7.1 Release
nvdsinferserver::TritonSimpleRuntime Class Reference
Definition at line 21 of file infer_simple_runtime.h.
Inheritance diagram for nvdsinferserver::TritonSimpleRuntime:
Collaboration diagram for nvdsinferserver::TritonSimpleRuntime:
Public Types
enum  {
  kLTpLayerDesc,
  kTpLayerNum
enum  {
  kInShapeName,
  kInShapeDims
using InferenceDone = std::function< void(NvDsInferStatus, SharedBatchArray)>
 Function wrapper for post inference processing. More...
using InputsConsumed = std::function< void(SharedBatchArray)>
 Function wrapper called after the input buffer is consumed. More...
using LayersTuple = std::tuple< const LayerDescription *, int >
 Tuple containing pointer to layer descriptions and the number of layers. More...
using InputShapeTuple = std::tuple< std::string, InferBatchDims >
 Tuple of layer name and dimensions including batch size. More...
using InputShapes = std::vector< InputShapeTuple >
Public Member Functions
 TritonSimpleRuntime (std::string model, int64_t version)
 ~TritonSimpleRuntime () override
void setOutputs (const std::set< std::string > &names)
NvDsInferStatus initialize () override
void addClassifyParams (const TritonClassParams &c)
 Add Triton Classification parameters to the list. More...
void setTensorMaxBytes (const std::string &name, size_t maxBytes)
 Set the maximum size for the tensor, the maximum of the existing size and new input size is used. More...
InferTensorOrder getInputTensorOrder () const final
 Returns the input tensor order. More...
void setUniqueId (uint32_t id)
 Set the unique ID for the object instance. More...
int uniqueId () const
 Get the unique ID of the object instance. More...
void setFirstDimBatch (bool flag)
 Set the flag indicating that it is a batch input. More...
bool isFirstDimBatch () const final
 Returns boolean indicating if batched input is expected. More...
uint32_t getLayerSize () const final
 Returns the total number of layers (input + output) for the model. More...
uint32_t getInputLayerSize () const final
 Returns the number of input layers for the model. More...
const LayerDescriptiongetLayerInfo (const std::string &bindingName) const final
 Retrieve the layer information from the layer name. More...
LayersTuple getInputLayers () const final
 Get the LayersTuple for input layers. More...
LayersTuple getOutputLayers () const final
 Get the LayersTuple for output layers. More...
bool checkInputDims (const InputShapes &shapes) const
 Check that the list of input shapes have fixed dimensions and corresponding layers are marked as input layers. More...
const LayerDescriptionListallLayers () const
 Returns the list of all descriptions of all layers, input and output. More...
void setKeepInputs (bool enable)
 Set the flag indicating whether to keep inputs buffers. More...
int32_t maxBatchSize () const final
 Returns the maximum batch size set for the backend. More...
bool isNonBatching () const
 Checks if the batch size indicates batched processing or no. More...
void setOutputPoolSize (int size)
 Helper function to access the member variables. More...
int outputPoolSize () const
void setOutputMemType (InferMemType memType)
InferMemType outputMemType () const
void setOutputDevId (int64_t devId)
int64_t outputDevId () const
std::vector< TritonClassParamsgetClassifyParams ()
const std::string & model () const
int64_t version () const
Protected Types
enum  {
  kName,
  kGpuId,
  kMemType
 Tuple keys as <tensor-name, gpu-id, memType> More...
using AsyncDone = std::function< void(NvDsInferStatus, SharedBatchArray)>
 Asynchronous inference done function: AsyncDone(Status, outputs). More...
using PoolKey = std::tuple< std::string, int64_t, InferMemType >
 Tuple holding tensor name, GPU ID, memory type. More...
using PoolValue = SharedBufPool< UniqSysMem >
 The buffer pool for the specified tensor, GPU and memory type combination. More...
using ReorderItemPtr = std::shared_ptr< ReorderItem >
using LayerIdxMap = std::unordered_map< std::string, int >
 Map of layer name to layer index. More...
Protected Member Functions
NvDsInferStatus specifyInputDims (const InputShapes &shapes) override
NvDsInferStatus enqueue (SharedBatchArray inputs, SharedCuStream stream, InputsConsumed bufConsumed, InferenceDone inferenceDone) override
void requestTritonOutputNames (std::set< std::string > &names) override
virtual NvDsInferStatus ensureServerReady ()
 Check that the Triton inference server is live. More...
virtual NvDsInferStatus ensureModelReady ()
 Check that the model is ready, load the model if it is not. More...
NvDsInferStatus setupReorderThread ()
 Create a loop thread that calls inferenceDoneReorderLoop on the queued items. More...
void setAllocator (UniqTritonAllocator allocator)
 Set the output tensor allocator. More...
virtual NvDsInferStatus setupLayersInfo ()
 Get the model configuration from the server and populate layer information. More...
TrtServerPtrserver ()
 Get the Triton server handle. More...
virtual NvDsInferStatus Run (SharedBatchArray inputs, InputsConsumed bufConsumed, AsyncDone asyncDone)
 Create an inference request and trigger asynchronous inference. More...
NvDsInferStatus fixateDims (const SharedBatchArray &bufs)
 Extend the dimensions to include batch size for the buffers in input array. More...
SharedSysMem allocateResponseBuf (const std::string &tensor, size_t bytes, InferMemType memType, int64_t devId)
 Acquire a buffer from the output buffer pool associated with the device ID and memory type. More...
void releaseResponseBuf (const std::string &tensor, SharedSysMem mem)
 Release the output tensor buffer. More...
NvDsInferStatus ensureInputs (SharedBatchArray &inputs)
 Ensure that the array of input buffers are expected by the model and reshape the input buffers if required. More...
PoolValue findResponsePool (PoolKey &key)
 Find the buffer pool for the given key. More...
PoolValue createResponsePool (PoolKey &key, size_t bytes)
 Create a new buffer pool for the key. More...
void serverInferCompleted (std::shared_ptr< TrtServerRequest > request, std::unique_ptr< TrtServerResponse > uniqResponse, InputsConsumed inputsConsumed, AsyncDone asyncDone)
 Call the inputs consumed function and parse the inference response to form the array of output batch buffers and call asyncDone on it. More...
bool inferenceDoneReorderLoop (ReorderItemPtr item)
 Add input buffers to the output buffer list if required. More...
bool debatchingOutput (SharedBatchArray &outputs, SharedBatchArray &inputs)
 Separate the batch dimension from the output buffer descriptors. More...
void resetLayers (LayerDescriptionList layers, int inputSize)
 Set the layer description list of the backend. More...
LayerDescriptionmutableLayerInfo (const std::string &bindingName)
 Get the mutable layer description structure for the layer name. More...
void setInputTensorOrder (InferTensorOrder order)
 Set the tensor order for the input layers. More...
bool needKeepInputs () const
 Check if the keep input flag is set. More...
void setMaxBatchSize (uint32_t size)
 Set the maximum batch size to be used for the backend. More...
Member Typedef Documentation
◆ AsyncDone
using nvdsinferserver::TrtISBackend::AsyncDone = std::function<void(NvDsInferStatus, SharedBatchArray)>
protectedinherited
Definition at line 169 of file infer_trtis_backend.h.
◆ InferenceDone
Definition at line 66 of file infer_ibackend.h.
◆ InputsConsumed
using nvdsinferserver::IBackend::InputsConsumed = std::function<void(SharedBatchArray)>
inherited
Definition at line 70 of file infer_ibackend.h.
◆ InputShapes
Definition at line 84 of file infer_ibackend.h.
◆ InputShapeTuple
using nvdsinferserver::IBackend::InputShapeTuple = std::tuple<std::string, InferBatchDims>
inherited
Definition at line 83 of file infer_ibackend.h.
◆ LayerIdxMap
using nvdsinferserver::BaseBackend::LayerIdxMap = std::unordered_map<std::string, int>
protectedinherited
Definition at line 136 of file infer_base_backend.h.
◆ LayersTuple
using nvdsinferserver::IBackend::LayersTuple = std::tuple<const LayerDescription*, int>
inherited
Definition at line 77 of file infer_ibackend.h.
◆ PoolKey
using nvdsinferserver::TrtISBackend::PoolKey = std::tuple<std::string, int64_t, InferMemType>
protectedinherited
Definition at line 224 of file infer_trtis_backend.h.
◆ PoolValue
using nvdsinferserver::TrtISBackend::PoolValue = SharedBufPool<UniqSysMem>
protectedinherited
Definition at line 229 of file infer_trtis_backend.h.
◆ ReorderItemPtr
using nvdsinferserver::TrtISBackend::ReorderItemPtr = std::shared_ptr<ReorderItem>
protectedinherited
Definition at line 293 of file infer_trtis_backend.h.
Member Enumeration Documentation
◆ anonymous enum
anonymous enum
protectedinherited
Enumerator
kName
kGpuId
kMemType
Definition at line 220 of file infer_trtis_backend.h.
◆ anonymous enum
anonymous enum
inherited
Enumerator
kLTpLayerDesc
kTpLayerNum
Definition at line 72 of file infer_ibackend.h.
◆ anonymous enum
anonymous enum
inherited
Enumerator
kInShapeName
kInShapeDims
Definition at line 79 of file infer_ibackend.h.
◆ TritonSimpleRuntime()
nvdsinferserver::TritonSimpleRuntime::TritonSimpleRuntime ( std::string  model,
int64_t  version
◆ ~TritonSimpleRuntime()
nvdsinferserver::TritonSimpleRuntime::~TritonSimpleRuntime ( )
override
Member Function Documentation
◆ addClassifyParams()
void nvdsinferserver::TrtISBackend::addClassifyParams ( const TritonClassParams c)
inlineinherited
Definition at line 58 of file infer_trtis_backend.h.
◆ allLayers()
const LayerDescriptionList& nvdsinferserver::BaseBackend::allLayers ( ) const
inlineinherited
Definition at line 113 of file infer_base_backend.h.
◆ allocateResponseBuf()
SharedSysMem nvdsinferserver::TrtISBackend::allocateResponseBuf ( const std::string &  tensor,
size_t  bytes,
int64_t  devId
protectedinherited
Create the pool if it doesn't exist.
Parameters
[in]tensorName of the output tensor.
[in]bytesBuffer size.
[in]memTypeRequested memory type.
[in]devIdDevice ID for the allocation.
Returns
Pointer to the allocated buffer.
◆ checkInputDims()
bool nvdsinferserver::BaseBackend::checkInputDims ( const InputShapes shapes) const
inherited
◆ createResponsePool()
PoolValue nvdsinferserver::TrtISBackend::createResponsePool ( PoolKey key,
size_t  bytes
protectedinherited
Parameters
[in]keyThe pool key combination.
[in]bytesSize of the requested buffer.
Returns
◆ debatchingOutput()
bool nvdsinferserver::TrtISBackend::debatchingOutput ( SharedBatchArray outputs,
protectedinherited
Parameters
[in]outputsArray of output batch buffers.
[in]inputsArray of input batch buffers.
Returns
Boolean indicating success or failure.
◆ enqueue()
NvDsInferStatus nvdsinferserver::TritonSimpleRuntime::enqueue ( SharedBatchArray  inputs,
overrideprotectedvirtual
Reimplemented from nvdsinferserver::TrtISBackend.
◆ ensureInputs()
NvDsInferStatus nvdsinferserver::TrtISBackend::ensureInputs ( SharedBatchArray inputs)
protectedinherited
Parameters
Returns
NVDSINFER_SUCCESS or NVDSINFER_TRITON_ERROR.
◆ ensureModelReady()
virtual NvDsInferStatus nvdsinferserver::TrtISBackend::ensureModelReady ( )
protectedvirtualinherited
Returns
Reimplemented in nvdsinferserver::TritonGrpcBackend.
◆ ensureServerReady()
virtual NvDsInferStatus nvdsinferserver::TrtISBackend::ensureServerReady ( )
Returns
◆ findResponsePool()
PoolValue nvdsinferserver::TrtISBackend::findResponsePool ( PoolKey key)
protectedinherited
◆ fixateDims()
NvDsInferStatus nvdsinferserver::TrtISBackend::fixateDims ( const SharedBatchArray bufs)
protectedinherited
Do nothing if batch input is not required.
◆ getClassifyParams()
std::vector<TritonClassParams> nvdsinferserver::TrtISBackend::getClassifyParams ( )
inlineinherited
Definition at line 71 of file infer_trtis_backend.h.
◆ getInputLayers()
LayersTuple nvdsinferserver::BaseBackend::getInputLayers ( ) const
finalvirtualinherited
Implements nvdsinferserver::IBackend.
◆ getInputLayerSize()
uint32_t nvdsinferserver::BaseBackend::getInputLayerSize ( ) const
inlinefinalvirtualinherited
Definition at line 83 of file infer_base_backend.h.
◆ getInputTensorOrder()
InferTensorOrder nvdsinferserver::BaseBackend::getInputTensorOrder ( ) const
Definition at line 49 of file infer_base_backend.h.
◆ getLayerInfo()
const LayerDescription* nvdsinferserver::BaseBackend::getLayerInfo ( const std::string &  bindingName) const
Referenced by nvdsinferserver::BaseBackend::mutableLayerInfo().
◆ getLayerSize()
uint32_t nvdsinferserver::BaseBackend::getLayerSize ( ) const
Definition at line 75 of file infer_base_backend.h.
◆ getOutputLayers()
LayersTuple nvdsinferserver::BaseBackend::getOutputLayers ( ) const
◆ inferenceDoneReorderLoop()
bool nvdsinferserver::TrtISBackend::inferenceDoneReorderLoop ( ReorderItemPtr  item)
protectedinherited
De-batch and run inference done callback.
Parameters
[in]itemThe reorder task.
Returns
◆ initialize()
NvDsInferStatus nvdsinferserver::TritonSimpleRuntime::initialize ( )
overridevirtual
◆ isFirstDimBatch()
bool nvdsinferserver::BaseBackend::isFirstDimBatch ( ) const
Definition at line 69 of file infer_base_backend.h.
◆ isNonBatching()
bool nvdsinferserver::BaseBackend::isNonBatching ( ) const
inlineinherited
Definition at line 130 of file infer_base_backend.h.
References INFER_EXPORT_API::isNonBatch(), and nvdsinferserver::BaseBackend::maxBatchSize().
◆ maxBatchSize()
int32_t nvdsinferserver::BaseBackend::maxBatchSize ( ) const
Definition at line 125 of file infer_base_backend.h.
Referenced by nvdsinferserver::BaseBackend::isNonBatching().
◆ model()
const std::string& nvdsinferserver::TrtISBackend::model ( ) const
inlineinherited
Definition at line 73 of file infer_trtis_backend.h.
◆ mutableLayerInfo()
LayerDescription* nvdsinferserver::BaseBackend::mutableLayerInfo ( const std::string &  bindingName)
inlineprotectedinherited
Definition at line 153 of file infer_base_backend.h.
References nvdsinferserver::BaseBackend::getLayerInfo().
◆ needKeepInputs()
bool nvdsinferserver::BaseBackend::needKeepInputs ( ) const
Definition at line 167 of file infer_base_backend.h.
◆ outputDevId()
int64_t nvdsinferserver::TrtISBackend::outputDevId ( ) const
inlineinherited
Definition at line 70 of file infer_trtis_backend.h.
◆ outputMemType()
InferMemType nvdsinferserver::TrtISBackend::outputMemType ( ) const
inlineinherited
Definition at line 68 of file infer_trtis_backend.h.
◆ outputPoolSize()
int nvdsinferserver::TrtISBackend::outputPoolSize ( ) const
inlineinherited
Definition at line 66 of file infer_trtis_backend.h.
◆ releaseResponseBuf()
void nvdsinferserver::TrtISBackend::releaseResponseBuf ( const std::string &  tensor,
SharedSysMem  mem
protectedinherited
Parameters
[in]memPointer to the memory buffer.
◆ requestTritonOutputNames()
void nvdsinferserver::TritonSimpleRuntime::requestTritonOutputNames ( std::set< std::string > &  names)
◆ resetLayers()
void nvdsinferserver::BaseBackend::resetLayers ( LayerDescriptionList  layers,
int  inputSize
protectedinherited
This function sets the layer description for the backend and updates the number of input layers, layer name to index map.
Parameters
[in]layersThe list of descriptions for all layers, input followed by output layers.
[in]inputSizeThe number of input layers in the list.
◆ Run()
virtual NvDsInferStatus nvdsinferserver::TrtISBackend::Run ( SharedBatchArray  inputs,
AsyncDone  asyncDone
serverInferCompleted() is set as callback function that in turn calls asyncDone.
Parameters
[in]bufConsumedCallback function for releasing input buffer.
[in]asyncDoneCallback function for processing response .
Returns
◆ server()
TrtServerPtr& nvdsinferserver::TrtISBackend::server ( )
Definition at line 164 of file infer_trtis_backend.h.
◆ serverInferCompleted()
void nvdsinferserver::TrtISBackend::serverInferCompleted ( std::shared_ptr< TrtServerRequest request,
std::unique_ptr< TrtServerResponse uniqResponse,
AsyncDone  asyncDone
protectedinherited
Parameters
[in]requestPointer to the inference request.
[in]uniqResponsePointer to the inference response from the server.
[in]inputsConsumedCallback function for releasing input buffer.
◆ setAllocator()
void nvdsinferserver::TrtISBackend::setAllocator ( UniqTritonAllocator  allocator)
Definition at line 148 of file infer_trtis_backend.h.
◆ setFirstDimBatch()
void nvdsinferserver::BaseBackend::setFirstDimBatch ( bool  flag)
inlineinherited
Definition at line 64 of file infer_base_backend.h.
◆ setInputTensorOrder()
void nvdsinferserver::BaseBackend::setInputTensorOrder ( InferTensorOrder  order)
Definition at line 162 of file infer_base_backend.h.
◆ setKeepInputs()
void nvdsinferserver::BaseBackend::setKeepInputs ( bool  enable)
inlineinherited
Definition at line 118 of file infer_base_backend.h.
◆ setMaxBatchSize()
void nvdsinferserver::BaseBackend::setMaxBatchSize ( uint32_t  size)
Definition at line 174 of file infer_base_backend.h.
◆ setOutputDevId()
void nvdsinferserver::TrtISBackend::setOutputDevId ( int64_t  devId)
inlineinherited
Definition at line 69 of file infer_trtis_backend.h.
◆ setOutputMemType()
void nvdsinferserver::TrtISBackend::setOutputMemType ( InferMemType  memType)
inlineinherited
Definition at line 67 of file infer_trtis_backend.h.
◆ setOutputPoolSize()
void nvdsinferserver::TrtISBackend::setOutputPoolSize ( int  size)
inlineinherited
Definition at line 65 of file infer_trtis_backend.h.
◆ setOutputs()
void nvdsinferserver::TritonSimpleRuntime::setOutputs ( const std::set< std::string > &  names)
inline
Definition at line 26 of file infer_simple_runtime.h.
◆ setTensorMaxBytes()
void nvdsinferserver::TrtISBackend::setTensorMaxBytes ( const std::string &  name,
size_t  maxBytes
inlineinherited
The size is rounded up to INFER_MEM_ALIGNMENT bytes.
Parameters
nameName of the tensor.
maxBytesNew maximum number of bytes for the buffer.
Definition at line 110 of file infer_trtis_backend.h.
References INFER_MEM_ALIGNMENT, and INFER_ROUND_UP.
◆ setUniqueId()
void nvdsinferserver::BaseBackend::setUniqueId ( uint32_t  id)
inlineinherited
Definition at line 54 of file infer_base_backend.h.
◆ setupLayersInfo()
virtual NvDsInferStatus nvdsinferserver::TrtISBackend::setupLayersInfo ( )
Set maximum batch size as specified in configuration settings.
Returns
◆ setupReorderThread()
NvDsInferStatus nvdsinferserver::TrtISBackend::setupReorderThread ( )
protectedinherited
Returns
◆ specifyInputDims()
NvDsInferStatus nvdsinferserver::TritonSimpleRuntime::specifyInputDims ( const InputShapes shapes)
◆ uniqueId()
int nvdsinferserver::BaseBackend::uniqueId ( ) const
inlineinherited
Definition at line 59 of file infer_base_backend.h.
◆ version()
int64_t nvdsinferserver::TrtISBackend::version ( ) const
inlineinherited
Definition at line 74 of file infer_trtis_backend.h.
