sources/includes/nvds_roi_meta.h
1 /*
2  * SPDX-FileCopyrightText: Copyright (c) 2021-2025 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
4  *
11  */
12
28 #ifndef __NVDS_ROI_META_H__
29 #define __NVDS_ROI_META_H__
30
31 #include "nvdsmeta.h"
32
34 #define DS_MAX_POLYGON_POINTS 8
35
38
41
44
46 typedef GList NvDsClassifierMetaList;
47
49 typedef GList NvDsUserMetaList;
50
54 typedef enum
55 {
72 } NvDsDataType;
73
77 typedef enum
78 {
85 } NvDsUnitType;
86
90 typedef struct NvDsRoiMeta
91 {
92  /* per roi information */
94
97
98  /* Scaled & converted buffer to processing width/height */
100
101  /* Deepstream frame meta */
103
107  gdouble scale_ratio_x;
108
112  gdouble scale_ratio_y;
113
115  gdouble offset_left;
116
118  gdouble offset_top;
119
122
125
126  /* Deepstream object meta */
128
129 } NvDsRoiMeta;
130
131 #endif
_NvOSD_RectParams
Holds the box parameters of the box to be overlayed.
Definition: sources/includes/nvll_osd_struct.h:140
NvDsRoiMeta
struct NvDsRoiMeta NvDsRoiMeta
Holds Information about ROI Metadata.
NvDsUnitType_Object
@ NvDsUnitType_Object
object mode
Definition: sources/includes/nvds_roi_meta.h:84
NvDsUnitType_ROI
@ NvDsUnitType_ROI
Region of Interests (ROIs)
Definition: sources/includes/nvds_roi_meta.h:82
NvDsDataType_INT32
@ NvDsDataType_INT32
INT32 data type.
Definition: sources/includes/nvds_roi_meta.h:65
NvDsRoiMeta::offset_left
gdouble offset_left
offsets in horizontal direction while scaling
Definition: sources/includes/nvds_roi_meta.h:115
NvDsDataType_INT8
@ NvDsDataType_INT8
INT8 data type.
Definition: sources/includes/nvds_roi_meta.h:61
NvDsDataType_FP16
@ NvDsDataType_FP16
FP16 data type.
Definition: sources/includes/nvds_roi_meta.h:71
NvDsDataType_UINT32
@ NvDsDataType_UINT32
UINT32 data type.
Definition: sources/includes/nvds_roi_meta.h:63
NvDsRoiMeta::converted_buffer
NvBufSurfaceParams * converted_buffer
Definition: sources/includes/nvds_roi_meta.h:99
NvDsDataType_INT64
@ NvDsDataType_INT64
INT64 data type.
Definition: sources/includes/nvds_roi_meta.h:67
NvDsDataType_UINT8
@ NvDsDataType_UINT8
UINT8 data type.
Definition: sources/includes/nvds_roi_meta.h:59
NvBufSurfaceParams
Hold the information of single buffer in the batch.
Definition: sources/includes/nvbufsurface.h:562
NvDsUnitType
NvDsUnitType
Unit Type Fullframe/ROI/Crop Objects.
Definition: sources/includes/nvds_roi_meta.h:77
classifier meta list
Definition: sources/includes/nvds_roi_meta.h:46
NvDsRoiMeta::scale_ratio_x
Ratio by which the frame/ROI crop was scaled in horizontal direction Required when scaling co-ordinat...
Definition: sources/includes/nvds_roi_meta.h:107
NvDsUserMetaList
user meta list
Definition: sources/includes/nvds_roi_meta.h:49
NvDsDataType_UINT64
@ NvDsDataType_UINT64
UINT64 data type.
Definition: sources/includes/nvds_roi_meta.h:69
NvDsRoiMeta::classifier_meta_list
NvDsClassifierMetaList * classifier_meta_list
Holds a pointer to a list of pointers of type NvDsClassifierMeta.
Definition: sources/includes/nvds_roi_meta.h:121
NvDsRoiMeta::roi
NvOSD_RectParams roi
Definition: sources/includes/nvds_roi_meta.h:93
NvDsRoiMeta::offset_top
gdouble offset_top
offsets in vertical direction while scaling
Definition: sources/includes/nvds_roi_meta.h:118
NvDsRoiMeta::scale_ratio_y
Ratio by which the frame/ROI crop was scaled in vertical direction Required when scaling co-ordinates...
Definition: sources/includes/nvds_roi_meta.h:112
NvDsRoiMeta::frame_meta
NvDsFrameMeta * frame_meta
Definition: sources/includes/nvds_roi_meta.h:102
NvDsUserMetaList
Definition: sources/includes/nvdsmeta.h:57
max polygon points ; currently not being used
Definition: sources/includes/nvds_roi_meta.h:34
NvDsRoiMeta::roi_polygon
guint roi_polygon[DS_MAX_POLYGON_POINTS][2]
Definition: sources/includes/nvds_roi_meta.h:96
NvDsRoiMeta
Definition: sources/includes/nvds_roi_meta.h:90
NvDsDataType_FP32
@ NvDsDataType_FP32
FP32 data type.
Definition: sources/includes/nvds_roi_meta.h:57
NvDsRoiMeta::roi_user_meta_list
NvDsUserMetaList * roi_user_meta_list
Holds a pointer to a list of pointers of type NvDsUserMeta.
Definition: sources/includes/nvds_roi_meta.h:124
_NvDsFrameMeta
Holds metadata for a frame in a batch.
Definition: sources/includes/nvdsmeta.h:301
nvdsmeta.h
NvDsRoiMeta::object_meta
NvDsObjectMeta * object_meta
Definition: sources/includes/nvds_roi_meta.h:127
NvDsUnitType_FullFrame
@ NvDsUnitType_FullFrame
Full frames.
Definition: sources/includes/nvds_roi_meta.h:80
Definition: sources/includes/nvdsmeta.h:60
NvDsDataType
NvDsDataType
Data type used for model in infer.
Definition: sources/includes/nvds_roi_meta.h:54
_NvDsObjectMeta
Holds metadata for an object in the frame.
Definition: sources/includes/nvdsmeta.h:360
