_NvDsObjectMeta Struct Reference
Holds metadata for an object in the frame.
Definition at line 360 of file sources/includes/nvdsmeta.h.
Collaboration diagram for _NvDsObjectMeta:
Data Fields
NvDsBaseMeta base_meta
struct _NvDsObjectMetaparent
 Holds a pointer to the parent NvDsObjectMeta. More...
gint unique_component_id
 Holds a unique component ID that identifies the metadata in this structure. More...
gint class_id
 Holds the index of the object class inferred by the primary detector/classifier. More...
guint64 object_id
 Holds a unique ID for tracking the object. More...
NvDsComp_BboxInfo detector_bbox_info
 Holds a structure containing bounding box parameters of the object when detected by detector. More...
NvDsComp_BboxInfo tracker_bbox_info
 Holds a structure containing bounding box coordinates of the object when processed by tracker. More...
gfloat confidence
 Holds a confidence value for the object, set by the inference component. More...
gfloat tracker_confidence
 Holds a confidence value for the object set by nvdcf_tracker. More...
NvOSD_RectParams rect_params
 Holds a structure containing positional parameters of the object processed by the last component that updates it in the pipeline. More...
NvOSD_MaskParams mask_params
 Holds mask parameters for the object. More...
NvOSD_TextParams text_params
 Holds text describing the object. More...
gchar obj_label [MAX_LABEL_SIZE]
 Holds a string describing the class of the detected object. More...
NvDsClassifierMetaListclassifier_meta_list
 Holds a pointer to a list of pointers of type NvDsClassifierMeta. More...
NvDsUserMetaListobj_user_meta_list
 Holds a pointer to a list of pointers of type NvDsUserMeta. More...
gint64 misc_obj_info [MAX_USER_FIELDS]
 Holds additional user-defined object information. More...
gint64 reserved [MAX_RESERVED_FIELDS]
 For internal use. More...
Field Documentation
◆ base_meta
NvDsBaseMeta _NvDsObjectMeta::base_meta
Definition at line 361 of file sources/includes/nvdsmeta.h.
◆ class_id
gint _NvDsObjectMeta::class_id
Definition at line 370 of file sources/includes/nvdsmeta.h.
◆ classifier_meta_list
NvDsClassifierMetaList * _NvDsObjectMeta::classifier_meta_list
Definition at line 406 of file sources/includes/nvdsmeta.h.
◆ confidence
gfloat _NvDsObjectMeta::confidence
confidence will be set to -0.1, if "Group Rectangles" mode of clustering is chosen since the algorithm does not preserve confidence values. Also, for objects found by tracker and not inference component, confidence will be set to -0.1
Definition at line 385 of file sources/includes/nvdsmeta.h.
◆ detector_bbox_info
NvDsComp_BboxInfo _NvDsObjectMeta::detector_bbox_info
Definition at line 376 of file sources/includes/nvdsmeta.h.
◆ mask_params
NvOSD_MaskParams _NvDsObjectMeta::mask_params
This mask is overlayed on object
See also
NvOSD_MaskParams.
Definition at line 399 of file sources/includes/nvdsmeta.h.
◆ misc_obj_info
gint64 _NvDsObjectMeta::misc_obj_info
Definition at line 410 of file sources/includes/nvdsmeta.h.
◆ obj_label
gchar _NvDsObjectMeta::obj_label
Definition at line 404 of file sources/includes/nvdsmeta.h.
◆ obj_user_meta_list
NvDsUserMetaList * _NvDsObjectMeta::obj_user_meta_list
Definition at line 408 of file sources/includes/nvdsmeta.h.
◆ object_id
guint64 _NvDsObjectMeta::object_id
UNTRACKED_OBJECT_ID indicates that the object has not been tracked.
Definition at line 373 of file sources/includes/nvdsmeta.h.
◆ parent
struct _NvDsObjectMeta * _NvDsObjectMeta::parent
Set to NULL if no parent exists.
Definition at line 364 of file sources/includes/nvdsmeta.h.
◆ rect_params
NvOSD_RectParams _NvDsObjectMeta::rect_params
e.g. If the tracker component is after the detector component in the pipeline then positinal parameters are from tracker component. Positional parameters are clipped so that they do not fall outside frame boundary. Can also be used to overlay borders or semi-transparent boxes on objects.
See also
NvOSD_RectParams.
Definition at line 396 of file sources/includes/nvdsmeta.h.
◆ reserved
gint64 _NvDsObjectMeta::reserved
For internal use.
Definition at line 412 of file sources/includes/nvdsmeta.h.
◆ text_params
NvOSD_TextParams _NvDsObjectMeta::text_params
This text can be overlayed on the standard text that identifies the object.
See also
NvOSD_TextParams.
Definition at line 402 of file sources/includes/nvdsmeta.h.
◆ tracker_bbox_info
NvDsComp_BboxInfo _NvDsObjectMeta::tracker_bbox_info
Definition at line 379 of file sources/includes/nvdsmeta.h.
◆ tracker_confidence
gfloat _NvDsObjectMeta::tracker_confidence
tracker_confidence will be set to -0.1 for KLT and IOU tracker
Definition at line 388 of file sources/includes/nvdsmeta.h.
◆ unique_component_id
gint _NvDsObjectMeta::unique_component_id
Definition at line 367 of file sources/includes/nvdsmeta.h.
