8.0 Release
28 #ifndef __NVDS_ROI_META_H__
29 #define __NVDS_ROI_META_H__
34 #define DS_MAX_POLYGON_POINTS 8
Holds the box parameters of the box to be overlayed.
struct NvDsRoiMeta NvDsRoiMeta
Holds Information about ROI Metadata.
NvDsObjectMeta * object_meta
@ NvDsUnitType_Object
object mode
@ NvDsUnitType_ROI
Region of Interests (ROIs)
@ NvDsDataType_INT32
INT32 data type.
gdouble offset_left
offsets in horizontal direction while scaling
@ NvDsDataType_INT8
INT8 data type.
@ NvDsDataType_FP16
FP16 data type.
@ NvDsDataType_UINT32
UINT32 data type.
@ NvDsDataType_INT64
INT64 data type.
@ NvDsDataType_UINT8
UINT8 data type.
NvDsUserMetaList * roi_user_meta_list
Holds a pointer to a list of pointers of type NvDsUserMeta.
NvDsClassifierMetaList * classifier_meta_list
Holds a pointer to a list of pointers of type NvDsClassifierMeta.
Hold the information of single buffer in the batch.
NvDsUnitType
Unit Type Fullframe/ROI/Crop Objects.
GList NvDsClassifierMetaList
classifier meta list
gdouble scale_ratio_x
Ratio by which the frame/ROI crop was scaled in horizontal direction Required when scaling co-ordinat...
GList NvDsUserMetaList
user meta list
@ NvDsDataType_UINT64
UINT64 data type.
NvDsFrameMeta * frame_meta
gdouble offset_top
offsets in vertical direction while scaling
gdouble scale_ratio_y
Ratio by which the frame/ROI crop was scaled in vertical direction Required when scaling co-ordinates...
guint roi_polygon[DS_MAX_POLYGON_POINTS][2]
currently not being used
max polygon points ; currently not being used
NvBufSurfaceParams * converted_buffer
@ NvDsDataType_FP32
FP32 data type.
@ NvDsUnitType_FullFrame
Full frames.
NvDsDataType
Data type used for model in infer.
