7.1 Release
nvdsinferserver::CropSurfaceConverter Class Reference
Preprocessor for cropping, scaling and padding the inference input to required height, width.
Definition at line 113 of file infer_preprocess.h.
Inheritance diagram for nvdsinferserver::CropSurfaceConverter:
Collaboration diagram for nvdsinferserver::CropSurfaceConverter:
Public Types
using PreprocessDone = std::function< void(NvDsInferStatus, SharedBatchArray)>
Public Member Functions
 CropSurfaceConverter (int32_t convertPoolSize)
 ~CropSurfaceConverter () override
void setParams (int outW, int outH, InferMediaFormat outFormat, int maxBatchSize)
void setMaintainAspectRatio (bool enable)
void setSymmetricPadding (bool enable)
void setScalingHW (NvBufSurfTransform_Compute compute_hw)
void setScalingFilter (NvBufSurfTransform_Inter filter)
NvDsInferStatus transform (SharedBatchArray src, SharedCuStream mainStream, PreprocessDone done) override
 Perform the transformation on the input buffer from the buffer array, indexed using m_TransformIdx. More...
Member Typedef Documentation
◆ PreprocessDone
Definition at line 44 of file infer_iprocess.h.
◆ CropSurfaceConverter()
nvdsinferserver::CropSurfaceConverter::CropSurfaceConverter ( int32_t  convertPoolSize)
inline
Definition at line 115 of file infer_preprocess.h.
◆ ~CropSurfaceConverter()
nvdsinferserver::CropSurfaceConverter::~CropSurfaceConverter ( )
override
Member Function Documentation
◆ setMaintainAspectRatio()
void nvdsinferserver::CropSurfaceConverter::setMaintainAspectRatio ( bool  enable)
inline
Definition at line 120 of file infer_preprocess.h.
◆ setParams()
void nvdsinferserver::CropSurfaceConverter::setParams ( int  outW,
int  outH,
int  maxBatchSize
◆ setScalingFilter()
void nvdsinferserver::CropSurfaceConverter::setScalingFilter ( NvBufSurfTransform_Inter  filter)
inline
◆ setScalingHW()
void nvdsinferserver::CropSurfaceConverter::setScalingHW ( NvBufSurfTransform_Compute  compute_hw)
inline
Definition at line 122 of file infer_preprocess.h.
◆ setSymmetricPadding()
void nvdsinferserver::CropSurfaceConverter::setSymmetricPadding ( bool  enable)
inline
Definition at line 121 of file infer_preprocess.h.
◆ setTransformIdx()
void nvdsinferserver::BasePreprocessor::setTransformIdx ( int  idx)
inlineinherited
Definition at line 92 of file infer_iprocess.h.
◆ setUniqueId()
void nvdsinferserver::BasePreprocessor::setUniqueId ( int  id)
inlineinherited
Definition at line 90 of file infer_iprocess.h.
◆ transform()
NvDsInferStatus nvdsinferserver::BasePreprocessor::transform ( SharedBatchArray  src,
PreprocessDone  done
inlineoverridevirtualinherited
Parameters
[in]srcThe input batch buffer array.
[in]mainStreamThe main processing CUDA stream.
[in]doneThe call function to be called after transformation.
Returns
NVDSINFER_SUCCESS or NVDSINFER_RESOURCE_ERROR.
Implements nvdsinferserver::IPreprocessor.
Definition at line 103 of file infer_iprocess.h.
References NVDSINFER_RESOURCE_ERROR, and NVDSINFER_SUCCESS.
◆ uniqueId()
int nvdsinferserver::BasePreprocessor::uniqueId ( ) const
inlineinherited
Definition at line 91 of file infer_iprocess.h.
