7.1 Release
infer_lstm.h
1 /*
2  * SPDX-FileCopyrightText: Copyright (c) 2020-2021 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
4  *
11  */
12
13 #ifndef __INFER_LSTM_CONTROL_H__
14 #define __INFER_LSTM_CONTROL_H__
15
16 #include "infer_base_context.h"
17 #include "infer_common.h"
18 #include "infer_datatypes.h"
19 #include "infer_proto_utils.h"
20 #include "infer_utils.h"
21
22 namespace nvdsinferserver {
23
25 public:
26  LstmController(const ic::LstmParams& params, int devId, int maxBatchSize)
27  {
28  m_Params.CopyFrom(params);
29  m_DevId = devId;
30  m_MaxBatchSize = maxBatchSize;
31  }
32  ~LstmController() = default;
33
37  void notifyError(NvDsInferStatus status);
38  void destroy()
39  {
40  UniqLock locker(m_Mutex);
41  m_InProgress = 0;
42  m_Cond.notify_all();
43  locker.unlock();
44  m_LoopStateMap.clear();
45  m_LstmInputs.clear();
46  }
47
48 private:
49  // check input/output tensor names/dims/datatype must be same
50  NvDsInferStatus checkTensorInfo(BaseBackend& backend);
51  struct LoopState {
52  std::string inputName;
53  SharedCudaTensorBuf inputTensor;
54  SharedBatchBuf outputTensor;
55  bool keepOutputParsing = false;
56  };
57
58 private:
59  ic::LstmParams m_Params;
60  int m_DevId = 0;
61  int m_MaxBatchSize = 1;
62  // map<outputName, loopState>
63  std::unordered_map<std::string, LoopState> m_LoopStateMap;
64  std::vector<SharedCudaTensorBuf> m_LstmInputs;
65  std::atomic<int32_t> m_InProgress{0};
66  std::mutex m_Mutex;
67  std::condition_variable m_Cond;
68  SharedCuEvent m_InputReadyEvent;
69  SharedCuStream m_LstmStream;
70 };
71
72 } // namespace nvdsinferserver
73
74 #endif
nvdsinferserver
Definition: infer_custom_process.h:24
nvdsinferserver::LstmController::destroy
void destroy()
Definition: infer_lstm.h:38
nvdsinferserver::SharedBatchBuf
std::shared_ptr< BaseBatchBuffer > SharedBatchBuf
Common buffer interfaces (internal).
Definition: infer_common.h:71
infer_datatypes.h
Header file for the data types used in the inference processing.
infer_utils.h
nvdsinferserver::LstmController::waitAndGetInputs
NvDsInferStatus waitAndGetInputs(SharedBatchArray &inputs)
infer_common.h
nvdsinferserver::LstmController::~LstmController
~LstmController()=default
Definition: infer_lstm.h:24
infer_proto_utils.h
nvdsinferserver::SharedCuStream
std::shared_ptr< CudaStream > SharedCuStream
Cuda based pointers.
Definition: infer_common.h:84
nvdsinferserver::LstmController::notifyError
nvdsinferserver::LstmController::LstmController
LstmController(const ic::LstmParams &params, int devId, int maxBatchSize)
Definition: infer_lstm.h:26
nvdsinferserver::SharedCuEvent
std::shared_ptr< CudaEvent > SharedCuEvent
Definition: infer_common.h:86
nvdsinferserver::BaseBackend
Base class of inference backend processing.
Definition: infer_base_backend.h:40
nvdsinferserver::LstmController::initInputState
NvDsInferStatus initInputState(BaseBackend &backend)
nvdsinferserver::LstmController::feedbackInputs
NvDsInferStatus feedbackInputs(SharedBatchArray &outTensors)
nvdsinferserver::UniqLock
std::unique_lock< std::mutex > UniqLock
Miscellaneous declarations.
Definition: infer_common.h:108
nvdsinferserver::SharedBatchArray
Definition: infer_common.h:75
Header file of the base class for inference context.
nvdsinferserver::SharedCudaTensorBuf
std::shared_ptr< CudaTensorBuf > SharedCudaTensorBuf
Definition: infer_common.h:91
NvDsInferStatus
NvDsInferStatus
Definition: nvdsinfer.h:220
