7.1 Release
nvds_latency_meta.h File Reference
Defines Latency API
Description: This file defines an API for measuring module latency.
Definition in file nvds_latency_meta.h.
Data Structures
struct  _NvDsMetaSubCompLatency
 Holds information about latency of the given subcomponent. More...
struct  _NvDsMetaCompLatency
 Holds information about latency of the given component. More...
struct  NvDsFrameLatencyInfo
 Holds information about the latency of a given frame. More...
Macros
#define MAX_COMPONENT_LEN   64
#define nvds_enable_latency_measurement   (nvds_get_enable_latency_measurement())
 Defines a pseudo-variable whose value is the return value of nvds_get_enable_latency_measurement(). More...
Typedefs
typedef struct _NvDsMetaSubCompLatency NvDsMetaSubCompLatency
typedef struct _NvDsMetaCompLatency NvDsMetaCompLatency
Functions
NvDsUserMetanvds_set_input_system_timestamp (GstBuffer *buffer, gchar *element_name)
 Sets the system timestamp when the Gst Buffer arrives as input at the component. More...
gboolean nvds_set_output_system_timestamp (GstBuffer *buffer, gchar *element_name)
 Sets the system timestamp when a Gst Buffer that is pushed to the downstream component. More...
guint nvds_measure_buffer_latency (GstBuffer *buf, NvDsFrameLatencyInfo *latency_info)
 Measures the latency of all frames present in the current batch. More...
gboolean nvds_get_enable_latency_measurement (void)
 Indicates whether the environment variable NVDS_ENABLE_LATENCY_MEASUREMENT is exported. More...
void nvds_add_reference_timestamp_meta (GstBuffer *buffer, gchar *element_name, guint frame_id)
 Adds the reference timestamp metadata for this buffer Note: element_name == "audiodecoder" and "nvv4l2decoder" will be used for latency measurement calculations where the timestamp will be used by API: nvds_measure_buffer_latency() to calculate the latency of buffers downstream relative to the decoder. More...
