28 #ifndef __NVDSPREPROCESS_INTERFACE_H__
29 #define __NVDSPREPROCESS_INTERFACE_H__
32 #include <cuda_runtime.h>
33 #include "nvbufsurface.h"
34 #include "nvbufsurftransform.h"
35 #include "gstnvdsmeta.h"
37 #include "nvds_roi_meta.h"
38 #include "nvtx3/nvToolsExt.h"
39 #include <unordered_map>
139 guint64 buffer_size = 1;
229 guint batch_index = 0;
231 gulong frame_num = 0;
238 gpointer converted_frame_ptr =
nullptr;
250 std::vector<NvDsPreProcessUnit>
units;
256 gulong inbuf_batch_num = 0;
261 gboolean push_buffer = FALSE;
265 gboolean event_marker = FALSE;
275 nvtxRangeId_t nvtx_complete_buf_range = 0;
278 #endif //__NVDSPREPROCESS_INTERFACE_H__
@ NvDsPreProcessFormat_Unknown
NvDsDataType data_type
DataType for tensor formation.
Custom Initialization parameter for custom library.
NvDsPreProcessNetworkInputOrder network_input_order
network order at which model will work
struct NvBufSurfTransformSyncObj * NvBufSurfTransformSyncObj_t
Holds the information about synchronization objects for asynchronous transform/composite APIs.
@ NVDSPREPROCESS_CUSTOM_LIB_FAILED
Custom Library interface implementation failed.
virtual gboolean release(NvDsPreProcessCustomBuf *)=0
method to release buffer from buffer pool
NvDsRoiMeta roi_meta
New meta for rois provided.
@ NVDSPREPROCESS_CONFIG_FAILED
Failed to configure the tensor_impl instance possibly due to an erroneous initialization property.
@ NvDsPreProcessFormat_RGB
Specifies 24-bit interleaved R-G-B format.
@ NvDsPreProcessNetworkInputOrder_kNHWC
Specifies NHWC network input order.
@ NVDSPREPROCESS_TENSOR_NOT_READY
Tensor Yet not ready to be attached as meta.
@ NVDSPREPROCESS_RESOURCE_ERROR
Resource error was encountered.
NvDsBatchMeta * batch_meta
Deepstream batch meta.
Holds information about the batch of frames to be inferred.
@ NvDsPreProcessFormat_RGBA
Specifies 32-bit interleaved R-G-B-A format.
unsigned int height
Holds the input height for the model.
@ NvDsPreProcessFormat_GRAY
Specifies 8-bit Luma format.
std::unordered_map< std::string, std::string > user_configs
User config map key-value pair.
@ NVDSPREPROCESS_INVALID_PARAMS
Invalid parameters were supplied.
NvDsPreProcessStatus
Enum for the status codes returned by NvDsPreProcessImpl.
@ NVDSPREPROCESS_SUCCESS
NvDsPreprocess operation succeeded.
NvDsPreProcessFormat network_color_format
Holds the network input format.
std::vector< NvDsRoiMeta > roi_vector
vector of rois which can be modified by custom lib
std::vector< NvBufSurfTransformSyncObj_t > sync_objects
Vector of sync objects for async transformation of the batch.
NvBufSurfaceMemType memory_type
Memory Type for tensor formation.
CustomSeqProcTensorParams seq_params
Additional Custom Parameters.
Hold the information of single buffer in the batch.
@ NvDsPreProcessFormat_Tensor
NCHW planar.
uint32_t pitch
Holds the pitch of the buffer.
@ NVDSPREPROCESS_CUSTOM_TENSOR_FAILED
Custom Tensor Preparation failed.
A preprocess unit for processing which can be Frame/ROI.
unsigned int width
Holds the input width for the model.
@ NVDSPREPROCESS_TENSORRT_ERROR
TensorRT interface failed.
Tensor params passed to custom library for tensor preparation.
std::vector< NvDsPreProcessUnit > units
Vector of units in the batch.
@ NVDSPREPROCESS_CUSTOM_TRANSFORMATION_FAILED
Custom Group Transformation failed.
NvDsPreProcessFormat scaling_pool_format
scaling pool color format
Custom Buffer passed to the custom lib for preparing tensor.
class for acquiring and releasing a buffer from tensor pool by custom lib.
NvBufSurfaceMemType
Specifies memory types for NvBufSurface.
std::vector< int > network_input_shape
Hold the network shape - interpreted based on network input order For resnet10 : NCHW = infer-batch-s...
NvDsPreProcessTensorParams tensor_params
tensor params from read from config file
Holds model parameters for tensor preparation.
gchar * config_file_path
nvdspreprocess config file path
NvDsPreProcessTensorParams params
tensor params from plugin
Enum for the network input order according to which network shape will be provided to prepare raw ten...
@ NvDsPreProcessFormat_BGRx
Specifies 32-bit interleaved B-G-R-x format.
guint unique_id
unique id of the preprocess plugin
@ NvDsPreProcessNetworkInputOrder_kNCHW
Specifies NCHW network input order.
std::string tensor_name
Name of the tensor same as input layer name of model.
unsigned int channels
Holds the number of input channels for the model.
@ NvDsPreProcessNetworkInputOrder_CUSTOM
Specifies any other custom input order handled by custom lib.
struct CustomCtx CustomCtx
Context for custom library.
Specifies 24-bit interleaved B-G-R format.
@ NVDSPREPROCESS_OUTPUT_PARSING_FAILED
Output parsing failed.
Defines model color formats.
@ NVDSPREPROCESS_CUDA_ERROR
CUDA error was encountered.
virtual NvDsPreProcessCustomBuf * acquire()=0
method to acquire a buffer from buffer pool
NvDsDataType
Data type used for model in infer.
Tensor params for Custom sequence processing for 3d conv network.
struct _GstBuffer GstBuffer
void * memory_ptr
memory ptr where to store prepared tensor
