9.0/sources/includes/nvbufsurftransform.h File Reference
NvBufSurfTransform Interface
This file specifies the NvBufSurfTransform image transformation APIs.
The NvBufSurfTransform API provides methods to set and get session parameters and to transform and composite APIs.
Definition in file 9.0/sources/includes/nvbufsurftransform.h.
Data Structures
struct  NvBufSurfTransformRect
 Holds the coordinates of a rectangle. More...
struct  _NvBufSurfTransformConfigParams
 Holds configuration parameters for a transform/composite session. More...
struct  _NvBufSurfaceTransformParams
 Holds transform parameters for a transform call. More...
struct  _NvBufSurfTransformCompositeParams
 Holds composite parameters for a composite call. More...
struct  _NvBufSurfTransform_ColorParams
struct  _NvBufSurfTransformCompositeBlendParams
 Holds composite blend parameters for a composite blender call. More...
struct  _NvBufSurfTransformCompositeBlendParamsEx
 Holds extended composite blend parameters for NvBufSurfTransformMultiInputBufCompositeBlend and NvBufSurfTransformMultiInputBufCompositeBlendAsync API. More...
Macros
#define NVBUFSURF_MAX_SYNCOBJ   5
 Defines the maximum number of sync objects. More...
Typedefs
typedef struct CUstream_st * cudaStream_t
 Forward declaration of cudaStream_t. More...
typedef struct _NvBufSurfTransformConfigParams NvBufSurfTransformConfigParams
typedef struct _NvBufSurfaceTransformParams NvBufSurfTransformParams
typedef struct _NvBufSurfTransformCompositeParams NvBufSurfTransformCompositeParams
typedef struct _NvBufSurfTransform_ColorParams NvBufSurfTransform_ColorParams
typedef struct _NvBufSurfTransformCompositeBlendParams NvBufSurfTransformCompositeBlendParams
typedef struct _NvBufSurfTransformCompositeBlendParamsEx NvBufSurfTransformCompositeBlendParamsEx
typedef struct NvBufSurfTransformSyncObj * NvBufSurfTransformSyncObj_t
 Holds the information about synchronization objects for asynchronous transform/composite APIs. More...
Enumerations
enum  NvBufSurfTransform_Compute {
  NvBufSurfTransformCompute_Default,
  NvBufSurfTransformCompute_GPU,
  NvBufSurfTransformCompute_VIC,
 Specifies compute devices used by NvBufSurfTransform. More...
enum  NvBufSurfTransform_Flip {
  NvBufSurfTransform_None,
  NvBufSurfTransform_Rotate90,
  NvBufSurfTransform_Rotate180,
  NvBufSurfTransform_Rotate270,
  NvBufSurfTransform_FlipX,
  NvBufSurfTransform_FlipY,
  NvBufSurfTransform_Transpose,
  NvBufSurfTransform_InvTranspose,
 Specifies video flip methods. More...
enum  NvBufSurfTransform_Inter {
  NvBufSurfTransformInter_Nearest = 0,
  NvBufSurfTransformInter_Bilinear,
  NvBufSurfTransformInter_Algo1,
  NvBufSurfTransformInter_Algo2,
  NvBufSurfTransformInter_Algo3,
  NvBufSurfTransformInter_Algo4,
  NvBufSurfTransformInter_Default,
 Specifies video interpolation methods. More...
enum  NvBufSurfTransform_Error {
  NvBufSurfTransformError_ROI_Error = -4,
  NvBufSurfTransformError_Invalid_Params = -3,
  NvBufSurfTransformError_Execution_Error = -2,
  NvBufSurfTransformError_Unsupported = -1,
  NvBufSurfTransformError_Success = 0,
 Specifies error codes returned by NvBufSurfTransform functions. More...
enum  NvBufSurfTransform_Transform_Flag {
  NVBUFSURF_TRANSFORM_CROP_SRC = 1,
  NVBUFSURF_TRANSFORM_CROP_DST = 1 << 1,
  NVBUFSURF_TRANSFORM_FILTER = 1 << 2,
  NVBUFSURF_TRANSFORM_FLIP = 1 << 3,
  NVBUFSURF_TRANSFORM_NORMALIZE = 1 << 4,
  NVBUFSURF_TRANSFORM_ALLOW_ODD_CROP = 1 << 5,
 Specifies transform types. More...
enum  NvBufSurfTransform_Composite_Flag {
  NVBUFSURF_TRANSFORM_COMPOSITE = 1,
  NVBUFSURF_TRANSFORM_BLEND = 1 << 1,
  NVBUFSURF_TRANSFORM_COMPOSITE_FILTER = 1 << 2,
 Specifies types of composition operations. More...
Functions
NvBufSurfTransform_Error NvBufSurfTransformSetSessionParams (NvBufSurfTransformConfigParams *config_params)
 Sets user-defined session parameters. More...
NvBufSurfTransform_Error NvBufSurfTransformGetSessionParams (NvBufSurfTransformConfigParams *config_params)
 Gets the session parameters used by NvBufSurfTransform(). More...
NvBufSurfTransform_Error NvBufSurfTransform (NvBufSurface *src, NvBufSurface *dst, NvBufSurfTransformParams *transform_params)
 Performs a transformation on batched input images. More...
NvBufSurfTransform_Error NvBufSurfTransformComposite (NvBufSurface *src, NvBufSurface *dst, NvBufSurfTransformCompositeParams *composite_params)
 Composites batched input images. More...
NvBufSurfTransform_Error NvBufSurfTransformAsync (NvBufSurface *src, NvBufSurface *dst, NvBufSurfTransformParams *transform_params, NvBufSurfTransformSyncObj_t *sync_obj)
 An asynchronous (non-blocking) transformation on batched input images. More...
NvBufSurfTransform_Error NvBufSurfTransformCompositeAsync (NvBufSurface *src, NvBufSurface *dst, NvBufSurfTransformCompositeParams *composite_params, NvBufSurfTransformSyncObj_t *sync_obj)
 Composites batched input images Asynchronously (non-blocking). More...
NvBufSurfTransform_Error NvBufSurfTransformCompositeBlend (NvBufSurface *src0, NvBufSurface *src1, NvBufSurface *alpha, NvBufSurface *dst, NvBufSurfTransformCompositeBlendParams *blend_params)
 Composites/Blends batched input images. More...
NvBufSurfTransform_Error NvBufSurfTransformMultiInputBufCompositeBlend (NvBufSurface **src, NvBufSurface *dst, NvBufSurfTransformCompositeBlendParamsEx *composite_blend_params)
 Performs Composition and Blending on multiple input images(batch size=1) and provide single output image(batch size=1) More...
NvBufSurfTransform_Error NvBufSurfTransformMultiInputBufCompositeBlendAsync (NvBufSurface **src, NvBufSurface *dst, NvBufSurfTransformCompositeBlendParamsEx *composite_blend_params, NvBufSurfTransformSyncObj_t *sync_obj)
 Performs Composition and Blending on multiple input images(batch size=1) and provide single output image(batch size=1) Asynchronously (non-blocking). More...
NvBufSurfTransform_Error NvBufSurfTransformSyncObjWait (NvBufSurfTransformSyncObj_t sync_obj, uint32_t time_out)
 Wait on the synchronization object. More...
NvBufSurfTransform_Error NvBufSurfTransformSyncObjDestroy (NvBufSurfTransformSyncObj_t *sync_obj)
 Destroy the synchronization object. More...
NvBufSurfTransform_Error NvBufSurfTransformSyncObjFromFile (int file, NvBufSurfTransformSyncObj_t *sync_obj, unsigned int *num_sync_objs)
 Get the synchronization object from sync point FD. More...
NvBufSurfTransform_Error NvBufSurfTransformSetDefaultSession (void)
 Sets the default transform session as the current session for all upcoming transforms. More...
◆ NVBUFSURF_MAX_SYNCOBJ
Definition at line 33 of file 9.0/sources/includes/nvbufsurftransform.h.
Typedef Documentation
◆ cudaStream_t
typedef struct CUstream_st* cudaStream_t
Definition at line 35 of file 9.0/sources/includes/nvbufsurftransform.h.
