7.1 Release
28 #ifndef __NVDSPREPROCESS_META_H__
29 #define __NVDSPREPROCESS_META_H__
NvDsDataType data_type
model datatype for which tensor prepared
guint gpu_id
gpu-id on which tensor prepared
std::vector< guint64 > target_unique_ids
target unique ids for which meta is prepared
guint meta_id
meta id for differentiating between multiple tensor meta from same gst buffer,for the case when sum o...
std::vector< NvDsRoiMeta > roi_vector
list of roi vectors per batch
std::string tensor_name
to be same as model input layer name
void * private_data
pointer to buffer from scaling pool
std::vector< int > tensor_shape
raw tensor buffer shape
guint64 buffer_size
size of raw tensor buffer
gboolean maintain_aspect_ratio
parameter to inform whether aspect ratio is maintained in the preprocess tensor
void * raw_tensor_buffer
raw tensor buffer preprocessed for infer
void * private_data
pointer to buffer from tensor pool
NvDsPreProcessTensorMeta * tensor_meta
pointer to tensor meta
NvDsDataType
Data type used for model in infer.
