NVIDIA Multimedia Utilities: On-Screen Display API
This file defines the NvOSD library, used to draw rectangles and text over the frame.
Definition in file sources/includes/nvll_osd_api.h.
Data Structures | |
| struct | _NvOSD_FrameTextParams |
| Holds information about the text in a frame. More... | |
| struct | _NvOSD_FrameRectParams |
| Holds information about the rectangles in a frame. More... | |
| struct | _NvOSD_FrameSegmentMaskParams |
| struct | _NvOSD_FrameLineParams |
| Holds information about the lines in a frame. More... | |
| struct | _NvOSD_FrameArrowParams |
| Holds information about the arrows in a frame. More... | |
| struct | _NvOSD_FrameCircleParams |
| Holds information about the circles in a frame. More... | |
Macros | |
| #define | NVOSD_PRINT_E(f_, ...) printf("libnvosd (%d):(ERROR) : " f_, __LINE__, ##__VA_ARGS__) |
| #define | MAX_IN_BUF 16 |
| #define | MAX_BORDER_WIDTH 32 |
Typedefs | |
| typedef void * | NvOSDCtxHandle |
| typedef struct _NvOSD_FrameTextParams | NvOSD_FrameTextParams |
| typedef struct _NvOSD_FrameRectParams | NvOSD_FrameRectParams |
| typedef struct _NvOSD_FrameSegmentMaskParams | NvOSD_FrameSegmentMaskParams |
| typedef struct _NvOSD_FrameLineParams | NvOSD_FrameLineParams |
| typedef struct _NvOSD_FrameArrowParams | NvOSD_FrameArrowParams |
| typedef struct _NvOSD_FrameCircleParams | NvOSD_FrameCircleParams |
Functions | |
| NvOSDCtxHandle | nvll_osd_create_context (void) |
| Creates an NvOSD context. More... | |
| void | nvll_osd_destroy_context (NvOSDCtxHandle nvosd_ctx) |
| Destroys an NvOSD context. More... | |
| void | nvll_osd_set_clock_params (NvOSDCtxHandle nvosd_ctx, NvOSD_TextParams *clk_params) |
| Sets clock parameters for a given context. More... | |
| int | nvll_osd_put_text (NvOSDCtxHandle nvosd_ctx, NvOSD_FrameTextParams *frame_text_params) |
| /brief Overlays clock and given text at a given location in a buffer. More... | |
| int | nvll_osd_draw_segment_masks (NvOSDCtxHandle nvosd_ctx, NvOSD_FrameSegmentMaskParams *frame_mask_params) |
| Overlays segment masks at a given location in a buffer. More... | |
| int | nvll_osd_blur_rectangles (NvOSDCtxHandle nvosd_ctx, NvOSD_FrameRectParams *frame_rect_params) |
| Blur boxes at a given location in a buffer. More... | |
| int | nvll_osd_draw_rectangles (NvOSDCtxHandle nvosd_ctx, NvOSD_FrameRectParams *frame_rect_params) |
| Overlays boxes at a given location in a buffer. More... | |
| int | nvll_osd_draw_lines (NvOSDCtxHandle nvosd_ctx, NvOSD_FrameLineParams *frame_line_params) |
| Overlays lines on the buffer. More... | |
| int | nvll_osd_draw_arrows (NvOSDCtxHandle nvosd_ctx, NvOSD_FrameArrowParams *frame_arrow_params) |
| Overlays arrows on the buffer. More... | |
| int | nvll_osd_draw_circles (NvOSDCtxHandle nvosd_ctx, NvOSD_FrameCircleParams *frame_circle_params) |
| Overlays circles on the buffer. More... | |
| void * | nvll_osd_set_params (NvOSDCtxHandle nvosd_ctx, int width, int height) |
| Sets the resolution of the frames on which the NvOSDContext is to operate. More... | |
| int | nvll_osd_init_colors_for_hw_blend (void *nvosd_ctx, NvOSD_Color_info *color_info, int num_classes) |
| Initializes colors for HW based blending. More... | |
| int | nvll_osd_apply (NvOSDCtxHandle nvosd_ctx, NvBufSurfaceParams *buf_ptr, NvBufSurface *surf) |
| Apply OSD to the video frame for GPU backend. More... | |
