sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h File Reference
Data Structures
struct  NvDsPostProcessDetectionFilterParams
struct  NvDsPostProcessColorParams
 Holds the bounding box coloring information for one class;. More...
struct  NvDsPostProcessDetectionParams
 Holds detection and bounding box grouping parameters. More...
struct  _NvDsPostProcessContextInitParams
 Holds the initialization parameters required for the NvDsPostProcessContext interface. More...
struct  NvDsPostProcessObjectDetectionInfo
 Holds information about one parsed object from a detector's output. More...
struct  NvDsPostProcessAttribute
 Holds information about one classified attribute. More...
struct  NvDsPostProcessInstanceMaskInfo
 Holds information about one parsed object and instance mask from a detector's output. More...
 Holds information about one detected object. More...
struct  NvDsPostProcessDetectionOutput
 Holds information on all objects detected by a detector network in one frame. More...
struct  NvDsPostProcessClassificationOutput
 Holds information on all attributes classifed by a classifier network for one frame. More...
struct  NvDsPostProcessSegmentationOutput
 Holds information parsed from segmentation network output for one frame. More...
struct  NvDsPoint3f
struct  NvDsPostProcessBodyPoseOutput
 Holds information parsed from bodypose network output for one frame. More...
struct  NvDsPostProcessFrameOutput
 Holds the information inferred by the network on one frame. More...
struct  NvDsPostProcessBatchOutput
 Holds the output for all of the frames in a batch (an array of frame), and related buffer information. More...
struct  NvDsPostProcessParseDetectionParams
 Holds the detection parameters required for parsing objects. More...
struct  NvDsPostProcessObjectInfo
 Holds the cached information of an object. More...
struct  _NvDsPostProcessObjectHistory
 Holds the inference information/history for one object based on it's tracking id. More...
Macros
#define _PATH_MAX   4096
#define _MAX_STR_LENGTH   1024
#define getDimsCHWFromDims(dimsCHW, dims)
 Sets values on a NvDsInferDimsCHW structure from a NvDsInferDims structure. More...
#define getDimsHWCFromDims(dimsCHW, dims)
#define DIVIDE_AND_ROUND_UP(a, b)   ((a + b - 1) / b)
#define printMsg(level, tag_str, fmt, ...)
#define printError(fmt, ...)
#define printWarning(fmt, ...)
#define printInfo(fmt, ...)
#define printDebug(fmt, ...)
Typedefs
typedef struct _NvDsPostProcessContextInitParams NvDsPostProcessContextInitParams
typedef NvDsPostProcessObjectDetectionInfo NvDsPostProcessParseObjectInfo
 A typedef defined to maintain backward compatibility. More...
typedef struct NvDsPoint3f NvDsPoint3f
typedef struct _NvDsPostProcessObjectHistory NvDsPostProcessObjectHistory
Enumerations
enum  NvDsPostProcessStatus {
  NVDSPOSTPROCESS_SUCCESS = 0,
  NVDSPOSTPROCESS_CONFIG_FAILED,
  NVDSPOSTPROCESS_CUSTOM_LIB_FAILED,
  NVDSPOSTPROCESS_INVALID_PARAMS,
  NVDSPOSTPROCESS_OUTPUT_PARSING_FAILED,
  NVDSPOSTPROCESS_CUDA_ERROR,
  NVDSPOSTPROCESS_RESOURCE_ERROR,
  NVDSPOSTPROCESS_UNKNOWN_ERROR,
 Enum for the status codes returned by NvDsPostProcessAlgorithm. More...
enum  NvDsPostProcesLogLevel {
  NVDSPOSTPROCESS_LOG_ERROR = 0,
  NVDSPOSTPROCESS_LOG_WARNING,
  NVDSPOSTPROCESS_LOG_INFO,
  NVDSPOSTPROCESS_LOG_DEBUG,
enum  NvDsPostProcessClusterMode {
  NVDSPOSTPROCESS_CLUSTER_GROUP_RECTANGLES = 0,
  NVDSPOSTPROCESS_CLUSTER_DBSCAN,
  NVDSPOSTPROCESS_CLUSTER_NMS,
  NVDSPOSTPROCESS_CLUSTER_DBSCAN_NMS_HYBRID,
  NVDSPOSTPROCESS_CLUSTER_NONE,
 Enum for clustering mode for detectors. More...
enum  NvDsPostProcessTensorOrder {
  NvDsPostProcessTensorOrder_kNCHW,
  NvDsPostProcessTensorOrder_kNHWC,
  NvDsPostProcessTensorOrder_kNC,
 Defines UFF layer orders. More...
enum  NvDsPostProcessNetworkType {
  NvDsPostProcessNetworkType_Detector,
  NvDsPostProcessNetworkType_Classifier,
  NvDsPostProcessNetworkType_Segmentation,
  NvDsPostProcessNetworkType_InstanceSegmentation,
  NvDsPostProcessNetworkType_BodyPose,
  NvDsPostProcessNetworkType_Other = 100,
 Defines network types. More...
Functions
const char * safeStr (const std::string &str)
bool string_empty (const char *str)
Variables
constexpr float DEFAULT_PRE_CLUSTER_THRESHOLD = 0.2
constexpr float DEFAULT_POST_CLUSTER_THRESHOLD = 0.0
constexpr float DEFAULT_EPS = 0.0
constexpr int DEFAULT_GROUP_THRESHOLD = 0
constexpr int DEFAULT_MIN_BOXES = 0
constexpr float DEFAULT_DBSCAN_MIN_SCORE = 0
constexpr float DEFAULT_NMS_IOU_THRESHOLD = 0.3
constexpr int DEFAULT_TOP_K = -1
constexpr bool ATHR_ENABLED = true
constexpr float ATHR_THRESHOLD = 60.0
constexpr int PROCESS_MODEL_FULL_FRAME = 1
constexpr int PROCESS_MODEL_OBJECTS = 2
◆ _MAX_STR_LENGTH
◆ _PATH_MAX
◆ DIVIDE_AND_ROUND_UP
#define DIVIDE_AND_ROUND_UP (   a,
)    ((a + b - 1) / b)
◆ getDimsCHWFromDims
#define getDimsCHWFromDims (   dimsCHW,
  dims
Value:
do { \
(dimsCHW).c = (dims).d[0]; \
(dimsCHW).h = (dims).d[1]; \
(dimsCHW).w = (dims).d[2]; \
} while (0)
Definition at line 43 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
◆ getDimsHWCFromDims
#define getDimsHWCFromDims (   dimsCHW,
  dims
Value:
do { \
(dimsCHW).h = (dims).d[0]; \
(dimsCHW).w = (dims).d[1]; \
(dimsCHW).c = (dims).d[2]; \
} while (0)
Definition at line 50 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
◆ printDebug
#define printDebug (   fmt,
Value:
do { \
printMsg (NVDSINFER_LOG_DEBUG, "DEBUG", fmt, ##__VA_ARGS__); \
} while (0)
Definition at line 138 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
◆ printError
#define printError (   fmt,
Value:
do { \
printMsg (NVDSINFER_LOG_ERROR, "Error in", fmt, ##__VA_ARGS__); \
} while (0)
Definition at line 123 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
◆ printInfo
#define printInfo (   fmt,
Value:
do { \
printMsg (NVDSINFER_LOG_INFO, "Info from", fmt, ##__VA_ARGS__); \
} while (0)
Definition at line 133 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
◆ printMsg
#define printMsg (   level,
  tag_str,
  fmt,
Value:
do { \
char* baseName = strrchr((char*)__FILE__, '/'); \
baseName = (baseName) ? (baseName + 1) : (char*)__FILE__; \
char logMsgBuffer[5 * _MAX_STR_LENGTH + 1]; \
snprintf(logMsgBuffer, 5 * _MAX_STR_LENGTH, \
tag_str " NvDsPostProcess::%s() <%s:%d> : " fmt, \
__func__, baseName, __LINE__, ##__VA_ARGS__); \
fprintf(stderr, "%s\n", logMsgBuffer); \
} while (0)
Definition at line 112 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
◆ printWarning
#define printWarning (   fmt,
Value:
do { \
printMsg (NVDSINFER_LOG_WARNING, "Warning from", fmt, ##__VA_ARGS__); \
} while (0)
Definition at line 128 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
Typedef Documentation
◆ NvDsPoint3f
◆ NvDsPostProcessContextInitParams
◆ NvDsPostProcessObjectHistory
◆ NvDsPostProcessParseObjectInfo
◆ NvDsPostProcesLogLevel
Enumerator
Definition at line 105 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
◆ NvDsPostProcessClusterMode
Enumerator
Definition at line 169 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
◆ NvDsPostProcessNetworkType
Enumerator
Specifies a detector.
Detectors find objects and their coordinates, and their classes in an input frame.
Specifies a classifier.
Classifiers classify an entire frame into one of several classes.
Specifies a segmentation network.
A segmentation network classifies each pixel into one of several classes.
Specifies a instance segmentation network.
A instance segmentation network detects objects, bounding box and mask for objects, and their classes in an input frame
Bodypose 3D.
Specifies other.
Output layers of an "other" network are not parsed by NvDsPostProcessContext. This is useful for networks that produce custom output. Output can be parsed by the NvDsPostProcessContext client or can be combined with the Gst-nvinfer feature to flow output tensors as metadata.
Bodypose 3D.
Specifies other.
Definition at line 191 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
◆ NvDsPostProcessStatus
Enumerator
operation succeeded.
Failed to configure the instance possibly due to an erroneous initialization property.
Custom Library interface implementation failed.
Invalid parameters were supplied.
Output parsing failed.
CUDA error was encountered.
Resource error was encountered.
Unknown error was encountered.
Definition at line 84 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
◆ NvDsPostProcessTensorOrder
Enumerator
Definition at line 181 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
Function Documentation
◆ safeStr()
const char* safeStr ( const std::string &  str)
inline
◆ string_empty()
bool string_empty ( const char *  str)
inline
Variable Documentation
◆ ATHR_ENABLED
constexpr
◆ ATHR_THRESHOLD
constexpr
◆ DEFAULT_DBSCAN_MIN_SCORE
constexpr
◆ DEFAULT_EPS
constexpr
◆ DEFAULT_GROUP_THRESHOLD
constexpr
◆ DEFAULT_MIN_BOXES
constexpr
◆ DEFAULT_NMS_IOU_THRESHOLD
constexpr
◆ DEFAULT_POST_CLUSTER_THRESHOLD
constexpr
◆ DEFAULT_PRE_CLUSTER_THRESHOLD
constexpr
◆ DEFAULT_TOP_K
constexpr
◆ PROCESS_MODEL_FULL_FRAME
constexpr
◆ PROCESS_MODEL_OBJECTS
constexpr
NVDSINFER_LOG_ERROR
@ NVDSINFER_LOG_ERROR
Definition: sources/includes/nvdsinfer.h:258
NVDSINFER_LOG_INFO
@ NVDSINFER_LOG_INFO
Definition: sources/includes/nvdsinfer.h:260
@ NVDSINFER_LOG_WARNING
Definition: sources/includes/nvdsinfer.h:259
NVDSINFER_LOG_DEBUG
@ NVDSINFER_LOG_DEBUG
Definition: sources/includes/nvdsinfer.h:261
_MAX_STR_LENGTH
Definition: sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h:38
