nvdsinferserver::BasePostprocessor Class Referenceabstract
Base post-processor class.
Definition at line 162 of file sources/libs/nvdsinferserver/infer_iprocess.h.
Inheritance diagram for nvdsinferserver::BasePostprocessor:
Collaboration diagram for nvdsinferserver::BasePostprocessor:
Public Types
using PostprocessDone = std::function< void(NvDsInferStatus, SharedBatchArray)>
Public Member Functions
 BasePostprocessor (InferPostprocessType type, int uid)
 Constructor, save process type and ID. More...
 ~BasePostprocessor () override=default
 Destructor default. More...
NvDsInferStatus postCudaProcess (SharedBatchArray inBuf, SharedCuStream mainStream, PostprocessDone done) override
 Acquire an output buffer array and call CUDA post processing steps. More...
NvDsInferStatus postHostProcess (SharedBatchArray inBuf, SharedCuStream mainStream, PostprocessDone done) override
 Acquire an output buffer array and call host side processing steps. More...
virtual NvDsInferStatus allocateResource (const std::vector< int > &devIds)=0
 Allocate resource like output buffer pool. More...
Member Typedef Documentation
◆ PostprocessDone [1/2]
◆ PostprocessDone [2/2]
◆ BasePostprocessor() [1/2]
nvdsinferserver::BasePostprocessor::BasePostprocessor ( InferPostprocessType  type,
int  uid
inline
Definition at line 167 of file sources/libs/nvdsinferserver/infer_iprocess.h.
◆ ~BasePostprocessor() [1/2]
nvdsinferserver::BasePostprocessor::~BasePostprocessor ( )
overridedefault
Destructor default.
◆ BasePostprocessor() [2/2]
int  uid
inline
Definition at line 167 of file 9.0/sources/libs/nvdsinferserver/infer_iprocess.h.
◆ ~BasePostprocessor() [2/2]
overridedefault
Destructor default.
Member Function Documentation
◆ allocateResource() [1/2]
virtual NvDsInferStatus nvdsinferserver::BasePostprocessor::allocateResource ( const std::vector< int > &  devIds)
pure virtual
◆ allocateResource() [2/2]
pure virtual
◆ networkType() [1/2]
InferPostprocessType nvdsinferserver::BasePostprocessor::networkType ( ) const
inline
◆ networkType() [2/2]
inline
◆ postCudaProcess() [1/2]
NvDsInferStatus nvdsinferserver::BasePostprocessor::postCudaProcess ( SharedBatchArray  inBuf,
inlineoverridevirtual
Parameters
[in]inBufPointer to the input batch array.
[in]mainStreamThe main CUDA stream to synchronize with.
[in]doneCallback function to be executed.
Returns
Error status.
Implements nvdsinferserver::IPostprocessor.
Definition at line 190 of file sources/libs/nvdsinferserver/infer_iprocess.h.
◆ postCudaProcess() [2/2]
Parameters
Returns
Error status.
Definition at line 190 of file 9.0/sources/libs/nvdsinferserver/infer_iprocess.h.
◆ postHostProcess() [1/2]
NvDsInferStatus nvdsinferserver::BasePostprocessor::postHostProcess ( SharedBatchArray  inBuf,
Parameters
Returns
Error status.
Definition at line 204 of file 9.0/sources/libs/nvdsinferserver/infer_iprocess.h.
◆ postHostProcess() [2/2]
Parameters
Returns
Error status.
Definition at line 204 of file sources/libs/nvdsinferserver/infer_iprocess.h.
◆ setUniqueId() [1/2]
void nvdsinferserver::BasePostprocessor::setUniqueId ( int  id)
inline
◆ setUniqueId() [2/2]
inline
◆ uniqueId() [1/2]
int nvdsinferserver::BasePostprocessor::uniqueId ( ) const
inline
◆ uniqueId() [2/2]
inline
