NVIDIA DeepStream inference specifications
Description: This file defines common elements used in the API exposed by the Gst-nvinfer plugin.
Definition in file nvdsinfer.h.
Data Structures | |
| struct | NvDsInferDims |
| Holds the dimensions of a layer. More... | |
| struct | NvDsInferDimsCHW |
| Holds the dimensions of a three-dimensional layer. More... | |
| struct | NvDsInferLayerInfo |
| Holds information about one layer in the model. More... | |
| struct | NvDsInferNetworkInfo |
| Holds information about the model network. More... | |
| struct | NvDsInferObjectDetectionInfo |
| Holds information about one parsed object from a detector's output. More... | |
| struct | NvDsInferInstanceMaskInfo |
| Holds information about one parsed object and instance mask from a detector's output. More... | |
| struct | NvDsInferAttribute |
| Holds information about one classified attribute. More... | |
Macros | |
| #define | NVDSINFER_MAX_DIMS 8 |
| #define | _DS_DEPRECATED_(STR) __attribute__ ((deprecated (STR))) |
| #define | getDimsCHWFromDims(dimsCHW, dims) |
| Sets values on a NvDsInferDimsCHW structure from a NvDsInferDims structure. More... | |
| #define | getDimsHWCFromDims(dimsCHW, dims) |
Typedefs | |
| typedef NvDsInferObjectDetectionInfo | NvDsInferParseObjectInfo |
| A typedef defined to maintain backward compatibility. More... | |
Enumerations | |
| enum | NvDsInferDataType { FLOAT = 0, HALF = 1, INT8 = 2, INT32 = 3, INT64 = 4, UINT8 = 5 } |
| Specifies the data type of a layer. More... | |
| enum | NvDsInferStatus { NVDSINFER_SUCCESS = 0, NVDSINFER_CONFIG_FAILED, NVDSINFER_CUSTOM_LIB_FAILED, NVDSINFER_INVALID_PARAMS, NVDSINFER_OUTPUT_PARSING_FAILED, NVDSINFER_CUDA_ERROR, NVDSINFER_TENSORRT_ERROR, NVDSINFER_RESOURCE_ERROR, NVDSINFER_TRITON_ERROR, NVDSINFER_TRTIS_ERROR = NVDSINFER_TRITON_ERROR, NVDSINFER_MEM_ERROR, NVDSINFER_UNKNOWN_ERROR } |
| Enum for the status codes returned by NvDsInferContext. More... | |
| enum | NvDsInferLogLevel { NVDSINFER_LOG_ERROR = 0, NVDSINFER_LOG_WARNING, NVDSINFER_LOG_INFO, NVDSINFER_LOG_DEBUG } |
| Enum for the log levels of NvDsInferContext. More... | |
Functions | |
| const char * | NvDsInferStatus2Str (NvDsInferStatus status) |
| Get the string name for the status. More... | |
