9.0/sources/libs/nvdsinferserver/infer_cuda_utils.h File Reference
Header file declaring utility classes for CUDA memory management, CIDA streams and events.
Definition in file 9.0/sources/libs/nvdsinferserver/infer_cuda_utils.h.
Data Structures
class  nvdsinferserver::CudaStream
 Wrapper class for CUDA streams. More...
class  nvdsinferserver::CudaEvent
 Wrapper class for CUDA events. More...
class  nvdsinferserver::SysMem
 Base class for managing memory allocation. More...
class  nvdsinferserver::CudaDeviceMem
 Allocates and manages CUDA device memory. More...
class  nvdsinferserver::CudaHostMem
 Allocates and manages CUDA pinned memory. More...
class  nvdsinferserver::CpuMem
 Allocates and manages host memory. More...
class  nvdsinferserver::CudaTensorBuf
 A batch buffer with CUDA memory allocation. More...
Namespaces
 nvdsinferserver
Functions
UniqCudaTensorBuf nvdsinferserver::createTensorBuf (const InferDims &dims, InferDataType dt, int batchSize, const std::string &name, InferMemType mt, int devId, bool initCuEvent)
 Create a tensor buffer of the specified memory type, dimensions on the given device. More...
UniqCudaTensorBuf nvdsinferserver::createGpuTensorBuf (const InferDims &dims, InferDataType dt, int batchSize, const std::string &name="", int devId=0, bool initCuEvent=false)
 Create a CUDA device memory tensor buffer of specified dimensions on the given device. More...
UniqCudaTensorBuf nvdsinferserver::createCpuTensorBuf (const InferDims &dims, InferDataType dt, int batchSize, const std::string &name="", int devId=0, bool initCuEvent=false)
 Create a CUDA pinned memory tensor buffer of specified dimensions on the given device. More...
NvDsInferStatus nvdsinferserver::syncAllCudaEvents (const SharedBatchArray &bufList)
 Synchronize on all events associated with the batch buffer array. More...
