Pad is an abstraction of the I/O with an Element,.
Pad class derives from the base Object class, so it is reference based, supports copying and moving. A Pad instance must be either for input or for output
Public Member Functions | |
| Pad () | |
| empty constructor More... | |
| Pad (bool is_input, const std::string &name=std::string()) | |
| substantial constructor More... | |
| Pad (const Object &) | |
| copy constructor More... | |
| Pad (Object &&) | |
| move constructor More... | |
| const std::string | getName () const |
| Return the name assigned during the construction. More... | |
| operator bool () const noexcept | |
| Check if the object is void. More... | |
| bool | operator== (const Object &other) noexcept |
| Check if the two objects are the same. More... | |
| GstObject * | give () |
| Give up the ownership and return the opaque pointer. More... | |
| GstObject * | getGObject () |
| Return the opaque object pointer. More... | |
| Object & | take (GstObject *object) |
| Takes the ownership of a object through the opaque pointer. More... | |
| Object & | seize (GstObject *object) |
| Seize a opaque object to prevent it from being destroyed somewhere. More... | |
| Object & | set (const YAML::Node ¶ms) |
| Set the properties from key/value pairs in the yaml format. More... | |
| Object & | set (const std::string &name, const Value &value) |
| template<typename T , typename... Args> | |
| Object & | set (const std::string &name, const T &value, const Args &... args) |
| Object & | getProperty (const std::string &name, T &value, Args &... args) |
| Template for getting multiple properties. More... | |
| std::vector< std::string > | listSignals (bool is_action) |
| List all the supported signals from the object. More... | |
| bool | connectSignal (const std::string &signal_name, SignalHandler &handler) |
| Connect a signal handler to the object. More... | |
| void | emitSignal (const std::string &signal_name, va_list args) |
| Emit a signal. More... | |
Static Public Member Functions | |
| static unsigned long | type () |
| Return the object's type id. More... | |
Protected Member Functions | |
| virtual void | set_ (const std::string &name, const Value &value) |
| virtual void | set_ (const std::string &name, const YAML::Node &value) |
| virtual Value | get_ (const std::string &name) |
Protected Attributes | |
| GstObject * | object_ |
| deepstream::Pad::Pad | ( | ) |
empty constructor
| deepstream::Pad::Pad | ( | bool | is_input, |
| const std::string & | name = std::string() |
| deepstream::Pad::Pad | ( | const Object & | ) |
copy constructor
| deepstream::Pad::Pad | ( | Object && | ) |
move constructor
inherited |
| [in] | signal_name | name of the signal to be connected |
| [in] | handler | handler for the signal |
inherited |
Emit a signal.
protectedvirtualinherited |
Reimplemented in deepstream::CustomObject.
Referenced by deepstream::Object::getProperty().
inlineinherited |
Definition at line 140 of file object.hpp.
References deepstream::Object::object_.
inherited |
inlineinherited |
Definition at line 171 of file object.hpp.
References deepstream::Object::get_().
Referenced by deepstream::CountMarker::handleData(), deepstream::TensorMetaParser::handleData(), deepstream::MsgMetaGenerator::handleData(), deepstream::NvDsKittiDump::handleData(), deepstream::LiDARDataSource::initialize(), deepstream::SmartRecordingAction::onAttached(), and deepstream::FileDataSource::read().
inherited |
inherited |
inlineexplicitnoexceptinherited |
Definition at line 131 of file object.hpp.
inlinenoexceptinherited |
Definition at line 134 of file object.hpp.
inlineinherited |
Definition at line 161 of file object.hpp.
References deepstream::Object::set(), and deepstream::Object::set_().
Definition at line 154 of file object.hpp.
References deepstream::Object::set_().
inherited |
Referenced by deepstream::Pipeline::add(), and deepstream::Object::set().
Referenced by deepstream::Object::set().
staticinherited |
protectedinherited |
Definition at line 198 of file object.hpp.
Referenced by deepstream::Object::getGObject(), deepstream::Object::operator bool(), and deepstream::Object::operator==().
