Definition at line 35 of file post_processor_detect.h.
| | DetectModelPostProcessor (int id, int gpuId=0) |
| NvDsPostProcessStatus | initResource (NvDsPostProcessContextInitParams &initParams) override |
| | ~DetectModelPostProcessor () override=default |
| NvDsPostProcessStatus | parseEachFrame (const std::vector< NvDsInferLayerInfo > &outputLayers, NvDsPostProcessFrameOutput &result) override |
| void | attachMetadata (NvBufSurface *surf, gint batch_idx, NvDsBatchMeta *batch_meta, NvDsFrameMeta *frame_meta, NvDsObjectMeta *object_meta, NvDsObjectMeta *parent_obj_meta, NvDsPostProcessFrameOutput &detection_output, NvDsPostProcessDetectionParams *all_params, std::set< gint > &filterOutClassIds, int32_t unique_id, gboolean output_instance_mask, gboolean process_full_frame, float segmentationThreshold, gboolean maintain_aspect_ratio, NvDsRoiMeta *roi_meta, gboolean symmetric_padding) override |
| void | releaseFrameOutput (NvDsPostProcessFrameOutput &frameOutput) override |
| const std::vector< std::vector< std::string > > & | getLabels () const |
| void | freeBatchOutput (NvDsPostProcessBatchOutput &batchOutput) |
| void | setNetworkInfo (NvDsInferNetworkInfo networkInfo) |
◆ DetectModelPostProcessor()
| DetectModelPostProcessor::DetectModelPostProcessor |
int |
id, |
int |
gpuId = 0 |
inline |
◆ ~DetectModelPostProcessor()
| DetectModelPostProcessor::~DetectModelPostProcessor |
overridedefault |
◆ attachMetadata()
| void DetectModelPostProcessor::attachMetadata |
NvBufSurface * |
surf, |
gint |
batch_idx, |
NvDsBatchMeta * |
batch_meta, |
NvDsFrameMeta * |
frame_meta, |
NvDsObjectMeta * |
object_meta, |
NvDsObjectMeta * |
parent_obj_meta, |
NvDsPostProcessFrameOutput & |
detection_output, |
NvDsPostProcessDetectionParams * |
all_params, |
std::set< gint > & |
filterOutClassIds, |
int32_t |
unique_id, |
gboolean |
output_instance_mask, |
gboolean |
process_full_frame, |
float |
segmentationThreshold, |
gboolean |
maintain_aspect_ratio, |
NvDsRoiMeta * |
roi_meta, |
gboolean |
symmetric_padding |
overridevirtual |
◆ freeBatchOutput()
◆ getLabels()
| const std::vector<std::vector<std::string> >& ModelPostProcessor::getLabels |
const |
inlineinherited |
◆ initResource()
◆ parseEachFrame()
◆ parseLabelsFile()
◆ releaseFrameOutput()
◆ setNetworkInfo()
◆ m_AllLayerInfo
◆ m_GpuID
| uint32_t ModelPostProcessor::m_GpuID = 0 |
protectedinherited |
◆ m_Labels
| std::vector<std::vector<std::string> > ModelPostProcessor::m_Labels |
◆ m_NetworkInfo
◆ m_NetworkType
◆ m_OutputLayerInfo
◆ m_UniqueID
| int ModelPostProcessor::m_UniqueID = 0 |
