deepstream::DataReceiver Class Reference
A specific signal handler for consuming data.
Users must implement the IDataConsumer interface to create a data receiver. Data receiver can only be attached to elements that supports "new-sample" signal, typically an "appsink".
Definition at line 37 of file service-maker/includes/data_receiver.hpp.
Inheritance diagram for deepstream::DataReceiver:
Collaboration diagram for deepstream::DataReceiver:
Data Structures
class  IDataConsumer
 required interface for a data receiver More...
Public Member Functions
 DataReceiver (const std::string &name, IDataConsumer *consumer, unsigned int retries=0)
 Constructor. More...
 DataReceiver (const std::string &name, const char *factory, IDataConsumer *consumer, unsigned int retries=0)
virtual ~DataReceiver ()
 Destructor. More...
int consume (Buffer buffer)
 Consume a buffer. More...
 Destructor. More...
void * getCallbackFn (const std::string &name) const
 Return the callback for a specific signal. More...
const std::string getName () const
 Return the name assigned during the construction. More...
 operator bool () const noexcept
 Check if the object is void. More...
bool operator== (const Object &other) noexcept
 Check if the two objects are the same. More...
GstObjectgive ()
 Give up the ownership and return the opaque pointer. More...
GstObjectgive ()
GstObjectgetGObject ()
 Return the opaque object pointer. More...
Objecttake (GstObject *object)
 Takes the ownership of a object through the opaque pointer. More...
Objectseize (GstObject *object)
 Seize a opaque object to prevent it from being destroyed somewhere. More...
Objectset (const YAML::Node &params)
 Set the properties from key/value pairs in the yaml format. More...
Objectset (const std::string &name, const Value &value)
template<typename T , typename... Args>
Objectset (const std::string &name, const T &value, const Args &... args)
ObjectgetProperty (const std::string &name, T &value, Args &... args)
 Template for getting multiple properties. More...
std::vector< std::string > listSignals (bool is_action)
 List all the supported signals from the object. More...
bool connectSignal (const std::string &signal_name, SignalHandler &handler)
 Connect a signal handler to the object. More...
void emitSignal (const std::string &signal_name, va_list args)
 Emit a signal. More...
static unsigned long type ()
 Return the type id assigned to signal handler. More...
Protected Member Functions
virtual void set_ (const std::string &name, const Value &value)
virtual void set_ (const std::string &name, const YAML::Node &value)
virtual Value get_ (const std::string &name)
Protected Attributes
std::unique_ptr< IDataConsumerdata_consumer_
unsigned int retries_
std::unique_ptr< IActionProviderprovider_
std::string param_spec_
 property spec in YAML format More...
std::map< std::string, Object::Valueproperties_
 property map More...
GstObjectobject_
◆ DataReceiver() [1/4]
deepstream::DataReceiver::DataReceiver ( const std::string &  name,
IDataConsumer consumer,
unsigned int  retries = 0
Constructor.
Create a data reciver with a user implemented data provider interface
Parameters
[in]namename of the instance
[in]handlerimplementation of the IDataConsumer interface
◆ DataReceiver() [2/4]
const char *  factory,
Constructor.
Parameters
[in]factoryname of the factory to create the instance
◆ ~DataReceiver() [1/2]
virtual deepstream::DataReceiver::~DataReceiver ( )
virtual
Destructor.
◆ DataReceiver() [3/4]
Constructor.
Parameters
◆ DataReceiver() [4/4]
Constructor.
Parameters
◆ ~DataReceiver() [2/2]
virtual
Destructor.
Member Function Documentation
◆ connectSignal() [1/2]
bool deepstream::Object::connectSignal ( const std::string &  signal_name,
SignalHandler handler
inherited
Parameters
[in]signal_namename of the signal to be connected
[in]handlerhandler for the signal
◆ connectSignal() [2/2]
inherited
Parameters
◆ consume() [1/2]
int deepstream::DataReceiver::consume ( Buffer  buffer)
Consume a buffer.
The method is called from the pipeline and invokes the its own IDataConsumer interface.
◆ consume() [2/2]
Consume a buffer.
◆ emitSignal() [1/2]
void deepstream::Object::emitSignal ( const std::string &  signal_name,
va_list  args
inherited
Emit a signal.
◆ emitSignal() [2/2]
va_list  args
inherited
Emit a signal.
◆ get_() [1/2]
virtual Value deepstream::CustomObject::get_ ( const std::string &  name)
protectedvirtualinherited
Reimplemented from deepstream::Object.
◆ get_() [2/2]
◆ getCallbackFn() [1/2]
void* deepstream::SignalHandler::getCallbackFn ( const std::string &  name) const
inherited
◆ getCallbackFn() [2/2]
inherited
◆ getGObject() [1/2]
GstObject* deepstream::Object::getGObject ( )
inlineinherited
Definition at line 140 of file service-maker/includes/object.hpp.
References deepstream::Object::object_.
◆ getGObject() [2/2]
inlineinherited
Definition at line 140 of file 9.0/service-maker/includes/object.hpp.
◆ getName() [1/2]
const std::string deepstream::Object::getName ( ) const
inherited
◆ getName() [2/2]
inherited
◆ getProperty() [1/2]
Object& deepstream::Object::getProperty ( const std::string &  name,
T &  value,
Args &...  args
inlineinherited
Definition at line 171 of file 9.0/service-maker/includes/object.hpp.
References deepstream::Object::get_(), and deepstream::Object::getProperty().
◆ getProperty() [2/2]
T &  value,
Args &...  args
inlineinherited
◆ give() [1/2]
GstObject* deepstream::Object::give ( )
inherited
◆ give() [2/2]
inherited
◆ listSignals() [1/2]
std::vector<std::string> deepstream::Object::listSignals ( bool  is_action)
inherited
◆ listSignals() [2/2]
inherited
◆ operator bool() [1/2]
deepstream::Object::operator bool ( ) const
inlineexplicitnoexceptinherited
Definition at line 131 of file 9.0/service-maker/includes/object.hpp.
◆ operator bool() [2/2]
Definition at line 131 of file service-maker/includes/object.hpp.
◆ operator==() [1/2]
bool deepstream::Object::operator== ( const Object other)
inlinenoexceptinherited
Definition at line 134 of file service-maker/includes/object.hpp.
◆ operator==() [2/2]
Definition at line 134 of file 9.0/service-maker/includes/object.hpp.
◆ seize() [1/2]
Object& deepstream::Object::seize ( GstObject object)
inherited
◆ seize() [2/2]
inherited
◆ set() [1/6]
Object& deepstream::Object::set ( const std::string &  name,
const T &  value,
inlineinherited
◆ set() [2/6]
const T &  value,
inlineinherited
◆ set() [3/6]
const Value value
inlineinherited
Definition at line 154 of file 9.0/service-maker/includes/object.hpp.
References deepstream::Object::set_().
◆ set() [4/6]
const Value value
inlineinherited
Definition at line 154 of file service-maker/includes/object.hpp.
◆ set() [5/6]
Object& deepstream::Object::set ( const YAML::Node &  params)
inherited
Referenced by deepstream::Pipeline::add(), and deepstream::Object::set().
◆ set() [6/6]
inherited
◆ set_() [1/4]
virtual void deepstream::CustomObject::set_ ( const std::string &  name,
const Value value
◆ set_() [2/4]
const Value value
◆ set_() [3/4]
const YAML::Node &  value
◆ set_() [4/4]
◆ take() [1/2]
Object& deepstream::Object::take ( GstObject object)
inherited
◆ take() [2/2]
inherited
◆ type() [1/2]
static unsigned long deepstream::SignalHandler::type ( )
staticinherited
◆ type() [2/2]
staticinherited
Field Documentation
◆ data_consumer_
std::unique_ptr< IDataConsumer > deepstream::DataReceiver::data_consumer_
protected
Definition at line 95 of file service-maker/includes/data_receiver.hpp.
◆ object_
GstObject * deepstream::Object::object_
protectedinherited
◆ param_spec_
std::string deepstream::CustomObject::param_spec_
protectedinherited
Definition at line 51 of file service-maker/includes/custom_object.hpp.
◆ properties_
std::map< std::string, Object::Value > deepstream::CustomObject::properties_
protectedinherited
property map
Definition at line 53 of file service-maker/includes/custom_object.hpp.
◆ provider_
std::unique_ptr< IActionProvider > deepstream::SignalHandler::provider_
protectedinherited
Definition at line 91 of file service-maker/includes/signal_handler.hpp.
◆ retries_
unsigned int deepstream::DataReceiver::retries_
protected
Definition at line 96 of file service-maker/includes/data_receiver.hpp.
