8.0 Release
nvdsinferserver::Postprocessor Class Referenceabstract
A generic post processor class.
Definition at line 54 of file sources/libs/nvdsinferserver/infer_postprocess.h.
Inheritance diagram for nvdsinferserver::Postprocessor:
Collaboration diagram for nvdsinferserver::Postprocessor:
Public Types
using TensorAllocator = std::function< SharedSysMem(const std::string &name, size_t bytes)>
using EventAllocator = std::function< SharedCuEvent()>
using PostprocessDone = std::function< void(NvDsInferStatus, SharedBatchArray)>
Public Member Functions
virtual ~Postprocessor ()=default
void setDllHandle (const SharedDllHandle &dlHandle)
void setLabelPath (const std::string &path)
void setNetworkInfo (const NvDsInferNetworkInfo &info)
void setOutputLayerCount (uint32_t num)
void setInputCopy (bool enable)
const std::vector< std::vector< std::string > > & getLabels () const
void setAllocator (TensorAllocator cpuAlloc, EventAllocator event)
bool needInputCopy () const
virtual NvDsInferStatus allocateResource (const std::vector< int > &devIds) override
NvDsInferStatus postCudaProcess (SharedBatchArray inBuf, SharedCuStream mainStream, PostprocessDone done) override
 Acquire an output buffer array and call CUDA post processing steps. More...
NvDsInferStatus postHostProcess (SharedBatchArray inBuf, SharedCuStream mainStream, PostprocessDone done) override
 Acquire an output buffer array and call host side processing steps. More...
Protected Member Functions
 Postprocessor (InferPostprocessType type, int id)
NvDsInferStatus postCudaImpl (SharedBatchArray &inBuf, SharedBatchArray &outbuf, SharedCuStream &mainStream) override
NvDsInferStatus postHostImpl (SharedBatchArray &inBuf, SharedBatchArray &outbuf, SharedCuStream &mainStream) override
SharedBatchArray requestCudaOutBufs (const SharedBatchArray &inBuf) override
SharedBatchArray requestHostOutBufs (const SharedBatchArray &inBuf) override
NvDsInferStatus parseLabelsFile (const std::string &path)
Protected Attributes
SharedDllHandle m_CustomLibHandle
 Custom library implementation. More...
bool m_CopyInputToHostBuffers = false
NvDsInferNetworkInfo m_NetworkInfo = {0}
 Network input information. More...
uint32_t m_OutputLayerCount = 0
std::string m_LabelPath
std::vector< std::vector< std::string > > m_Labels
 Holds the string labels for classes. More...
TensorAllocator m_CpuAllocator
EventAllocator m_EventAllocator
Member Typedef Documentation
◆ EventAllocator [1/2]
◆ EventAllocator [2/2]
◆ PostprocessDone [1/2]
◆ PostprocessDone [2/2]
◆ TensorAllocator [1/2]
using nvdsinferserver::Postprocessor::TensorAllocator = std::function<SharedSysMem(const std::string& name, size_t bytes)>
◆ TensorAllocator [2/2]
◆ Postprocessor() [1/2]
nvdsinferserver::Postprocessor::Postprocessor ( InferPostprocessType  type,
int  id
inlineprotected
◆ ~Postprocessor() [1/2]
virtual nvdsinferserver::Postprocessor::~Postprocessor ( )
virtualdefault
◆ Postprocessor() [2/2]
int  id
inlineprotected
◆ ~Postprocessor() [2/2]
virtualdefault
Member Function Documentation
◆ allocateResource() [1/2]
◆ allocateResource() [2/2]
◆ getLabels() [1/2]
const std::vector<std::vector<std::string> >& nvdsinferserver::Postprocessor::getLabels ( ) const
inline
Definition at line 74 of file sources/libs/nvdsinferserver/infer_postprocess.h.
References m_Labels.
◆ getLabels() [2/2]
inline
Definition at line 74 of file 9.0/sources/libs/nvdsinferserver/infer_postprocess.h.
◆ needInputCopy() [1/2]
bool nvdsinferserver::Postprocessor::needInputCopy ( ) const
inline
◆ needInputCopy() [2/2]
inline
◆ networkType() [1/2]
InferPostprocessType nvdsinferserver::BasePostprocessor::networkType ( ) const
inlineinherited
◆ networkType() [2/2]
inlineinherited
◆ parseLabelsFile() [1/2]
NvDsInferStatus nvdsinferserver::Postprocessor::parseLabelsFile ( const std::string &  path)
protected
◆ parseLabelsFile() [2/2]
protected
◆ postCudaImpl() [1/2]
NvDsInferStatus nvdsinferserver::Postprocessor::postCudaImpl ( SharedBatchArray inBuf,
SharedBatchArray outbuf,
overrideprotectedvirtual
◆ postCudaImpl() [2/2]
◆ postCudaProcess() [1/2]
NvDsInferStatus nvdsinferserver::BasePostprocessor::postCudaProcess ( SharedBatchArray  inBuf,
inlineoverridevirtualinherited
Parameters
[in]inBufPointer to the input batch array.
[in]mainStreamThe main CUDA stream to synchronize with.
[in]doneCallback function to be executed.
Returns
Error status.
Implements nvdsinferserver::IPostprocessor.
Definition at line 190 of file sources/libs/nvdsinferserver/infer_iprocess.h.
◆ postCudaProcess() [2/2]
Parameters
Returns
Error status.
Definition at line 190 of file 9.0/sources/libs/nvdsinferserver/infer_iprocess.h.
◆ postHostImpl() [1/2]
NvDsInferStatus nvdsinferserver::Postprocessor::postHostImpl ( SharedBatchArray inBuf,
◆ postHostImpl() [2/2]
◆ postHostProcess() [1/2]
NvDsInferStatus nvdsinferserver::BasePostprocessor::postHostProcess ( SharedBatchArray  inBuf,
Parameters
Returns
Error status.
Definition at line 204 of file sources/libs/nvdsinferserver/infer_iprocess.h.
◆ postHostProcess() [2/2]
Parameters
Returns
Error status.
Definition at line 204 of file 9.0/sources/libs/nvdsinferserver/infer_iprocess.h.
◆ requestCudaOutBufs() [1/2]
SharedBatchArray nvdsinferserver::Postprocessor::requestCudaOutBufs ( const SharedBatchArray inBuf)
◆ requestCudaOutBufs() [2/2]
◆ requestHostOutBufs() [1/2]
SharedBatchArray nvdsinferserver::Postprocessor::requestHostOutBufs ( const SharedBatchArray inBuf)
◆ requestHostOutBufs() [2/2]
◆ setAllocator() [1/2]
void nvdsinferserver::Postprocessor::setAllocator ( TensorAllocator  cpuAlloc,
inline
◆ setAllocator() [2/2]
inline
◆ setDllHandle() [1/2]
void nvdsinferserver::Postprocessor::setDllHandle ( const SharedDllHandle dlHandle)
inline
◆ setDllHandle() [2/2]
inline
◆ setInputCopy() [1/2]
void nvdsinferserver::Postprocessor::setInputCopy ( bool  enable)
inline
◆ setInputCopy() [2/2]
inline
◆ setLabelPath() [1/2]
void nvdsinferserver::Postprocessor::setLabelPath ( const std::string &  path)
inline
Definition at line 68 of file 9.0/sources/libs/nvdsinferserver/infer_postprocess.h.
References m_LabelPath.
◆ setLabelPath() [2/2]
inline
Definition at line 68 of file sources/libs/nvdsinferserver/infer_postprocess.h.
◆ setNetworkInfo() [1/2]
void nvdsinferserver::Postprocessor::setNetworkInfo ( const NvDsInferNetworkInfo info)
inline
◆ setNetworkInfo() [2/2]
inline
Definition at line 69 of file sources/libs/nvdsinferserver/infer_postprocess.h.
References m_NetworkInfo.
◆ setOutputLayerCount() [1/2]
void nvdsinferserver::Postprocessor::setOutputLayerCount ( uint32_t  num)
inline
◆ setOutputLayerCount() [2/2]
inline
◆ setUniqueId() [1/2]
void nvdsinferserver::BasePostprocessor::setUniqueId ( int  id)
inlineinherited
◆ setUniqueId() [2/2]
inlineinherited
◆ uniqueId() [1/2]
int nvdsinferserver::BasePostprocessor::uniqueId ( ) const
inlineinherited
◆ uniqueId() [2/2]
inlineinherited
Field Documentation
◆ m_CopyInputToHostBuffers
bool nvdsinferserver::Postprocessor::m_CopyInputToHostBuffers = false
protected
◆ m_CpuAllocator
TensorAllocator nvdsinferserver::Postprocessor::m_CpuAllocator
protected
Definition at line 121 of file sources/libs/nvdsinferserver/infer_postprocess.h.
Referenced by setAllocator().
◆ m_CustomLibHandle
SharedDllHandle nvdsinferserver::Postprocessor::m_CustomLibHandle
protected
Definition at line 111 of file sources/libs/nvdsinferserver/infer_postprocess.h.
Referenced by setDllHandle().
◆ m_EventAllocator
EventAllocator nvdsinferserver::Postprocessor::m_EventAllocator
protected
Definition at line 122 of file sources/libs/nvdsinferserver/infer_postprocess.h.
◆ m_LabelPath
std::string nvdsinferserver::Postprocessor::m_LabelPath
protected
Definition at line 116 of file sources/libs/nvdsinferserver/infer_postprocess.h.
Referenced by setLabelPath().
◆ m_Labels
std::vector< std::vector< std::string > > nvdsinferserver::Postprocessor::m_Labels
protected
Definition at line 119 of file sources/libs/nvdsinferserver/infer_postprocess.h.
Referenced by getLabels().
◆ m_NetworkInfo
NvDsInferNetworkInfo nvdsinferserver::Postprocessor::m_NetworkInfo = {0}
protected
Definition at line 114 of file sources/libs/nvdsinferserver/infer_postprocess.h.
Referenced by setNetworkInfo().
◆ m_OutputLayerCount
uint32_t nvdsinferserver::Postprocessor::m_OutputLayerCount = 0
protected
