nvdsinferserver::TrtServerRequest Class Reference
Wrapper class for Triton inference request.
Definition at line 68 of file sources/libs/nvdsinferserver/infer_trtis_server.h.
Public Member Functions
 ~TrtServerRequest ()
 Destructor. More...
TRITONSERVER_InferenceRequest * ptr ()
 Get the pointer to the Triton inference request object. More...
const std::string & model () const
 Get the model name. More...
uint64_t id () const
 Get the request ID. More...
uint64_t bufId () const
 Get the input buffer ID associated with the request. More...
SharedBatchArray releaseInputs ()
 Release the ownership of input batch buffer array. More...
const std::vector< std::string > & outputs () const
 Get the list of requested output layer names. More...
const std::map< std::string, TritonClassParams > & classParams () const
 Get the Triton classification parameters list (tensor name : classification parameters). More...
 Destructor. More...
Protected Member Functions
 TrtServerRequest (TrtServerPtr server)
 Constructor. More...
NvDsInferStatus init (const std::string &model, int64_t version, SharedBatchArray &inputs, const std::vector< std::string > &outputs, uint64_t reqId, const std::vector< TritonClassParams > &clasList)
 Create a new Triton inference request with the specified inputs and parameters. More...
NvDsInferStatus setRequestComplete (TRITONSERVER_InferenceRequestReleaseFn_t requestCompleteCb, void *userPtr)
 Set the release callback function for the request. More...
NvDsInferStatus setResponseComplete (ShrTritonAllocator &allocator, TRITONSERVER_InferenceResponseCompleteFn_t responseCompleteCb, void *responseUserPtr)
 Set the allocator and response callback for the request. More...
Static Protected Member Functions
static void RequestOnRelease (TRITONSERVER_InferenceRequest *request, const uint32_t flags, void *userp)
 The callback function to release the request instance. More...
Friends
class TrtISServer
◆ TrtServerRequest() [1/2]
nvdsinferserver::TrtServerRequest::TrtServerRequest ( TrtServerPtr  server)
protected
Constructor.
Save the server instance pointer and register the Triton request deletion function.
Parameters
server
◆ ~TrtServerRequest() [1/2]
nvdsinferserver::TrtServerRequest::~TrtServerRequest ( )
Destructor.
Releases the Triton inference request instance.
◆ TrtServerRequest() [2/2]
protected
Constructor.
Parameters
server
◆ ~TrtServerRequest() [2/2]
Destructor.
Member Function Documentation
◆ bufId() [1/2]
uint64_t nvdsinferserver::TrtServerRequest::bufId ( ) const
inline
Definition at line 147 of file sources/libs/nvdsinferserver/infer_trtis_server.h.
◆ bufId() [2/2]
inline
Definition at line 147 of file 9.0/sources/libs/nvdsinferserver/infer_trtis_server.h.
◆ classParams() [1/2]
const std::map<std::string, TritonClassParams>& nvdsinferserver::TrtServerRequest::classParams ( ) const
inline
Definition at line 161 of file sources/libs/nvdsinferserver/infer_trtis_server.h.
◆ classParams() [2/2]
inline
Definition at line 161 of file 9.0/sources/libs/nvdsinferserver/infer_trtis_server.h.
◆ id() [1/2]
uint64_t nvdsinferserver::TrtServerRequest::id ( ) const
inline
Get the request ID.
Definition at line 143 of file 9.0/sources/libs/nvdsinferserver/infer_trtis_server.h.
◆ id() [2/2]
inline
Get the request ID.
Definition at line 143 of file sources/libs/nvdsinferserver/infer_trtis_server.h.
◆ init() [1/2]
NvDsInferStatus nvdsinferserver::TrtServerRequest::init ( const std::string &  model,
int64_t  version,
SharedBatchArray inputs,
const std::vector< std::string > &  outputs,
uint64_t  reqId,
const std::vector< TritonClassParams > &  clasList
protected
Parameters
[in]modelModel name.
[in]versionModel version.
[in]inputsArray of input batch buffers.
[in]outputsList of names of required output tensors.
[in]reqIdID of this request.
[in]clasListTriton classification parameters, if any.
Returns
NVDSINFER_SUCCESS or NVDSINFER_TRITON_ERROR.
◆ init() [2/2]
int64_t  version,
uint64_t  reqId,
protected
Parameters
Returns
◆ model() [1/2]
const std::string& nvdsinferserver::TrtServerRequest::model ( ) const
inline
Get the model name.
Definition at line 139 of file 9.0/sources/libs/nvdsinferserver/infer_trtis_server.h.
◆ model() [2/2]
inline
Get the model name.
Definition at line 139 of file sources/libs/nvdsinferserver/infer_trtis_server.h.
◆ outputs() [1/2]
const std::vector<std::string>& nvdsinferserver::TrtServerRequest::outputs ( ) const
inline
Definition at line 156 of file sources/libs/nvdsinferserver/infer_trtis_server.h.
◆ outputs() [2/2]
inline
Definition at line 156 of file 9.0/sources/libs/nvdsinferserver/infer_trtis_server.h.
◆ ptr() [1/2]
TRITONSERVER_InferenceRequest* nvdsinferserver::TrtServerRequest::ptr ( )
inline
Definition at line 135 of file sources/libs/nvdsinferserver/infer_trtis_server.h.
◆ ptr() [2/2]
inline
Definition at line 135 of file 9.0/sources/libs/nvdsinferserver/infer_trtis_server.h.
◆ releaseInputs() [1/2]
SharedBatchArray nvdsinferserver::TrtServerRequest::releaseInputs ( )
inline
Returns
Shared pointer to the input array.
Definition at line 152 of file sources/libs/nvdsinferserver/infer_trtis_server.h.
◆ releaseInputs() [2/2]
inline
Returns
Definition at line 152 of file 9.0/sources/libs/nvdsinferserver/infer_trtis_server.h.
◆ RequestOnRelease() [1/2]
static void nvdsinferserver::TrtServerRequest::RequestOnRelease ( TRITONSERVER_InferenceRequest *  request,
void *  userp
staticprotected
Parameters
[in]requestPointer to the request.
[in]flagsFlags associated with the callback.
[in]userpUser data pointer.
◆ RequestOnRelease() [2/2]
void *  userp
staticprotected
Parameters
◆ setRequestComplete() [1/2]
NvDsInferStatus nvdsinferserver::TrtServerRequest::setRequestComplete ( TRITONSERVER_InferenceRequestReleaseFn_t  requestCompleteCb,
void *  userPtr
protected
Parameters
[in]requestCompleteCbThe request release callback function.
[in]userPtrThe user data pointer for the callback.
Returns
◆ setRequestComplete() [2/2]
void *  userPtr
protected
Parameters
Returns
◆ setResponseComplete() [1/2]
NvDsInferStatus nvdsinferserver::TrtServerRequest::setResponseComplete ( ShrTritonAllocator allocator,
void *  responseUserPtr
protected
Parameters
[in]allocatorPointer to the output allocator instance.
[in]responseCompleteCbThe response callback function.
[in]responseUserPtrThe user data pointer.
Returns
◆ setResponseComplete() [2/2]
protected
Parameters
Returns
Friends And Related Function Documentation
◆ TrtISServer
