        | NVIDIA DeepStream SDK API Reference |
                8.0 Release
   19 #ifndef __NVDSINFER_TRTIS_UTILS_H__
   20 #define __NVDSINFER_TRTIS_UTILS_H__
   32 #include "model_config.pb.h"
   40 #define CHECK_TRTIS_ERR_W_ACTION(trtisExpr, action, fmt, ...)              \
   42         UniqTritonT<TRITONSERVER_Error> errPtr(                            \
   43             (trtisExpr), TRITONSERVER_ErrorDelete);                        \
   46                 "Triton: " fmt ", triton_err_str:%s, err_msg:%s",          \
   47                 ##__VA_ARGS__, TRITONSERVER_ErrorCodeString(errPtr.get()), \
   48                 TRITONSERVER_ErrorMessage(errPtr.get()));                  \
   57 #define RETURN_TRTIS_ERROR(trtisExpr, fmt, ...) \
   58     CHECK_TRTIS_ERR_W_ACTION(trtisExpr, return NVDSINFER_TRITON_ERROR, fmt, ##__VA_ARGS__)
   64 #define CONTINUE_TRTIS_ERROR(trtisExpr, fmt, ...) \
   65     CHECK_TRTIS_ERR_W_ACTION(trtisExpr, , fmt, ##__VA_ARGS__)
   67 namespace ni = inference;
  129 template <
typename VecDims>
  136     for (
const auto &v : shape) {
InferMemType MemTypeFromTriton(TRITONSERVER_MemoryType type)
Maps the TRITONSERVER_MemoryType to the InferMemType.
InferDataType
Datatype of the tensor buffer.
InferDataType DataTypeFromTritonPb(ni::DataType type)
Maps the data type from Triton model configuration proto definition to InferDataType.
Header file for the data types used in the inference processing.
InferTensorOrder
The type of tensor order.
enum TRITONSERVER_memorytype_enum TRITONSERVER_MemoryType
TRITONSERVER_MemoryType.
TRITONSERVER_DataType DataTypeToTriton(InferDataType type)
Maps the InferDataType to TRITONSERVER_DataType.
void normalizeDims(InferDims &dims)
InferDataType DataTypeFromTriton(TRITONSERVER_DataType type)
Maps the TRITONSERVER_DataType to the InferDataType.
const char * TritonControlModeToStr(int32_t mode)
Returns a string describing the TRITONSERVER_ModelControlMode: none, explicit or poll.
InferDims DimsFromTriton(const VecDims &shape)
Converts the input shape vector from Triton to InferDims type.
bool hasWildcard(const nvinfer1::Dims &dims)
#define NVDSINFER_MAX_DIMS
enum TRITONSERVER_datatype_enum TRITONSERVER_DataType
InferMemType
The memory types of inference buffers.
Holds the information about the dimensions of a neural network layer.
InferTensorOrder TensorOrderFromTritonPb(ni::ModelInput::Format order)
Maps the tensor order from Triton model configuration proto definition to the InferTensorOrder type.
InferTensorOrder TensorOrderFromTritonMeta(const std::string &format)
Maps the tensor order from Triton metadata string to the InferTensorOrder type.
TRITONSERVER_MemoryType MemTypeToTriton(InferMemType type)
Maps the InferMemType to the TRITONSERVER_MemoryType.
static std::string format(const char *fmt,...)
