8.0 Release
nvdsinferserver::ClassifyPostprocessor Class Reference
Post processor class for classification output.
Definition at line 208 of file sources/libs/nvdsinferserver/infer_postprocess.h.
Inheritance diagram for nvdsinferserver::ClassifyPostprocessor:
Collaboration diagram for nvdsinferserver::ClassifyPostprocessor:
Public Types
using TensorAllocator = std::function< SharedSysMem(const std::string &name, size_t bytes)>
using EventAllocator = std::function< SharedCuEvent()>
using PostprocessDone = std::function< void(NvDsInferStatus, SharedBatchArray)>
Public Member Functions
 ClassifyPostprocessor (int uid, const ic::ClassificationParams &params)
NvDsInferStatus allocateResource (const std::vector< int > &devIds) override
void setDllHandle (const SharedDllHandle &dlHandle)
void setLabelPath (const std::string &path)
void setNetworkInfo (const NvDsInferNetworkInfo &info)
void setOutputLayerCount (uint32_t num)
void setInputCopy (bool enable)
const std::vector< std::vector< std::string > > & getLabels () const
void setAllocator (TensorAllocator cpuAlloc, EventAllocator event)
bool needInputCopy () const
NvDsInferStatus postCudaProcess (SharedBatchArray inBuf, SharedCuStream mainStream, PostprocessDone done) override
 Acquire an output buffer array and call CUDA post processing steps. More...
NvDsInferStatus postHostProcess (SharedBatchArray inBuf, SharedCuStream mainStream, PostprocessDone done) override
 Acquire an output buffer array and call host side processing steps. More...
Protected Member Functions
NvDsInferStatus postCudaImpl (SharedBatchArray &inBuf, SharedBatchArray &outbuf, SharedCuStream &mainStream) override
NvDsInferStatus postHostImpl (SharedBatchArray &inBuf, SharedBatchArray &outbuf, SharedCuStream &mainStream) override
SharedBatchArray requestCudaOutBufs (const SharedBatchArray &inBuf) override
SharedBatchArray requestHostOutBufs (const SharedBatchArray &inBuf) override
NvDsInferStatus parseLabelsFile (const std::string &path)
Protected Attributes
SharedDllHandle m_CustomLibHandle
 Custom library implementation. More...
bool m_CopyInputToHostBuffers = false
NvDsInferNetworkInfo m_NetworkInfo = {0}
 Network input information. More...
uint32_t m_OutputLayerCount = 0
std::string m_LabelPath
std::vector< std::vector< std::string > > m_Labels
 Holds the string labels for classes. More...
TensorAllocator m_CpuAllocator
EventAllocator m_EventAllocator
Member Typedef Documentation
◆ EventAllocator [1/2]
◆ EventAllocator [2/2]
◆ PostprocessDone [1/2]
◆ PostprocessDone [2/2]
◆ TensorAllocator [1/2]
using nvdsinferserver::Postprocessor::TensorAllocator = std::function<SharedSysMem(const std::string& name, size_t bytes)>
inherited
◆ TensorAllocator [2/2]
inherited
◆ ClassifyPostprocessor() [1/2]
nvdsinferserver::ClassifyPostprocessor::ClassifyPostprocessor ( int  uid,
const ic::ClassificationParams &  params
◆ ClassifyPostprocessor() [2/2]
Member Function Documentation
◆ allocateResource() [1/2]
NvDsInferStatus nvdsinferserver::ClassifyPostprocessor::allocateResource ( const std::vector< int > &  devIds)
overridevirtual
Reimplemented from nvdsinferserver::Postprocessor.
◆ allocateResource() [2/2]
overridevirtual
◆ getLabels() [1/2]
const std::vector<std::vector<std::string> >& nvdsinferserver::Postprocessor::getLabels ( ) const
inlineinherited
◆ getLabels() [2/2]
inlineinherited
◆ needInputCopy() [1/2]
bool nvdsinferserver::Postprocessor::needInputCopy ( ) const
inlineinherited
◆ needInputCopy() [2/2]
inlineinherited
◆ networkType() [1/2]
InferPostprocessType nvdsinferserver::BasePostprocessor::networkType ( ) const
inlineinherited
◆ networkType() [2/2]
inlineinherited
◆ parseLabelsFile() [1/2]
NvDsInferStatus nvdsinferserver::Postprocessor::parseLabelsFile ( const std::string &  path)
protectedinherited
◆ parseLabelsFile() [2/2]
protectedinherited
◆ postCudaImpl() [1/2]
NvDsInferStatus nvdsinferserver::Postprocessor::postCudaImpl ( SharedBatchArray inBuf,
SharedBatchArray outbuf,
overrideprotectedvirtualinherited
◆ postCudaImpl() [2/2]
◆ postCudaProcess() [1/2]
NvDsInferStatus nvdsinferserver::BasePostprocessor::postCudaProcess ( SharedBatchArray  inBuf,
inlineoverridevirtualinherited
Parameters
[in]inBufPointer to the input batch array.
[in]mainStreamThe main CUDA stream to synchronize with.
[in]doneCallback function to be executed.
Returns
Error status.
Implements nvdsinferserver::IPostprocessor.
Definition at line 190 of file sources/libs/nvdsinferserver/infer_iprocess.h.
◆ postCudaProcess() [2/2]
Parameters
Returns
Error status.
Definition at line 190 of file 9.0/sources/libs/nvdsinferserver/infer_iprocess.h.
◆ postHostImpl() [1/2]
NvDsInferStatus nvdsinferserver::Postprocessor::postHostImpl ( SharedBatchArray inBuf,
◆ postHostImpl() [2/2]
◆ postHostProcess() [1/2]
NvDsInferStatus nvdsinferserver::BasePostprocessor::postHostProcess ( SharedBatchArray  inBuf,
Parameters
Returns
Error status.
Definition at line 204 of file 9.0/sources/libs/nvdsinferserver/infer_iprocess.h.
◆ postHostProcess() [2/2]
Parameters
Returns
Error status.
Definition at line 204 of file sources/libs/nvdsinferserver/infer_iprocess.h.
◆ requestCudaOutBufs() [1/2]
SharedBatchArray nvdsinferserver::Postprocessor::requestCudaOutBufs ( const SharedBatchArray inBuf)
◆ requestCudaOutBufs() [2/2]
◆ requestHostOutBufs() [1/2]
SharedBatchArray nvdsinferserver::Postprocessor::requestHostOutBufs ( const SharedBatchArray inBuf)
◆ requestHostOutBufs() [2/2]
◆ setAllocator() [1/2]
void nvdsinferserver::Postprocessor::setAllocator ( TensorAllocator  cpuAlloc,
inlineinherited
◆ setAllocator() [2/2]
inlineinherited
◆ setDllHandle() [1/2]
void nvdsinferserver::Postprocessor::setDllHandle ( const SharedDllHandle dlHandle)
inlineinherited
◆ setDllHandle() [2/2]
inlineinherited
◆ setInputCopy() [1/2]
void nvdsinferserver::Postprocessor::setInputCopy ( bool  enable)
inlineinherited
◆ setInputCopy() [2/2]
inlineinherited
◆ setLabelPath() [1/2]
void nvdsinferserver::Postprocessor::setLabelPath ( const std::string &  path)
inlineinherited
◆ setLabelPath() [2/2]
inlineinherited
◆ setNetworkInfo() [1/2]
void nvdsinferserver::Postprocessor::setNetworkInfo ( const NvDsInferNetworkInfo info)
inlineinherited
◆ setNetworkInfo() [2/2]
inlineinherited
◆ setOutputLayerCount() [1/2]
void nvdsinferserver::Postprocessor::setOutputLayerCount ( uint32_t  num)
inlineinherited
◆ setOutputLayerCount() [2/2]
inlineinherited
◆ setUniqueId() [1/2]
void nvdsinferserver::BasePostprocessor::setUniqueId ( int  id)
inlineinherited
◆ setUniqueId() [2/2]
inlineinherited
◆ uniqueId() [1/2]
int nvdsinferserver::BasePostprocessor::uniqueId ( ) const
inlineinherited
◆ uniqueId() [2/2]
inlineinherited
Field Documentation
◆ m_CopyInputToHostBuffers
bool nvdsinferserver::Postprocessor::m_CopyInputToHostBuffers = false
protectedinherited
◆ m_CpuAllocator
TensorAllocator nvdsinferserver::Postprocessor::m_CpuAllocator
protectedinherited
◆ m_CustomLibHandle
SharedDllHandle nvdsinferserver::Postprocessor::m_CustomLibHandle
protectedinherited
Definition at line 111 of file sources/libs/nvdsinferserver/infer_postprocess.h.
Referenced by nvdsinferserver::Postprocessor::setDllHandle().
◆ m_EventAllocator
EventAllocator nvdsinferserver::Postprocessor::m_EventAllocator
protectedinherited
◆ m_LabelPath
std::string nvdsinferserver::Postprocessor::m_LabelPath
protectedinherited
◆ m_Labels
std::vector< std::vector< std::string > > nvdsinferserver::Postprocessor::m_Labels
protectedinherited
Definition at line 119 of file sources/libs/nvdsinferserver/infer_postprocess.h.
Referenced by nvdsinferserver::Postprocessor::getLabels().
◆ m_NetworkInfo
NvDsInferNetworkInfo nvdsinferserver::Postprocessor::m_NetworkInfo = {0}
protectedinherited
Definition at line 114 of file sources/libs/nvdsinferserver/infer_postprocess.h.
Referenced by nvdsinferserver::Postprocessor::setNetworkInfo().
◆ m_OutputLayerCount
uint32_t nvdsinferserver::Postprocessor::m_OutputLayerCount = 0
protectedinherited
