start of the memory allocation to the buffer pointer. More...
◆ CudaTensorBuf() [1/2]
nvdsinferserver::CudaTensorBuf::CudaTensorBuf ( const InferDims dims,
InferDataType  dt,
int  batchSize,
const std::string &  name,
InferMemType  mt,
int  devId,
bool  initCuEvent
◆ ~CudaTensorBuf() [1/2]
nvdsinferserver::CudaTensorBuf::~CudaTensorBuf ( )
override
◆ CudaTensorBuf() [2/2]
InferDataType  dt,
int  batchSize,
InferMemType  mt,
int  devId,
bool  initCuEvent
◆ ~CudaTensorBuf() [2/2]
override
Member Function Documentation
◆ attach() [1/2]
void nvdsinferserver::BaseBatchBuffer::attach ( SharedBatchBuf  buf)
inlineinherited
◆ attach() [2/2]
inlineinherited
◆ attachedBufs() [1/2]
const std::vector<SharedBatchBuf>& nvdsinferserver::BaseBatchBuffer::attachedBufs ( ) const
inlineinherited
◆ attachedBufs() [2/2]
inlineinherited
◆ bufId() [1/2]
uint64_t nvdsinferserver::BaseBatchBuffer::bufId ( ) const
inlineinherited
◆ bufId() [2/2]
inlineinherited
◆ cuEvent() [1/2]
const SharedCuEvent& nvdsinferserver::BaseBatchBuffer::cuEvent ( ) const
inlineinherited
◆ cuEvent() [2/2]
inlineinherited
◆ detach() [1/2]
void nvdsinferserver::BaseBatchBuffer::detach ( )
inlineinherited
◆ detach() [2/2]
inlineinherited
Definition at line 72 of file sources/libs/nvdsinferserver/infer_batch_buffer.h.
Referenced by reuse().
◆ getBatchSize() [1/2]
uint32_t nvdsinferserver::BaseBatchBuffer::getBatchSize ( ) const
inlinefinalvirtualinherited
◆ getBatchSize() [2/2]
◆ getBufDesc() [1/2]
const InferBufferDescription& nvdsinferserver::BaseBatchBuffer::getBufDesc ( ) const
◆ getBufDesc() [2/2]
◆ getBufOffset() [1/2]
size_t nvdsinferserver::BaseBatchBuffer::getBufOffset ( uint32_t  batchIdx) const
inlineoverridevirtualinherited
Needed for sharing CUDA memory with Triton server.
Implements nvdsinferserver::IBatchBuffer.
Reimplemented in nvdsinferserver::RefBatchBuffer, nvdsinferserver::RefBatchBuffer, nvdsinferserver::BatchSurfaceBuffer, nvdsinferserver::BatchSurfaceBuffer, nvdsinferserver::SurfaceBuffer, and nvdsinferserver::SurfaceBuffer.
Definition at line 100 of file sources/libs/nvdsinferserver/infer_batch_buffer.h.
◆ getBufOffset() [2/2]
Reimplemented in nvdsinferserver::RefBatchBuffer, nvdsinferserver::BatchSurfaceBuffer, and nvdsinferserver::SurfaceBuffer.
Definition at line 100 of file 9.0/sources/libs/nvdsinferserver/infer_batch_buffer.h.
◆ getBufPtr() [1/2]
void* nvdsinferserver::CudaTensorBuf::getBufPtr ( uint32_t  batchIdx) const
finalvirtual
◆ getBufPtr() [2/2]
finalvirtual
◆ getSyncObj() [1/2]
NvBufSurfTransformSyncObj_t& nvdsinferserver::BaseBatchBuffer::getSyncObj ( )
inlineinherited
◆ getSyncObj() [2/2]
inlineinherited
◆ getTotalBytes() [1/2]
uint64_t nvdsinferserver::BaseBatchBuffer::getTotalBytes ( ) const
◆ getTotalBytes() [2/2]
◆ hasAttachedBufs() [1/2]
bool nvdsinferserver::BaseBatchBuffer::hasAttachedBufs ( ) const
inlineinherited
◆ hasAttachedBufs() [2/2]
inlineinherited
◆ hasAttachLoop() [1/2]
bool nvdsinferserver::BaseBatchBuffer::hasAttachLoop ( ) const
inlineinherited
◆ hasAttachLoop() [2/2]
inlineinherited
◆ mutableAttachedBufs() [1/2]
std::vector<SharedBatchBuf>& nvdsinferserver::BaseBatchBuffer::mutableAttachedBufs ( )
inlineinherited
◆ mutableAttachedBufs() [2/2]
inlineinherited
◆ mutableBufDesc() [1/2]
InferBufferDescription& nvdsinferserver::BaseBatchBuffer::mutableBufDesc ( )
inlineinherited
Definition at line 50 of file sources/libs/nvdsinferserver/infer_batch_buffer.h.
Referenced by setName().
◆ mutableBufDesc() [2/2]
inlineinherited
◆ reuse() [1/2]
void nvdsinferserver::CudaTensorBuf::reuse ( )
inline
◆ reuse() [2/2]
inline
◆ setBatchSize() [1/2]
void nvdsinferserver::CudaTensorBuf::setBatchSize ( uint32_t  size)
◆ setBatchSize() [2/2]
◆ setBufDesc() [1/2]
void nvdsinferserver::BaseBatchBuffer::setBufDesc ( const InferBufferDescription desc)
inlineinherited
◆ setBufDesc() [2/2]
◆ setBufId() [1/2]
void nvdsinferserver::BaseBatchBuffer::setBufId ( uint64_t  id)
inlineinherited
◆ setBufId() [2/2]
inlineinherited
◆ setCuEvent() [1/2]
void nvdsinferserver::BaseBatchBuffer::setCuEvent ( SharedCuEvent  e)
inlineinherited
◆ setCuEvent() [2/2]
inlineinherited
◆ setName() [1/2]
void nvdsinferserver::CudaTensorBuf::setName ( const std::string &  name)
inline
◆ setName() [2/2]
inline
◆ setSyncObj() [1/2]
void nvdsinferserver::BaseBatchBuffer::setSyncObj ( NvBufSurfTransformSyncObj_t  SyncObj)
inlineinherited
◆ setSyncObj() [2/2]
inlineinherited
◆ waitForSyncObj() [1/2]
void nvdsinferserver::BaseBatchBuffer::waitForSyncObj ( )
inlineinherited
◆ waitForSyncObj() [2/2]
inlineinherited
