deepstream::SourceManager Class Reference
Definition at line 46 of file service-maker/includes/source_manager.hpp.
Inheritance diagram for deepstream::SourceManager:
Collaboration diagram for deepstream::SourceManager:
Public Member Functions
 SourceManager (const std::string &name)
 Constructor. More...
int addSource (const std::string &source_name)
 Add a source to the manager. More...
void removeSource (int source_id)
 Remove a source from the manager. More...
void terminate ()
 Terminate the pipeline. More...
void terminate ()
SignalEmitterattach (const std::string &action_name, Object &object)
 Attach the signal emitter to an object on specified action. More...
SignalEmitteremit (const std::string &action_name, const std::string &object_name,...)
 Emit the action by name. More...
const std::string getName () const
 Return the name assigned during the construction. More...
 operator bool () const noexcept
 Check if the object is void. More...
bool operator== (const Object &other) noexcept
 Check if the two objects are the same. More...
GstObjectgive ()
 Give up the ownership and return the opaque pointer. More...
GstObjectgive ()
GstObjectgetGObject ()
 Return the opaque object pointer. More...
Objecttake (GstObject *object)
 Takes the ownership of a object through the opaque pointer. More...
Objectseize (GstObject *object)
 Seize a opaque object to prevent it from being destroyed somewhere. More...
Objectset (const YAML::Node &params)
 Set the properties from key/value pairs in the yaml format. More...
Objectset (const std::string &name, const Value &value)
template<typename T , typename... Args>
Objectset (const std::string &name, const T &value, const Args &... args)
ObjectgetProperty (const std::string &name, T &value, Args &... args)
 Template for getting multiple properties. More...
std::vector< std::string > listSignals (bool is_action)
 List all the supported signals from the object. More...
bool connectSignal (const std::string &signal_name, SignalHandler &handler)
 Connect a signal handler to the object. More...
void emitSignal (const std::string &signal_name, va_list args)
 Emit a signal. More...
static unsigned long type ()
 Return the type id assigned to signal emitter. More...
Protected Member Functions
virtual void set_ (const std::string &name, const Value &value)
virtual void set_ (const std::string &name, const YAML::Node &value)
virtual Value get_ (const std::string &name)
Protected Attributes
std::multimap< std::string, Objectobject_map_
std::unique_ptr< IActionOwnerowner_
std::string param_spec_
 property spec in YAML format More...
std::map< std::string, Object::Valueproperties_
 property map More...
GstObjectobject_
Static Protected Attributes
static int gen_number_
static std::mutex gen_number_mutex_
◆ SourceManager() [1/2]
deepstream::SourceManager::SourceManager ( const std::string &  name)
inline
Constructor.
Create a source manager with a user implemented action owner interface
Parameters
[in]namename of the instance
Definition at line 55 of file service-maker/includes/source_manager.hpp.
◆ SourceManager() [2/2]
inline
Constructor.
Parameters
Definition at line 55 of file 9.0/service-maker/includes/source_manager.hpp.
Member Function Documentation
◆ addSource() [1/2]
int deepstream::SourceManager::addSource ( const std::string &  source_name)
Parameters
[in]source_namename of the source to be added
Returns
int a unique ID for the source, -1 if failed
◆ addSource() [2/2]
Parameters
Returns
◆ attach() [1/2]
SignalEmitter& deepstream::SignalEmitter::attach ( const std::string &  action_name,
Object object
inherited
◆ attach() [2/2]
Object object
inherited
◆ connectSignal() [1/2]
bool deepstream::Object::connectSignal ( const std::string &  signal_name,
SignalHandler handler
inherited
Parameters
[in]signal_namename of the signal to be connected
[in]handlerhandler for the signal
◆ connectSignal() [2/2]
inherited
Parameters
◆ emit() [1/2]
SignalEmitter& deepstream::SignalEmitter::emit ( const std::string &  action_name,
const std::string &  object_name,
inherited
Parameters
[in]action_namename of the action to be triggered
[in]object_namename of the attached object who is to trigger the action
Referenced by deepstream::SmartRecordingAction::startSmartRecord(), and deepstream::SmartRecordingAction::stopSmartRecord().
◆ emit() [2/2]
inherited
Parameters
◆ emitSignal() [1/2]
void deepstream::Object::emitSignal ( const std::string &  signal_name,
va_list  args
inherited
Emit a signal.
◆ emitSignal() [2/2]
va_list  args
inherited
Emit a signal.
◆ get_() [1/2]
virtual Value deepstream::CustomObject::get_ ( const std::string &  name)
protectedvirtualinherited
Reimplemented from deepstream::Object.
◆ get_() [2/2]
◆ getGObject() [1/2]
GstObject* deepstream::Object::getGObject ( )
inlineinherited
Definition at line 140 of file service-maker/includes/object.hpp.
References deepstream::Object::object_.
◆ getGObject() [2/2]
inlineinherited
Definition at line 140 of file 9.0/service-maker/includes/object.hpp.
◆ getName() [1/2]
const std::string deepstream::Object::getName ( ) const
inherited
◆ getName() [2/2]
inherited
◆ getProperty() [1/2]
Object& deepstream::Object::getProperty ( const std::string &  name,
T &  value,
Args &...  args
inlineinherited
◆ getProperty() [2/2]
T &  value,
Args &...  args
inlineinherited
Definition at line 171 of file 9.0/service-maker/includes/object.hpp.
References deepstream::Object::get_(), and deepstream::Object::getProperty().
◆ give() [1/2]
GstObject* deepstream::Object::give ( )
inherited
◆ give() [2/2]
inherited
◆ listSignals() [1/2]
std::vector<std::string> deepstream::Object::listSignals ( bool  is_action)
inherited
◆ listSignals() [2/2]
inherited
◆ operator bool() [1/2]
deepstream::Object::operator bool ( ) const
inlineexplicitnoexceptinherited
Definition at line 131 of file service-maker/includes/object.hpp.
◆ operator bool() [2/2]
Definition at line 131 of file 9.0/service-maker/includes/object.hpp.
◆ operator==() [1/2]
bool deepstream::Object::operator== ( const Object other)
inlinenoexceptinherited
Definition at line 134 of file service-maker/includes/object.hpp.
◆ operator==() [2/2]
Definition at line 134 of file 9.0/service-maker/includes/object.hpp.
◆ removeSource() [1/2]
void deepstream::SourceManager::removeSource ( int  source_id)
Parameters
[in]source_idID of the source to be removed
◆ removeSource() [2/2]
Parameters
◆ seize() [1/2]
Object& deepstream::Object::seize ( GstObject object)
inherited
◆ seize() [2/2]
inherited
◆ set() [1/6]
Object& deepstream::Object::set ( const std::string &  name,
const T &  value,
inlineinherited
◆ set() [2/6]
const T &  value,
inlineinherited
◆ set() [3/6]
const Value value
inlineinherited
Definition at line 154 of file 9.0/service-maker/includes/object.hpp.
References deepstream::Object::set_().
◆ set() [4/6]
const Value value
inlineinherited
Definition at line 154 of file service-maker/includes/object.hpp.
◆ set() [5/6]
Object& deepstream::Object::set ( const YAML::Node &  params)
inherited
◆ set() [6/6]
inherited
Referenced by deepstream::Pipeline::add(), and deepstream::Object::set().
◆ set_() [1/4]
virtual void deepstream::CustomObject::set_ ( const std::string &  name,
const Value value
◆ set_() [2/4]
const Value value
◆ set_() [3/4]
const YAML::Node &  value
◆ set_() [4/4]
◆ take() [1/2]
Object& deepstream::Object::take ( GstObject object)
inherited
◆ take() [2/2]
inherited
◆ terminate() [1/2]
void deepstream::SourceManager::terminate ( )
◆ terminate() [2/2]
◆ type() [1/2]
static unsigned long deepstream::SignalEmitter::type ( )
staticinherited
◆ type() [2/2]
staticinherited
Field Documentation
◆ gen_number_
static int deepstream::SourceManager::gen_number_
staticprotected
Definition at line 79 of file service-maker/includes/source_manager.hpp.
◆ gen_number_mutex_
static std::mutex deepstream::SourceManager::gen_number_mutex_
staticprotected
Definition at line 80 of file service-maker/includes/source_manager.hpp.
◆ object_
GstObject * deepstream::Object::object_
protectedinherited
◆ object_map_
std::multimap< std::string, Object > deepstream::SignalEmitter::object_map_
protectedinherited
Definition at line 103 of file service-maker/includes/signal_emitter.hpp.
◆ owner_
std::unique_ptr< IActionOwner > deepstream::SignalEmitter::owner_
protectedinherited
Definition at line 104 of file service-maker/includes/signal_emitter.hpp.
◆ param_spec_
std::string deepstream::CustomObject::param_spec_
protectedinherited
Definition at line 51 of file service-maker/includes/custom_object.hpp.
◆ properties_
std::map< std::string, Object::Value > deepstream::CustomObject::properties_
protectedinherited
property map
Definition at line 53 of file service-maker/includes/custom_object.hpp.
