        | NVIDIA DeepStream SDK API Reference |
                8.0 Release
   22 #ifndef __NVDSINFERSERVER_GRPC_BACKEND_H__
   23 #define __NVDSINFERSERVER_GRPC_BACKEND_H__
   40         m_RequestOutputs = names;
   42     void setUrl (
const std::string &url) { m_Url = url;}
   44         m_EnableCudaBufferSharing = enableSharing;
   62     std::set<std::string> m_RequestOutputs;
   63     std::shared_ptr<nvdsinferserver::InferGrpcClient> m_InferGrpcClient;
   64     bool m_EnableCudaBufferSharing =
false;
void setEnableCudaBufferSharing(const bool enableSharing)
NvDsInferStatus initialize() override
const std::string & model() const
Header file of Triton Inference Server inference backend.
std::function< void(SharedBatchArray)> InputsConsumed
Function wrapper called after the input buffer is consumed.
Triton backend processing class.
Header file for the gRPC client and request class for inference using the Triton Inference Server....
NvDsInferStatus ensureServerReady() override
void requestTritonOutputNames(std::set< std::string > &names) override
std::function< void(NvDsInferStatus, SharedBatchArray)> AsyncDone
Asynchronous inference done function: AsyncDone(Status, outputs).
NvDsInferStatus ensureModelReady() override
NvDsInferStatus setupLayersInfo() override
NvDsInferStatus Run(SharedBatchArray inputs, InputsConsumed bufConsumed, AsyncDone asyncDone) override
void setOutputs(const std::set< std::string > &names)
std::function< void(NvDsInferStatus, SharedBatchArray)> InferenceDone
Function wrapper for post inference processing.
NvDsInferStatus enqueue(SharedBatchArray inputs, SharedCuStream stream, InputsConsumed bufConsumed, InferenceDone inferenceDone) override
~TritonGrpcBackend() override
std::shared_ptr< CudaStream > SharedCuStream
Cuda based pointers.
TritonGrpcBackend(std::string model, int64_t version)
void setUrl(const std::string &url)
Triton gRPC mode backend processing class.
NvDsInferStatus
