7.1 Release
nvll_osd_api.h File Reference
NVIDIA Multimedia Utilities: On-Screen Display API
This file defines the NvOSD library, used to draw rectangles and text over the frame.
Definition in file nvll_osd_api.h.
Data Structures
struct  _NvOSD_FrameTextParams
 Holds information about the text in a frame. More...
struct  _NvOSD_FrameRectParams
 Holds information about the rectangles in a frame. More...
struct  _NvOSD_FrameSegmentMaskParams
struct  _NvOSD_FrameLineParams
 Holds information about the lines in a frame. More...
struct  _NvOSD_FrameArrowParams
 Holds information about the arrows in a frame. More...
struct  _NvOSD_FrameCircleParams
 Holds information about the circles in a frame. More...
Macros
#define NVOSD_PRINT_E(f_, ...)   printf("libnvosd (%d):(ERROR) : " f_, __LINE__, ##__VA_ARGS__)
#define MAX_IN_BUF   16
#define MAX_BORDER_WIDTH   32
Typedefs
typedef void * NvOSDCtxHandle
typedef struct _NvOSD_FrameTextParams NvOSD_FrameTextParams
typedef struct _NvOSD_FrameRectParams NvOSD_FrameRectParams
typedef struct _NvOSD_FrameSegmentMaskParams NvOSD_FrameSegmentMaskParams
typedef struct _NvOSD_FrameLineParams NvOSD_FrameLineParams
typedef struct _NvOSD_FrameArrowParams NvOSD_FrameArrowParams
typedef struct _NvOSD_FrameCircleParams NvOSD_FrameCircleParams
Functions
NvOSDCtxHandle nvll_osd_create_context (void)
 Creates an NvOSD context. More...
void nvll_osd_destroy_context (NvOSDCtxHandle nvosd_ctx)
 Destroys an NvOSD context. More...
void nvll_osd_set_clock_params (NvOSDCtxHandle nvosd_ctx, NvOSD_TextParams *clk_params)
 Sets clock parameters for a given context. More...
int nvll_osd_put_text (NvOSDCtxHandle nvosd_ctx, NvOSD_FrameTextParams *frame_text_params)
 /brief Overlays clock and given text at a given location in a buffer. More...
int nvll_osd_draw_segment_masks (NvOSDCtxHandle nvosd_ctx, NvOSD_FrameSegmentMaskParams *frame_mask_params)
 Overlays segment masks at a given location in a buffer. More...
int nvll_osd_draw_rectangles (NvOSDCtxHandle nvosd_ctx, NvOSD_FrameRectParams *frame_rect_params)
 Overlays boxes at a given location in a buffer. More...
int nvll_osd_draw_lines (NvOSDCtxHandle nvosd_ctx, NvOSD_FrameLineParams *frame_line_params)
 Overlays lines on the buffer. More...
int nvll_osd_draw_arrows (NvOSDCtxHandle nvosd_ctx, NvOSD_FrameArrowParams *frame_arrow_params)
 Overlays arrows on the buffer. More...
int nvll_osd_draw_circles (NvOSDCtxHandle nvosd_ctx, NvOSD_FrameCircleParams *frame_circle_params)
 Overlays circles on the buffer. More...
void * nvll_osd_set_params (NvOSDCtxHandle nvosd_ctx, int width, int height)
 Sets the resolution of the frames on which the NvOSDContext is to operate. More...
int nvll_osd_init_colors_for_hw_blend (void *nvosd_ctx, NvOSD_Color_info *color_info, int num_classes)
 Initializes colors for HW based blending. More...
int nvll_osd_apply (NvOSDCtxHandle nvosd_ctx, NvBufSurfaceParams *buf_ptr, NvBufSurface *surf)
 Apply OSD to the video frame for GPU backend. More...
