nvdsinferserver::TrtISServer Class Reference
Wrapper class for creating Triton Inference Server instance.
Definition at line 533 of file sources/libs/nvdsinferserver/infer_trtis_server.h.
Inheritance diagram for nvdsinferserver::TrtISServer:
Collaboration diagram for nvdsinferserver::TrtISServer:
Public Member Functions
 ~TrtISServer ()
 Destructor. More...
bool isServerReady ()
 Check if the server is ready. More...
bool isServerLive ()
 Check if the server is live. More...
bool isModelReady (const std::string &model, int64_t version)
 Check if the server is ready for inference using specified model. More...
NvDsInferStatus loadModel (const std::string &modelName)
 Load or reload the specified model. More...
NvDsInferStatus unloadModel (const std::string &modelName)
 Unload the specified model. More...
NvDsInferStatus getModelConfig (const std::string &model, int64_t version, ni::ModelConfig &config)
 Get the model configuration for the specified model. More...
SharedRequest createRequest (const std::string &model, int64_t version, SharedBatchArray &inputs, const std::vector< std::string > &outputs, const std::vector< TritonClassParams > &clasList)
 Create and initializes a new inference request. More...
NvDsInferStatus inferAsync (SharedRequest request, WeakTritonAllocator allocator, TritonInferAsyncDone done)
 Submit a request for asynchronous inference. More...
 ~TrtISServer ()
 Destructor. More...
static TrtServerPtr getInstance (const triton::RepoSettings *repo)
 Get a new or existing instance of the Triton Inference Server. More...
Protected Member Functions
 TrtISServer (const triton::RepoSettings &repo)
 Constructor. More...
NvDsInferStatus initialize ()
 Create a new instance of the Triton Inference Server. More...
const triton::RepoSettingsgetRepoSettings ()
 Get the model repository settings. More...
Friends
class TrtServerRequest
class TrtServerResponse
◆ TrtISServer() [1/2]
nvdsinferserver::TrtISServer::TrtISServer ( const triton::RepoSettings repo)
protected
Constructor.
Save the model repository configuration settings.
Parameters
repo
◆ ~TrtISServer() [1/2]
nvdsinferserver::TrtISServer::~TrtISServer ( )
Destructor.
Stops the Triton server if the server handle is valid.
◆ TrtISServer() [2/2]
protected
Constructor.
Parameters
repo
◆ ~TrtISServer() [2/2]
Destructor.
Member Function Documentation
◆ createRequest() [1/2]
SharedRequest nvdsinferserver::TrtISServer::createRequest ( const std::string &  model,
int64_t  version,
SharedBatchArray inputs,
const std::vector< std::string > &  outputs,
const std::vector< TritonClassParams > &  clasList
Parameters
[in]modelName of the model.
[in]versionVersion of the model.
[in]inputsArray of input batch buffers.
[in]outputsList of requested output names.
[in]clasListTriton Classification parameters, if any.
Returns
Pointer to the request instance upon success, null pointer on failure.
◆ createRequest() [2/2]
int64_t  version,
Parameters
Returns
◆ getInstance() [1/2]
static TrtServerPtr nvdsinferserver::TrtISServer::getInstance ( const triton::RepoSettings repo)
static
This function checks if an instance of Triton is present. If it doesn't exist, a new one is instantiated using the provided model repository configuration. If a Triton instance is already running and repository configuration is provided, the existing and new configuration is checked to be same otherwise a null pointer is returned.
Parameters
[in]repoModel repository configuration, can be null when the Triton server is already instantiated.
Returns
Pointer to the Triton server instance.
◆ getInstance() [2/2]
static
Parameters
Returns
◆ getModelConfig() [1/2]
NvDsInferStatus nvdsinferserver::TrtISServer::getModelConfig ( const std::string &  model,
int64_t  version,
ni::ModelConfig &  config
Parameters
[out]configModelConfig protobuf message to be populated.
Returns
NVDSINFER_SUCCESS or NVDSINFER_TRITON_ERROR.
◆ getModelConfig() [2/2]
int64_t  version,
Parameters
Returns
◆ getRepoSettings() [1/2]
const triton::RepoSettings& nvdsinferserver::TrtISServer::getRepoSettings ( )
inlineprotected
Definition at line 558 of file 9.0/sources/libs/nvdsinferserver/infer_trtis_server.h.
◆ getRepoSettings() [2/2]
inlineprotected
Definition at line 558 of file sources/libs/nvdsinferserver/infer_trtis_server.h.
◆ inferAsync() [1/2]
NvDsInferStatus nvdsinferserver::TrtISServer::inferAsync ( SharedRequest  request,
This functions sets the release and response callback functions for the request and then triggers the asynchronous inference.
Parameters
[in]requestPointer to the request object.
[in]allocatorPointer to the response allocator.
[in]donePointer to the function to be called after inference is done.
Returns
◆ inferAsync() [2/2]
Parameters
Returns
◆ initialize() [1/2]
NvDsInferStatus nvdsinferserver::TrtISServer::initialize ( )
protected
This functions creates a TRITONSERVER_ServerOptions instance and updates it as per the repository configuration. These options are then used to create a new Triton instance and save the handle in m_Impl.
Returns
Error status.
◆ initialize() [2/2]
protected
Returns
Error status.
◆ isModelReady() [1/2]
bool nvdsinferserver::TrtISServer::isModelReady ( const std::string &  model,
int64_t  version
Parameters
Returns
Boolean indicating readiness.
◆ isModelReady() [2/2]
int64_t  version
Parameters
Returns
◆ isServerLive() [1/2]
bool nvdsinferserver::TrtISServer::isServerLive ( )
◆ isServerLive() [2/2]
◆ isServerReady() [1/2]
bool nvdsinferserver::TrtISServer::isServerReady ( )
◆ isServerReady() [2/2]
◆ loadModel() [1/2]
NvDsInferStatus nvdsinferserver::TrtISServer::loadModel ( const std::string &  modelName)
Parameters
[in]modelNameName of the model
Returns
◆ loadModel() [2/2]
Parameters
Returns
◆ unloadModel() [1/2]
NvDsInferStatus nvdsinferserver::TrtISServer::unloadModel ( const std::string &  modelName)
Parameters
[in]modelNameName of the model.
Returns
◆ unloadModel() [2/2]
Parameters
Returns
Friends And Related Function Documentation
◆ TrtServerRequest
◆ TrtServerResponse
