7.1 Release
nvdsinferserver::triton::RepoSettings Struct Reference
Model repository settings for the Triton Inference Server.
Definition at line 453 of file infer_trtis_server.h.
Public Member Functions
bool initFrom (const ic::TritonModelRepo &repo, const std::vector< int > &devIds)
 Populate the RepoSettings instance with the values from the TritonModelRepo protobuf message. More...
bool operator== (const RepoSettings &other) const
 Comparison operators. More...
bool operator!= (const RepoSettings &other) const
Data Fields
std::set< std::string > roots
 Set of model repository directories. More...
uint32_t logLevel = 0
 Level of the Triton log output. More...
bool tfAllowSoftPlacement = true
 Flag to enable/disable soft placement of TF operators. More...
float tfGpuMemoryFraction = 0
 TensorFlow GPU memory fraction per process. More...
bool strictModelConfig = true
 Flag to enable/disable Triton strict model configuration. More...
double minComputeCapacity = TRITON_DEFAULT_MINIMUM_COMPUTE_CAPABILITY
 The minimun supported compute compability for Triton server. More...
uint64_t pinnedMemBytes = TRITON_DEFAULT_PINNED_MEMORY_BYTES
 Pre-allocated pinned memory on host for Triton runtime. More...
std::string backendDirectory {TRITON_DEFAULT_BACKEND_DIR}
 The path to the Triton backends directory. More...
int32_t controlMode = (int32_t)TRITONSERVER_MODEL_CONTROL_EXPLICIT
 Triton model control mode. More...
std::map< uint32_t, uint64_t > cudaDevMemMap
 Map of the device IDs and corresponding size of CUDA memory pool to be allocated. More...
std::vector< BackendConfigbackendConfigs
 Array of backend configurations settings. More...
std::string debugStr
 Debug string of the TritonModelRepo protobuf message. More...
Member Function Documentation
◆ initFrom()
bool nvdsinferserver::triton::RepoSettings::initFrom ( const ic::TritonModelRepo &  repo,
const std::vector< int > &  devIds
Parameters
[in]repoThe model repository configuration proto message.
[in]devIdsNot used.
Returns
Success or failure status.
◆ operator!=()
bool nvdsinferserver::triton::RepoSettings::operator!= ( const RepoSettings other) const
inline
Definition at line 522 of file infer_trtis_server.h.
References operator==().
◆ operator==()
bool nvdsinferserver::triton::RepoSettings::operator== ( const RepoSettings other) const
Check that the two repository settings are same/different. Different control modes are reported as warning. CudaDeviceMem is not checked.
Referenced by operator!=().
Field Documentation
◆ backendConfigs
std::vector<BackendConfig> nvdsinferserver::triton::RepoSettings::backendConfigs
Definition at line 498 of file infer_trtis_server.h.
◆ backendDirectory
std::string nvdsinferserver::triton::RepoSettings::backendDirectory {TRITON_DEFAULT_BACKEND_DIR}
Definition at line 485 of file infer_trtis_server.h.
◆ controlMode
int32_t nvdsinferserver::triton::RepoSettings::controlMode = (int32_t)TRITONSERVER_MODEL_CONTROL_EXPLICIT
Definition at line 489 of file infer_trtis_server.h.
◆ cudaDevMemMap
std::map<uint32_t, uint64_t> nvdsinferserver::triton::RepoSettings::cudaDevMemMap
Definition at line 494 of file infer_trtis_server.h.
◆ debugStr
std::string nvdsinferserver::triton::RepoSettings::debugStr
Definition at line 503 of file infer_trtis_server.h.
◆ logLevel
uint32_t nvdsinferserver::triton::RepoSettings::logLevel = 0
Definition at line 461 of file infer_trtis_server.h.
◆ minComputeCapacity
double nvdsinferserver::triton::RepoSettings::minComputeCapacity = TRITON_DEFAULT_MINIMUM_COMPUTE_CAPABILITY
Definition at line 477 of file infer_trtis_server.h.
◆ pinnedMemBytes
uint64_t nvdsinferserver::triton::RepoSettings::pinnedMemBytes = TRITON_DEFAULT_PINNED_MEMORY_BYTES
Definition at line 481 of file infer_trtis_server.h.
◆ roots
std::set<std::string> nvdsinferserver::triton::RepoSettings::roots
Definition at line 457 of file infer_trtis_server.h.
◆ strictModelConfig
bool nvdsinferserver::triton::RepoSettings::strictModelConfig = true
Definition at line 473 of file infer_trtis_server.h.
◆ tfAllowSoftPlacement
bool nvdsinferserver::triton::RepoSettings::tfAllowSoftPlacement = true
Definition at line 465 of file infer_trtis_server.h.
◆ tfGpuMemoryFraction
float nvdsinferserver::triton::RepoSettings::tfGpuMemoryFraction = 0
Definition at line 469 of file infer_trtis_server.h.
