sources/includes/nvdsinfer.h File Reference
NVIDIA DeepStream inference specifications
Description: This file defines common elements used in the API exposed by the Gst-nvinfer plugin.
Definition in file sources/includes/nvdsinfer.h.
Data Structures
struct  NvDsInferDims
 Holds the dimensions of a layer. More...
struct  NvDsInferDimsCHW
 Holds the dimensions of a three-dimensional layer. More...
struct  NvDsInferLayerInfo
 Holds information about one layer in the model. More...
struct  NvDsInferNetworkInfo
 Holds information about the model network. More...
struct  NvDsInferObjectDetectionInfo
 Holds information about one parsed object from a detector's output. More...
struct  NvDsInferInstanceMaskInfo
 Holds information about one parsed object and instance mask from a detector's output. More...
struct  NvDsInferAttribute
 Holds information about one classified attribute. More...
Macros
#define NVDSINFER_MAX_DIMS   8
#define _DS_DEPRECATED_(STR)   __attribute__ ((deprecated (STR)))
#define getDimsCHWFromDims(dimsCHW, dims)
 Sets values on a NvDsInferDimsCHW structure from a NvDsInferDims structure. More...
#define getDimsHWCFromDims(dimsCHW, dims)
Typedefs
typedef NvDsInferObjectDetectionInfo NvDsInferParseObjectInfo
 A typedef defined to maintain backward compatibility. More...
Enumerations
enum  NvDsInferDataType {
  FLOAT = 0,
  HALF = 1,
  INT8 = 2,
  INT32 = 3,
  INT64 = 4,
  UINT8 = 5,
  FLOAT = 0,
  HALF = 1,
  INT8 = 2,
  INT32 = 3,
  INT64 = 4,
  UINT8 = 5
 Specifies the data type of a layer. More...
enum  NvDsInferStatus {
  NVDSINFER_SUCCESS = 0,
  NVDSINFER_CONFIG_FAILED,
  NVDSINFER_CUSTOM_LIB_FAILED,
  NVDSINFER_INVALID_PARAMS,
  NVDSINFER_OUTPUT_PARSING_FAILED,
  NVDSINFER_CUDA_ERROR,
  NVDSINFER_TENSORRT_ERROR,
  NVDSINFER_RESOURCE_ERROR,
  NVDSINFER_TRITON_ERROR,
  NVDSINFER_TRTIS_ERROR = NVDSINFER_TRITON_ERROR,
  NVDSINFER_MEM_ERROR,
  NVDSINFER_UNKNOWN_ERROR,
 Enum for the status codes returned by NvDsInferContext. More...
enum  NvDsInferLogLevel {
  NVDSINFER_LOG_ERROR = 0,
  NVDSINFER_LOG_WARNING,
  NVDSINFER_LOG_INFO,
  NVDSINFER_LOG_DEBUG,
  NVDSINFER_LOG_INFO,
  NVDSINFER_LOG_DEBUG
 Enum for the log levels of NvDsInferContext. More...
Functions
const char * NvDsInferStatus2Str (NvDsInferStatus status)
 Get the string name for the status. More...
